Views on Ducati 996
Keir
PostPosted: 10:47 - 02 Feb 2007    Post subject: Views on Ducati 996 Reply with quote
As it coming up to summer ish, Im feeling the need for a new 'first' bike. The Gsxr 600 has been good but im fancying something different and im thinking ducati 996 bp. Seen a few about for around 5k with 5000 miles on the clock, 50mm termis and loads of carbon trick bits.
Anyone owned one and got a mini review on them?
Current : '08 Yamaha FZ1s
Zimbo
PostPosted: 11:08 - 02 Feb 2007    Post subject: Reply with quote
A very fast and capable bike, surprisingly comfortable over long distances at speed, not brilliant in town though, too much weight on your wrists and not much steering lock.
No need to spend £5K though, there's good ones around for £3K and aren't going to depreciate much from that. For £5K you'll get a good 998 with the testastretta engine.
As always, find out if it's been properly serviced and had belts changed and valve clearances checked recently. The only other known fault, apart from occasional reg/rec failures, is the well known chrome flaking off rockers syndrome, new ones cost around £100.
Have a look on https://www.ducatisportingclub.com/forumdisplay.php?f=85 for loads more info from owners.
JonB
Afraid of Mileage
PostPosted: 11:11 - 02 Feb 2007    Post subject: Reply with quote
Absolutely lovely bike, a mate off SWB had one and he was like a rocket on it and with those lovely termis, it is just a dream bike. Make sure you buy it in red though! Very Happy
craigs23
Mr Muscle
PostPosted: 18:00 - 02 Feb 2007    Post subject: Reply with quote
Awesome piece of machinery, if you can live/afford one. Much better than Ducatis of late, in my eye anyway.
PostPosted: 18:12 - 02 Feb 2007    Post subject: Reply with quote
If you're going for it, I doubt it'll be much if at all faster than your GSXR.
Should be easier to go fast without trying so much however - but the riding position doesn't match the lazier engine, as mentioned.
DucatiEVO
PostPosted: 18:54 - 02 Feb 2007    Post subject: Reply with quote
If you can stretch to the 998 testa engine it's worth it, as there is a big difference in how the bike revs/rides. Thumbs Up
It's more iconic than a Gixxer will ever be.... Wink
aKa: Ducky
crm250
PostPosted: 19:12 - 02 Feb 2007    Post subject: Reply with quote
Evo's right. and plump for the S model as a minimum too for the deep sump motor. Doesnt sound alot but the quality with a few other components shows between the model range.
A 996 is a fine bike, however its not the strongest motor in the world. its a bit too stressed as a track bike but as a road bike would be fine. regular oil changes are a must, and allow it nearly a minuite before blipping the throttle when starting from cold after a few days parking to allow the oil to get up there (rockers are £90 retail each and you have 8)
the 996 is smoother than the earlier 916 it replaced and revs a bit harder too, but sounds quite different - actually no its doesnt, it the 916 that sounds different to all the others, it sounds less even and lumpier.
Try one before you buy as V2's are not for everyone, if you are used to thrashing the GSXR up at the top a twin will not impress you as there is bugger all up top after 9k its all from 3 - 8k
as mentioned in other posts i sold a blade for my old 916 and it took me 3 months to even start to like it, suddenly it all became clear and i saw the light. Very Happy
quik_d
PostPosted: 20:01 - 02 Feb 2007    Post subject: Reply with quote
From a non technical point of view, my favourite looking bike. I even have a little model of it on my monitor at work Laughing
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
Keir
PostPosted: 20:09 - 02 Feb 2007    Post subject: Reply with quote
thanks so far, it been useful. I do like to thrash the nuts off my bike so maybe a low reving fragile bike isnt the best idea. its just the looks are astounding......
Zimbo
PostPosted: 13:32 - 03 Feb 2007    Post subject: Reply with quote
Oh you can still thrash it, it's just that taking it round to the redline in every gear doesn't work and you need to short shift and drive using the superior torque characteristics, a different riding style that you need to adapt to.
The last post was made 19 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 65.57 Kb
