| Project9928 |
 Project9928 Traffic Copper
| Gradog |
 Gradog Nitrous Nuisance
| finpos |
 finpos World Chat Champion
| gixxersixx |
 gixxersixx Trackday Trickster
 Posted: 10:37 - 05 Jan 2007 Post subject: |
| finpos wrote: |
What you think is low beam is actually high beam,
finpos. |
Low beam fillament could be blown, change your bulb ____________________ We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies |
| Project9928 |
| Project9928 |
| finpos |
 Posted: 11:42 - 05 Jan 2007 Post subject: |
If it does have relays, then between the switches and the lamps is exactly where they will be.
I've seen a couple of twin-light bikes where the headlight wiring has been, err, modified because people don't like the light pattern (one on the other off on low beam), but sounds like you have pair of H4s so that shouldn't be the case.
I'm a little perplexed about the way the headlights are wired up, though, because (supposedly) one of the reasons you have two is that they don't both go into the same failure mode if something (a relay?) breaks - then you are always left with some light. But I guess that's not the case.
By the way, you'll be suprised what people can do with H4s if they push and twist them hard enough
finpos. |
| Project9928 |
 Posted: 11:52 - 05 Jan 2007 Post subject: |
| finpos wrote: | If it does have relays, then between the switches and the lamps is exactly where they will be.
finpos. |
Yeah I was alittle worried when I looked on r1-forum.com about a mod to turn the lights off completely, but then its using a non-Yamaha switch and wires running from the horn...... looked quite dodge to say the least. But there's nothing obviously dodgy around the fuse box or headlight switch but I'll have to take the farings off to get a proper look.
The H4's I fitted in were brand new on Sunday and they slipped in normally so hopefully thats a good sign that the connecters are ok, but its another thing I will be inspecting.
Lol I just hope it is the relays because then it saves me having to do a load of work . |
| finpos |
 Posted: 12:17 - 05 Jan 2007 Post subject: |
Found a wiring diagram online and had a quick look at it for you:
1. Yamaha indeed haven't bothered with using the headlights in a redundent manner. Dual headlights for looking fancy, then
2. 95% certain the suspect is the secondary relay (five-pin relay labeled "65 - headlight relay (dimmer)" in the workshop manual). From what you describe, the associated wiring should all be ok, with the exception of the wiring between that relay and the low beam filament (B/G) which hasn't been seen to work yet. (Previous owner butchery not accounted for)
3. However, that relay seems to have gone into a very odd failure mode. You should be able to whip it out and test it off the bike easily enough - it's a simple changeover relay. Alternately, you can short out the correct (B/L to B/G = low beam, B/L to B/Y = high beam, don't blame me etc. ) pins in it's socket to see if the lights come on as expected.
Good luck!
finpos. |
| Project9928 |
 Posted: 12:54 - 05 Jan 2007 Post subject: |
| finpos wrote: | Found a wiring diagram online and had a quick look at it for you:
Good luck!
finpos. |
Well I've just phoned the place where I got the bike from and they have the relay they order in. So I'm going to give that a go tomorrow and I'll let you know how I get on.
Thanks for the help  |
| Project9928 |
 Posted: 22:08 - 06 Jan 2007 Post subject: |
Well I got the relay that the dealer had for me and it doesn't work......... probably because its for a diffrent bike lol.
They gave me a 5 pin relay and I should have a 4 pin relay..... great .
The bike is going to be taken apart tomorrow so I can get a good look at the wiring. |
| finpos |
 Posted: 23:31 - 06 Jan 2007 Post subject: |
On the wiring diagram I looked at, the 5-pin relay is indeed the right one - if you found a 4 pin one, that was (probably) the primary (on-off) relay. They are the same shape.
The secondary (dimmer) relay should have the B/L, B/Y and B/G wires going to it, plus two more that I can't remember the colour of.
Keep digging
finpos. |
| Project9928 |
| Project9928 |
| finpos |
| Project9928 |
 Posted: 19:31 - 08 Jan 2007 Post subject: |
lol nope you've got it completely right.
Just taken a look at the wiring diagram and I got to the 2 mixed up. Also the primary relay was the one that the garage were messing around with so i don't think they would have fixed it lol.
I've got to get another relay anyway because I broke one of the clips by accident on the one they gave me before i fitted it up.
Should be fully up and running friday
Thanks mate  |
| Project9928 |
 Posted: 00:29 - 23 Jan 2007 Post subject: |
All sorted now at last.
There was no 2nd relay present...... just a bit of wire looped back on it self where the relay should be lol. Pulled it out and pluged in the relay and woohoo I have lights  |
| finpos |
| Project9928 |
The last post was made 19 years, 160 days ago. Instead of replying here, would creating a new thread be more useful? |
