how to test which wire goes where on the coil Help!
quik_d
PostPosted: 15:19 - 03 Feb 2007    Post subject: how to test which wire goes where on the coil Help! Reply with quote
I just changed the spark plugs, and in order to get to them i had to disconnect and move the coils. I noted which set of wires went on which coil, but not which wire went on which terminal on the coils.
How can i check this?
cheers
Dean
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
crazymotorbik...
PostPosted: 15:30 - 03 Feb 2007    Post subject: Reply with quote
Hey,
What colored wires have you got?
On my kawasaki Reds go to the +ve terminal (Self explanatory) and then i have a green -ve for the left side and a black -ve the other. There should be +ve and -ve symbols marked on the coils.
The +ve wire should be the same feed for each coil, well it was on my kawasaki. So if you test the continuity between the wires, the ones that are connected should be +ve.
Cheers,
Shaun.
syl
PostPosted: 15:52 - 03 Feb 2007    Post subject: Reply with quote
No matter what type you have, they just stick out of the bottom, to allow for removal.
https://www.addenbrookes.org.uk/resources/images/fpc/coils2_250_301202.jpg
https://www.addenbrookes.org.uk/resources/images/fpc/coil_place_250_301202.jpg
Oh, you meant something Embarassed else
Current bike: Kawasaki Z750S
quik_d
PostPosted: 17:12 - 03 Feb 2007    Post subject: Reply with quote
Oh, you meant something else
yes i did, urgh!
I've sorted it now, i was being a numpty!
Cheers
The last post was made 19 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 39.78 Kb
