| nsr_rory |
 nsr_rory Renault 5 Driver
| Marci |
 Marci Brolly Dolly
 Posted: 12:58 - 24 Jan 2007 Post subject: |
The problem isn't at the engine then... strip reeds, carb manifold, carb, air intake manifold and airbox. Ensure all rubbers are ok - not perished with cracks in. Strip carb and clean all jets etc. Clean airfilter.
If it starts and revs up with fuel directly in cylinder, problem can only be in the fuel delivery system... all easy stuff to remove, strip, clean and put back on. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| nsr_rory |
| Marci |
 Marci Brolly Dolly
 Posted: 13:33 - 24 Jan 2007 Post subject: |
It's revving high due to the amount of fuel your pouring into the cylinder at a guess. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| nsr_rory |
| Marci |
 Marci Brolly Dolly
 Posted: 13:44 - 24 Jan 2007 Post subject: |
That can only be massive airleak and/or carb problem. It won't rev to 10k unless it has enough fuel to rev to 10k... are you SURE the carb is assembled correctly - slide properly inserted correct way round, correct size jets, float valve sealing properly etc etc...? ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| nsr_rory |
| Marci |
 Marci Brolly Dolly
 Posted: 13:55 - 24 Jan 2007 Post subject: |
Cracks in the rubbers between carb and engine and carb and airbox... lack of gasket on carb float bowl...
If floats / float valve was a problem you'd have fuel dripping out of the carb breather nipple on the base of the float bowl. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| nsr_rory |
| Marci |
 Marci Brolly Dolly
 Posted: 14:08 - 24 Jan 2007 Post subject: |
Screws on the SIDE of the carb are to set idle air:fuel mixture, and idle speed. They should be set according to the manual, not "to stop fuel pissing out".
There should be a rubber ring that sits in a lip around the edge of the float bowl which provides an airtight seal. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| nsr_rory |
| Marci |
 Marci Brolly Dolly
 Posted: 14:15 - 24 Jan 2007 Post subject: |
Apparently it's a PHBH28 carb or similar. There should be a big bolt on the bottom, that should be done up tight - it's what holds the floatbowl on and also should have the main jet fitted to the middle on the other end of it.
On the side are two screws. A Large sprung screw, and a smaller one.
Turn the smaller one ALL the way in til it nips gently, then wind it out 2 and a half turns.
Get the bike running then turn the Large sprung screw to set idle revs... one way will increase revs, the other way decrease revs. You want it set to idle around 1200rpm ish. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| nsr_rory |
| Marci |
 Marci Brolly Dolly
 Posted: 14:36 - 24 Jan 2007 Post subject: |
Have you checked that the throttle slide and needle are all correctly seated etc so that when throttle is closed the slide is in the fully-down position (look up the carb air inlet)? ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| nsr_rory |
| Marci |
 Marci Brolly Dolly
 Posted: 14:42 - 24 Jan 2007 Post subject: |
That's not testing anything. That's you GIVING it fuel, and it'll rev as high as the amount of fuel you've given it. Stop pouring fuel in holes. We already know fuel is getting to the engine, that much is clear. What we don't know is HOW MUCH fuel the carb is giving it, and the only way to test that is to let the carb do the delivery, not by you feeding it thru a hole...
If you're hundred percent certain that the throttle slide and needle etc are all seating correctly, and returning fully to the closed position when throttle is shut (ie: no cable snags / cable too short once fitted so holds the slide open slightly), there's no further advice I can give. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| nsr_rory |
| nsr_rory |
The last post was made 19 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
