Spark Plug Colour?!!
YT
PostPosted: 09:25 - 08 May 2002    Post subject: Spark Plug Colour?!! Reply with quote
What sort of colour should the spark plug be??
Not long ago put a new one in and after looking at it, it looks quite black already.
Is it running to lean/rich?? Or is this usual?
if so how do i adjust this?
Cheers,
-YT-
MultiSync
PostPosted: 11:12 - 08 May 2002    Post subject: Reply with quote
i think black means the bike is running lean?
Guest
PostPosted: 11:31 - 08 May 2002    Post subject: Reply with quote
Black means it is running to rich
The best way to get the right reading is to do a plug chop, get the bike up to temp take the bike to a long strate road ride the bike hard in all gears up to sixth,pull the cluch in at the same time as you hit the kill switch, pull over and take the plug out and check colour if it i is still black u have a problem, if it is a nice light brown then it is fine,and if it is white get it looked at ASAP.
TiN
Pocket Tin
PostPosted: 11:50 - 08 May 2002    Post subject: Reply with quote
is it sooty, or oily?...either way, it's not good...
Tin
McJamweasel
BCF Junkie
PostPosted: 12:45 - 08 May 2002    Post subject: Reply with quote
How long ago is not long?
10 miles, 100, 1000?
if its closer to the latter then thats not too unusual.
Check your air filter as well though - it may need a clean.
TiN
Pocket Tin
PostPosted: 13:51 - 08 May 2002    Post subject: Reply with quote
Does a "dirty" plug need to be cleaned?...if so, how?
Tin
Guest
PostPosted: 13:52 - 08 May 2002    Post subject: Reply with quote
black not too bad, but if its white be very worried
TiN
Pocket Tin
PostPosted: 14:03 - 08 May 2002    Post subject: Reply with quote
oh, that's ok then...mine's only black!...
Tin
The last post was made 24 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 52.4 Kb
