Rs 125 battery is flat...Help
5v3d3b0
PostPosted: 14:32 - 24 Jan 2007    Post subject: Rs 125 battery is flat...Help Reply with quote
The battery has next to 0 power...The neutral light doesn't even come on at full strength. Will it be enough to take a few long rides, or will I have to buy a new battery?
Jamie S
PostPosted: 14:36 - 24 Jan 2007    Post subject: Reply with quote
urmm duh ! charge it up !
5v3d3b0
PostPosted: 14:41 - 24 Jan 2007    Post subject: Reply with quote
Don't have a charger...
Jamie S
PostPosted: 14:43 - 24 Jan 2007    Post subject: Reply with quote
you no any one who has ? it would save u so much money mate
5v3d3b0
PostPosted: 14:46 - 24 Jan 2007    Post subject: Reply with quote
I might do. If so, instructions please! 12V right?
Marci
PostPosted: 14:47 - 24 Jan 2007    Post subject: Reply with quote
Bump start it, whack it in neutral, gaffa tape the throttle open so it sits at 5000rpm and leave it for a while. Won't do the bike any good but it should get some charge into it.
Can pick up a cheap trickle charger for £10 - shop around...
Yes, 12v. Clip negative (usually black lead) of charger to the battery first. Clip positive (usually red) to the battery. Turn on the charger.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Jamie S
PostPosted: 14:50 - 24 Jan 2007    Post subject: Reply with quote
look in the argos catalog (sp?)
they have them !
5v3d3b0
PostPosted: 14:52 - 24 Jan 2007    Post subject: Reply with quote
Will a car charger do? Think my girlfriend's dad has one
0ddball
PostPosted: 14:53 - 24 Jan 2007    Post subject: Reply with quote
Why is it flat in the first place?
Jamie S
PostPosted: 14:54 - 24 Jan 2007    Post subject: Reply with quote
yess ! a car chager will do !
5v3d3b0
It's been standing for about half a year...
Marci
PostPosted: 14:55 - 24 Jan 2007    Post subject: Reply with quote
Generally yes but don't leave it unattended during the charge as a carcharger will put out a higher charging amperage than a trickle charger. Plonk your hand on the side of the battery whilst it's charging, and if it's warm, stop charging it. DON'T use the "fast" charge option on the charger if it has one. Leave it on "normal".
2hrs should be plenty to start with, refit it, fire it up and take it for a good long run, preferably during daylight so you don't need mainbeam on.
Trickle chargers for bike / low capacity batteries tend to charge at around 0.4 / 0.5a, whereas car chargers can be anything up to 5a set to their slowest charging speed, and anything up to 12a (possibly more) on fast.
5v3d3b0
How long do I charge it for?
EDIT: Thanks
Jamie S
car chagers are the same
Jamie S
obout 12 hours
Jamie S
PostPosted: 14:56 - 24 Jan 2007    Post subject: Reply with quote
set it to low on the strenght guage and leave over night !
0ddball
It might take a charge. Though sometimes if they have been left flat for too long it knackers them.
SoulRider
PostPosted: 15:23 - 24 Jan 2007    Post subject: Reply with quote
i brought a charger when i had my rs125 and use it now on my sv650s, their priceless, saves you so much money. mine was about £35 if i remember right and after a battery is fully charged it retains the chargbe untill i fit it. 40 mins charge is enough to get the bike started just needs decent run after.
Well worth investing in one imo Thumbs Up
My Bike Pics
alains
PostPosted: 16:13 - 24 Jan 2007    Post subject: Reply with quote
be carefull , lead batteries do not like fast charging . charge intensity must be 1/10 of power . ex : for a 5Ah battery , charge is 0.5 Amps during 8-10 hours . to check if your battery is still in order :
- after charging check voltage . if it's under 12.8 volts throw it
- leave it for 2-3 hours , check voltage again if you have lost more than 0.3 volts throw it
5v3d3b0
PostPosted: 22:25 - 25 Jan 2007    Post subject: Reply with quote
My girlfriend's dad has 2 different car chargers... One is 5 amps, and one is 3... Is 3 too much?
Finglonga
PostPosted: 22:40 - 25 Jan 2007    Post subject: Reply with quote
Car chargers are usually High amp chargers and can fry a small bike battery. As Alains says keep an eye on th battery.
Andy Sez....
F.Y.Y.F.F.
Jamie S
PostPosted: 00:01 - 26 Jan 2007    Post subject: Reply with quote
3 amp.
and dont let it get to hot
colin1
Captain Safety
PostPosted: 00:51 - 26 Jan 2007    Post subject: Reply with quote
i think you will need a new battery
alains
PostPosted: 00:59 - 26 Jan 2007    Post subject: Reply with quote
Timmeh
PostPosted: 01:04 - 26 Jan 2007    Post subject: Reply with quote
I bought an intelligent, fully-automatic charger from Halfords and it is the boss. It charges both car and bike, sealed and old-skool and only puts in what the battery allows. I've never had any problems with any of the batteries I've used on it, even on one I accidentally left on charge over the weekend.
The last post was made 19 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.86 - MySQL Queries: 13 - Page Size: 121 Kb
