2nd gear slipping
KevlarPants
PostPosted: 01:00 - 03 Feb 2007    Post subject: 2nd gear slipping Reply with quote
'94 zzr 600, 35k miles.
When I shift up into second and put the power on the gear slips, like it hasn't quite engaged. The bike lurches, once or twice until the gear catches properly. At least that is the best way I can describe it. Once it has engaged/caught it is ok then. Although I don't tend to stay long in second as this lurching is not nice.
The bike has been doing this for the last year, but recently it has almost caught me out, once nearly high siding me (off a roundabout, wasn't fun).
So I spoke to a mechanic and he said that as it is only one gear it is unlikely to be the clutch, i.e. second gear cog is knackered.
Short version, thats going to be expensive to sort out.
He laid out three options.
About ten hours labour to get the engine out and 'split' it, and see whats what in the gearbox and go from there.
Option two, get the engine out and put new engine in. This would probably work out a bit cheaper.
Third option, flog it and get another bike, probably the cheapest option.
So, I'm just looking for some opinions here I guess. The bike cost me 1500. With the way the numbers are stacking up trading in is the cheapest option.
However, I could probably live with it for now and just stay the hell away from 2nd as much as possible.
Thing is I quite like the bike. Its my first 'big' bike and it goes like stink off a stink shovel.
Any thoughts?
instigator
PostPosted: 01:15 - 03 Feb 2007    Post subject: Reply with quote
I would look for a replacement engine and THEN sell it. ZZR600 is apparently known for it's gearbox problems. It seemed like the perfect bike for me until I heard about that. Mad
It may be your first big bike but that is no reason to hang onto it. Go forth and try something else. Thumbs Up
0ddball
PostPosted: 01:44 - 03 Feb 2007    Post subject: Reply with quote
Bear in mind that because it's a common problem, any replacement engine you get might have the same problem. In fact it could be the reason the donor bike was broken for parts.
chris1-4-7
PostPosted: 17:26 - 03 Feb 2007    Post subject: Reply with quote
My old man has had a zzr in the past. Kept it for over 2 and a half years. Never had any transmission problems. Spannermonkey has also put forth a good comment. How it may have been the reason in the first place. Wink
Chris(Brum)
bunglehaze
PostPosted: 16:52 - 05 Feb 2007    Post subject: Reply with quote
Im in the same predicament and to be honest I love the ZZR but my logical thinking is telling me to sell it for peanuts and just get a different bike, apparently doing the replacement is not that difficult but from my experience so far the hard part is finding the replacement parts which on your bike (same year as mine) would be:
Drum : 13239-1176
Forks: 13140-1154
13140-1191
Top output dog: 13260-1478
2nd output dog: 13260-1379
As some have said it may be that any 2nd hand part you buy would be just as bad so you need to check over the drum for the damage before buying (or get the breaker to email over a photo if mail order) I have been offered replacement engines which in my opinion are just not viable for the price people want for them (offered one APPARENTLY 4000 miles on a 2000 plate - slightly suspicious as weekend warriors who keep miles low dont usually buy sport/tourers price=£300 on a bike that cost me £900 hardly seems worth it)
So right now its a toss up between replacing and tidying up the bike then selling, selling as is and having to spend a fair bit more on a replacement or repairing the transmission, respraying and keeping it for another season.
In my case I have dropped it so there are a fair few scratches that make it look untidy which is making me lean more towards getting rid of it as is and buying a zx6r instead Smile
cheers
leigh Very Happy
https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H
Odie
PostPosted: 17:08 - 05 Feb 2007    Post subject: Reply with quote
Its not the drum (selector drum) that goes its normaly the "dog teeth" that slide across to engage with the next gear in the box, These engage with the next gear to transmit the drive to the next cog / gear.
If some-one has been slamming it into that gear they can go, also if some-one likes to give a bike some stick in a certain gear to much that can cause it, also if they not been case hardened properly during manufacture they can go and some gear boxs are just shit!
Had to do a complete box on zzr1100 that had a second gear problem so it could just be down to a bad design by kawasaki!
Selector forks can go, if they go you normal cannot get a gear at all. (selector forks transmit the movement from the selector drum to the gears)
bearwood.beckham
PostPosted: 17:48 - 05 Feb 2007    Post subject: Reply with quote
Could it be the clutch? Has it been replaced in the time you've had it or by a previous owner. 35k is alot on a clutch and gearbox.
Odie
PostPosted: 17:51 - 05 Feb 2007    Post subject: Reply with quote
Why would it be the clutch?
If it were the clutch it would do it in every gear!
veeeffarr
PostPosted: 18:01 - 05 Feb 2007    Post subject: Reply with quote
This is what puts me off of Thundercats and ZZR's although they're perfect for me Sad
bearwood.beckham
PostPosted: 18:21 - 05 Feb 2007    Post subject: Reply with quote
Not necessarily, I had a mate with a high mileage CBR600F (I think it was) and his was slipping in first gear. He took it to a garage and they replaced the clutch, and he's not had a single problem since.
Odie
PostPosted: 19:03 - 05 Feb 2007    Post subject: Reply with quote
Only slipping in first gear?
Dont disbeileve you but i have been working on bikes for the last 20 + years and thats the first time i have heard of a bike slipping its clutch in 1st gear and no other!
bunglehaze
PostPosted: 19:12 - 05 Feb 2007    Post subject: Reply with quote
From what I have read it seems the selector drum is a problem with these, the apex of the curves flattens off which is the initial cause of any wear on the other components. The reason for the full parts list I gave above is because thats generally what needs replacing.
Oh and with these it is not wear on the teeth usually it is on the sides of the dogs.
regards
leigh Very Happy
bearwood.beckham
PostPosted: 19:13 - 05 Feb 2007    Post subject: Reply with quote
I'm just going on what he's told me. Thumbs Up
KevlarPants
PostPosted: 20:04 - 07 Feb 2007    Post subject: Reply with quote
Thanks for the replies guys.
My garage are going to have a look on monday, and we'll take it from there.
While the idea of a new(er) bike is attractive, I might have to live with this for a bit.
cheers
The last post was made 19 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 85.49 Kb
