Not pulling away quickly at all....
goonernumber1
PostPosted: 20:27 - 29 Jan 2007    Post subject: Not pulling away quickly at all.... Reply with quote
Hi all,
Just had a new clutch cable fitted and I'm not too sure if it has been fitted correctly. It just seems to let me release the clutch lever a lot longer than before to 'catch' and the power kicks in. Ihave to release the clutch lever almost al the way to the end til it kicks in. Does this sound ok or can I tighten it some how?
Cheers for helping an amateur!!!!
geordiecbrblo...
PostPosted: 20:42 - 29 Jan 2007    Post subject: Reply with quote
There will be a way of adjusting it Smile
On my old CBR600 there is a thumb-wheel adjuster next to the lever and if that fails, I can also adjust it where it mounts on the clutch cover.
What bike is it?
quik_d
PostPosted: 20:55 - 29 Jan 2007    Post subject: Reply with quote
Are you sure its not just because the old one was adjusted to its max, and seeing as this is new its on the first stage of its adjustment, so doesn't need to be brought in as far to engage the clutch?
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
goonernumber1
PostPosted: 21:04 - 29 Jan 2007    Post subject: Reply with quote
That makes more sense to be honest as I don't need to bring the lever in nearly as much to engage the clutch.
Should I just leave it for now?
MarkJ
PostPosted: 21:13 - 29 Jan 2007    Post subject: Reply with quote
No just adjust it to how you want. There should be some thumb wheel adjusters on your lever like these:
https://faq.f650.com/FAQs/Photos/ClutchPhotos/ClutchLeverAdjust.jpg
And probably some nuts on top of the clutch
https://www.thumperfaq.com/images/yz400f_clutch_act_04_small.jpg
Which can be used to adjust the biting point.
PostPosted: 21:14 - 29 Jan 2007    Post subject: Reply with quote
based purely on the topic title. Give it more revs son!
The last post was made 19 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.78 - MySQL Queries: 13 - Page Size: 47.07 Kb
