mot question
uncleboob
PostPosted: 15:52 - 31 Jan 2007    Post subject: mot question Reply with quote
Hi there
Will my cg pass its mot if the kickstart return spring doesn't work? The kickstart still works to start the bike and once running you can manually return the lever to its upright position....i guess it might be dangerous if you forgot to lift it up
cheers
jo
CBT (passed), THEORY (passed), Many lessons completed, Bike sold DAS nearly booked!...
My lovely ZZR sold to pay for DAS, bought a VT125cc and crashed it
Currently back to pedal power!..DAS money spend...twisted bike in garage!....CLR 125 bought- on the road again!
PostPosted: 16:17 - 31 Jan 2007    Post subject: Reply with quote
I know of nothing in the MOT manual that states the kickstart has to return.
I definately know you don't have to have one for the MOT so if the tester queries it, remove it for the test.
craigT19
Jolly Green Giant
PostPosted: 16:30 - 31 Jan 2007    Post subject: Reply with quote
no it doesnt have to have a return spring, think that beacuse on some bikes in the past the kickstart has literally spun round and doubled up as a gear lever once the bike had started
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
PostPosted: 16:41 - 31 Jan 2007    Post subject: Reply with quote
Like on my Jawa now you come to mention it. Smile
Odie
PostPosted: 20:19 - 31 Jan 2007    Post subject: Reply with quote
Be carefull, the mot tester might decide that with the kick start dangling down it might be construde as a hazard to your ability to ride the bike safely (leaning into right hand bends etc).
If you can leave it running during the test.
uncleboob
PostPosted: 22:39 - 31 Jan 2007    Post subject: Reply with quote
Cheers guys
i've been sorting out a knackered cg and have everything sorted except this bit, as i'm coming up to my DAS i was going to sell the bike after putting it through the MoT and put the money towards the cost, although its seems to be a cheap fix ( spring is a few pounds) the thought of having to take the whole engine out to fix it is giving me a bit of a headache!!!
I'm going to check it over again this weekend and will put it in for the test next week, i'll let you know how it goes
cheers
jo
uncleboob
PostPosted: 22:40 - 31 Jan 2007    Post subject: Reply with quote
Cheers guys
cheers
jo
Davo
Davo To The Rescue!
PostPosted: 22:43 - 31 Jan 2007    Post subject: Reply with quote
It's not necessary for the MOT tester to start the bike (unless the battery level is too low to test the lights), so charge the battery and take it in.
PostPosted: 02:17 - 01 Feb 2007    Post subject: Reply with quote
Guys, as craigT19 says. I have a bike that doesn't even have a return spring. It came out of the factory like that and is type-approved. Therefore it cannot be an MOT requirement.
Odie
PostPosted: 06:30 - 01 Feb 2007    Post subject: Reply with quote
I know that some machines were never fitted with a return spring on their kick starter (MZ's etc) as it doubled up as the gear lever but the CG did.
Its an easy job to change, just a bit fiddly.
I still feel its a safety issue, take it in for the MOT, if it fails on the kick start take it away and sort the problem, you normaly get 7 days to fix the problem.
Ichy
PostPosted: 06:34 - 01 Feb 2007    Post subject: Reply with quote
Do they not check for emissions or the exhaust for leaks?
Odie
PostPosted: 06:53 - 01 Feb 2007    Post subject: Reply with quote
Good idea would be to take it to the running so that they can hear that it isnt loud or leaking, unfortunatly the CG has no electric start, new ones might have cannot remember.
uncleboob
PostPosted: 09:15 - 01 Feb 2007    Post subject: Reply with quote
....from what i can remember from the book, i think you have to take the engine out to change the spring....if not then i'll get it sorted over the weekend. Do we think that just taking the clutch cover off will provide access
cheers
Jo
PostPosted: 10:34 - 01 Feb 2007    Post subject: Reply with quote
Nah, if it fails the MOT on the kickstart just remove it and take it in for a retest (or just tell the guy that's what you're going to do, or whip out your 11mm spanner and do it there and then).
As I say, there is no requirement for one to be fitted, I've MOTed bikes with no way of starting them other than bumping with no problem. In fact, you can MOT a rolling chassis providing the lights work off the battery.
Once you have the MOT, you can fix the bike at your leisure.
hedjehog
PostPosted: 16:21 - 01 Feb 2007    Post subject: Reply with quote
Stinkwheel wrote:
... you can MOT a rolling chassis providing the lights work off the battery
The headlight on my (88 BRE) CG could not be turned on without the engine running...
I'm fairly sure it was built that way and not a feature of its knackeredness.
1988 CG125 BRE; 2000 GPZ500S D7; VFR 800 FI-X; 1980 CB 250 RSA; 1998 FZS 600 Fazer; 1986 Honda C70 E
Trip
PostPosted: 17:59 - 01 Feb 2007    Post subject: Reply with quote
Could on my '85...
Think it was its knackeredness.
Bike: Yamaha XJ600N Mileage: 28500 Miles Rider Mileage: Many Miles
CBT: PASSED Theory: PASSED Test: PASSED
Past-CG125 Present - Yamaha XJ600N Future - WHO KNOWS?
hedjehog
PostPosted: 09:12 - 02 Feb 2007    Post subject: Reply with quote
Rich_simpkins wrote:
Could on my '85...
Well, bugger me! You live and learn, eh?! Wink
Funny thing is, I noticed about a week ago, the guy I sold it to just sold it on on eBay for more than he bought it off me for. Nice work that man!
CGs are an investment in whatever condition...
Smile
hedjehog
McJamweasel
BCF Junkie
PostPosted: 23:17 - 02 Feb 2007    Post subject: Reply with quote
Yeah, it is. You need to check that the throttle works correctly and you need to check for fuel and exhaust system leaks and exhaust noise.
PostPosted: 02:56 - 03 Feb 2007    Post subject: Reply with quote
No. You can MOT a rolling chassis with no engine in it at all. Used to be a really common thing to do when you were building a chop before the advent of the MSVA test so you could get it registered.
I've twice MOTed bikes, in two different places, that could only be started by bumping them on account of knackered starter motors. They certainly didn't start them when they were tested.
Nothing whatsoever in the manual that states there has to be a working engine. Nothing to my knowledge about testing the functioning or otherwise of the throttle mechanism either.
I stand ready to be corrected. Please quote the paragraph of the testers manual under which this would fail if you do so because that is what I would ask an MOT tester to do should I fail on such a point.
john2
PostPosted: 08:46 - 03 Feb 2007    Post subject: Reply with quote
Put it this way. My scooter passed an MOT with no electic start. Cracked indicator lense and the horn not working Confused Laughing
PostPosted: 17:09 - 03 Feb 2007    Post subject: Reply with quote
Related point, but does anyone know where there is an online copy of the current bike MOT manual.
Loads of copies from 2001, but I know it has changed a lot since then.
uncleboob
PostPosted: 23:37 - 03 Feb 2007    Post subject: I need a rainy day to fix my bike!!! Reply with quote
...well i guess i'll be able to settle the question, just as soon as i take it to the test centre.....today was going to be the day but i looked outside at the clear blue skies and sunshine and decided that getting lost in the warwickshire countryside was a much better use of time!!!
But i will be going next week, checked my documents and it seems that my daily ride is due for a check-up Sad ...here's hoping that it doesn't need too much attention
as an aside, has anyone changed the kickstart retunr spring on their cg125 before? If so can you do it by removing the right hand casing, as opposed to removing the whole engine?
cheers
jo
McJamweasel
BCF Junkie
PostPosted: 00:12 - 04 Feb 2007    Post subject: Reply with quote
Evidently, if there is no fuel or exhaust system then it cannot be checked,
They should of been - at least according to the current regs. From looking at an online copy of the 2001 regs it wasn't a requirement listed there.
The manual does state that the fuel system has to be checked for leaks with the engine running and switched off. The throttle has to be checked with the bars on each lock, to make sure that the cable doesn't pull/stick. Exhaust noise/leakage is also a factor of the test, again the engine needs to be running for this. When I get back into work on tuesday I'll dig out the exact wording and the paragraph numbers.
MattEMulsion
PostPosted: 11:03 - 04 Feb 2007    Post subject: Reply with quote
Well your scooter shouldn't have passed its MOT with the horn not working and maybe should have failed with the cracked indicator lense too (depends on how bad it was). Obviously the guy doing the MOT wasn't up to much and shows a very shoddy state of workmanship and attitude. I just hope for your sake that he didn't 'miss' anything serious that could end up with you having a nasty accident due to his incompetence.
Yamaha YZF-R6
The last post was made 19 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 134.4 Kb
