problem starting
nsr_rory
PostPosted: 16:55 - 23 Jan 2007    Post subject: problem starting Reply with quote
hey guys im new to this forum so hi to every1 Smile ok ive got a 2002 nsr and its not starting can anybody help me ? if i pour a little bit of petrol in the spark plug hole and then put the plug in at will fire it also does this if i pu a little bit down the air intake tube through the air filter. when the bike starts its revs all the way up to 10k runs for 2-3 secs then cuts out. any ideas / i really appreciate any help Smile
Marci
PostPosted: 17:14 - 23 Jan 2007    Post subject: Reply with quote
Checked throttle cable isn't snagged either at handlebar end or at top of carb? My Mito used to snag on the ignition barrel if I did full left lock then turned right... and during this process it'd pull the end of the shielding out of the carb's cable guide, causing the shielding to snag on the cable guide effectively holding the throttle wide open.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
nsr_rory
PostPosted: 17:17 - 23 Jan 2007    Post subject: Reply with quote
yeah what i did earlier to try and terminate the problem was i undone the bolts on the top of the carb and took the little barrel with the throttle pin out and then tried to start it again to see if it was that making it rev. i also tried this with the choke cable but it didnt make any difference it still reved right up to about ten k
nsr_rory
PostPosted: 14:40 - 26 Jan 2007    Post subject: Reply with quote
hey guys i think ive pretty much tried everything to get this damn thing going but im not giving up. ive spent a week trying to get it to start. ive booked it on wednesday but i really want it to run so that i can just be motd and i dont have to pay the labour charge. if the ptrol goes in to the air intake part of the carb it will start and the same if it goes into the spark plug hole. does this make it a carb issue ? it also revs at 10k then cuts out when the petrol ive put in runs out.
finpos
PostPosted: 14:49 - 26 Jan 2007    Post subject: Reply with quote
I'm certain that the first thing you checked was that petrol was getting into the carb from the tank.
And after that, that the petrol was getting out of the carb and into the cylinder.
evs at 10k runs for 2-3 secs then cuts out
Could that be because it's running shockingly lean until the petrol you poured in has run out????
finpos.
nsr_rory
PostPosted: 15:00 - 26 Jan 2007    Post subject: Reply with quote
im not sure if got the two screws on the side the mixture crew and the idle screw tightened up then undone 2 and a half ways. is this correct.
alien.46.uk
Have you a Foam air pod, or any kind of Air Pod on instead of the normal box?
I've had to take mine off due to it causing it to die and not idle as the air was too cold and freezing the carb ...
So with the box now getting air from close to the exhaust again its a bit warmer and it has a while to warm up in the bnox a little and is now running fine.
Just a thought ...
Luke.
2007 Kawasaki ZX10R :: 1998 Kawasaki ZX-9R - SOLD
1998 Yamaha FZS600 Fazer - SOLD :: 1994 Aprilia Pegaso 125 - SOLD
nsr_rory
PostPosted: 15:01 - 26 Jan 2007    Post subject: Reply with quote
the airbox and everything on the engine is completely standard any ideas?
Marci
PostPosted: 16:44 - 26 Jan 2007    Post subject: Reply with quote
Blue... Finpos... read this topic to see what's already been tried / suggested... https://www.bikechatforums.com/viewtopic.php?t=105500
For some reason folks wanna start a new topic per day for the same problem recently...
salty21
PostPosted: 18:33 - 26 Jan 2007    Post subject: Reply with quote
you shouldnt tighten the idle screw and undo it 2 and a half turns, the more you tighten it the higher the idle so if you did this you should undo it a couple more turns and try it from there.
The last post was made 19 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.52 Sec - Server Load: 2.99 - MySQL Queries: 13 - Page Size: 71.05 Kb
