cleaning bike
smallpaul31
PostPosted: 22:11 - 31 Jan 2007    Post subject: cleaning bike Reply with quote
hello all
i pick up me 1st bike on saturday, kawasaki zx600r, now wot is the best way to wash and dry the bike after a ride in this weather with the salt on the roads. may sund daft to most ppl but bein new to biking and all that Surprised
av heard lots bout getting mug off and spray that dispers the water
Passed CBT 23/10/06
Passed theory on 14/11/06
Passed pratical test 24/01/07
angryjonny
PostPosted: 23:02 - 31 Jan 2007    Post subject: Reply with quote
Muck-off or similar should do a good job.
I understand that rubbing WD40 into the exposed bits is supposed to protect from corrosion too - obviously not any bits where grip is essential (don't get any on the tyres or brake disks for example) and not on anything that gets hot, like the exhaust.
Whosthedaddy
PostPosted: 23:06 - 31 Jan 2007    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=97576&highlight=cleaning
Ariel Badger
PostPosted: 00:41 - 01 Feb 2007    Post subject: Reply with quote
Do not clean it, protect it.
Spray it with WD40 if you like or if you are a cheap skate like me use cheap furniture polish.
Clean it in the spring.
JonB
Afraid of Mileage
PostPosted: 01:46 - 01 Feb 2007    Post subject: Reply with quote
Use FS365 to protect it from the salt, like ariel said, wash it in the Spring.
krebsy
PostPosted: 11:30 - 01 Feb 2007    Post subject: Reply with quote
Don't spray WD40 onto the engine or Exhaust as it bakes on and is a bugger to shift.
Get a squirty bottle of AutoGlym shampoo, some degreaser, a few sponges, some furniture polish (with Beeswax in it) and some FS365.
Wash down with warm water and scrub off any stubborn oily muck with the degreaser. Coat the whole bike in shampoo, rub in with a clean sponge then rinse down with warm water and another sponge to get the clean water into all the gaps. Dry her off with a towel then start her up and let the engine/exhaust heat dry the rest.
Check the bike over for any signs of corrosion or damage and once dry, spray fs365 into all the nooks and crannies and use the polish everywere else (bar the seat).
then check the fluid levels, top up as required (brakes/oil etc.) and clean and re-grease the chain. don't put too much oil/grease on the chain otherwise it'll fling off all over your nice clean swingarm/wheel/tyre etc. (as mine did this week.. Sad .
Take her out for a spin to shake the cobwebs off and to dry anywhere that's been missed. Smile
K.
1280 x 1024.
PostPosted: 11:49 - 01 Feb 2007    Post subject: Reply with quote
krebsy wrote:
~stuff~
~more stuff~
~other stuff~
K.
Except by the time you've done all that, it will be dark.
My weekends away, I leave after work on Friday and don't get back 'till after dark on the Sunday. As such I don't have time to clean my bikes. I let them get covered in oil and grease and give them an occasional scoosh over with F365. Doesn't look pretty but they still work.
niceguyeduard...
PostPosted: 13:25 - 01 Feb 2007    Post subject: Reply with quote
K, Good advice man Thumbs Up , some of the best instructions on t site. No more cleaning topics now, all should be refered to your post.
imabikr
PostPosted: 14:05 - 01 Feb 2007    Post subject: Reply with quote
I also heard that the best thing to do is use loads of cold water first rather than hot, as hot water just makes the salt corrode more.
My general think is to get home & douse it with the hose for long enough to get it completely rinsed down. Dry it off by running the engine, wipe the other bits down with a microfibre cloth to get the water beads off.
Then smother it in lots & lots of FS365!
Seems to work for me...
(oh, if I’ve got a spare couple of hours every few days I’ll hose it, autoglym spray cleaner thingy, autoglym shampoo, dry then FS365)
krebsy
PostPosted: 16:43 - 01 Feb 2007    Post subject: Reply with quote
Well, bar dropping it in the mud afterwards it only took an hour to get the bike clean. Smile I start off with warm water as it's better for losening up the grease and crud and to be honest, unless you are leaving it on a bath of hot water for a while, then the salt will be off before it can really start to react...
K.
1280 x 1024.
The last post was made 19 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 65.3 Kb
