renault meganes
lee8040
PostPosted: 15:26 - 03 Feb 2007    Post subject: renault meganes Reply with quote
does anyone own a renault megane on here ?
Whosthedaddy
PostPosted: 15:34 - 03 Feb 2007    Post subject: Reply with quote
I hired a 04 one for a week, nice comfy well equiped car.
WishayKillie
PostPosted: 16:46 - 03 Feb 2007    Post subject: Reply with quote
My GF's got a 54 plate 1.4. It's a good wee car, only recently though the coils for the plugs have started to ge one by one Sad
PostPosted: 16:47 - 03 Feb 2007    Post subject: Reply with quote
Unfortunatly I do, a '98 1.4i Liberte.
Its really shit, doesn't like the rain, doesn't like being revved, there are several different oil leaks on the engine that smoke away nicely as you're driving, rear suspension makes dodgy sounding thuds when going over bumps, I 've broken various other parts, its generally crap. Oh, and its French!! Shocked
A good car, if you want an unreliable shitheap. Thumbs Up
Wanna buy one then?
0ddball
PostPosted: 16:59 - 03 Feb 2007    Post subject: Reply with quote
It's not too bad as French cars go. But then that's not really much of a recomendation.
owdamer
PostPosted: 18:53 - 03 Feb 2007    Post subject: Reply with quote
My brother has an R reg one, and Theres an 05 plate one parks opposite my house.
lee8040
PostPosted: 19:38 - 03 Feb 2007    Post subject: Reply with quote
i just needed to no where the plug for the radiator is at the bottom theres a metal plate so it cant be down there and theres nothing on the side to drain the water
binge
Emo Kiddy
PostPosted: 20:09 - 03 Feb 2007    Post subject: Reply with quote
Drain Plug?
Do you want to bleed the system or Empty it?
If you want to empty it, Just take off the lowest pipe in the system.
<|ben|>
lee8040
PostPosted: 09:18 - 05 Feb 2007    Post subject: Reply with quote
i was told if you do that tho you need to bleed the system.
shouldnt there be a drain plug? it cant be on the bottom as that will mean you need to remove aload of metal paneling
10 pence Short
PostPosted: 10:10 - 05 Feb 2007    Post subject: Reply with quote
You would need to Bleed it when refilling, if you drain it by either method. Usually Renaults have fairly visible bleed points, Screw in plugs in the top hose, heater pipes and radiator top, depending on the model year. Presuming you're adding anti-freeze this time of year? Just open a bleed point and add an anti-freeze/water mix whilst the old coolant is coming out, until it's all in the system.
I haven't had a cont all day, drinkstable.
Annabella
Like a person, only smaller
PostPosted: 10:48 - 05 Feb 2007    Post subject: Reply with quote
Shocked
And you told me I was imagining those noises!
I did honestly think I had made part of your car fall off.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
The last post was made 19 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 67.36 Kb
