XS650 flat tracker project - tank ideas?
400bandit
PostPosted: 23:13 - 04 Feb 2007    Post subject: XS650 flat tracker project - tank ideas? Reply with quote
Hello all. For some time now me and my dad have had a XS650 sitting in the garage with the intention of turning it into a mean street/flat tracker. Well now the ball is finally about to start rolling. It's going to have some extensive modifications to it such as; bored out to 840cc, head ported and polished, a 90 degree re-phase and then some... We are ok for all the parts for that side of things but so far the biggest problem is sourcing the right tank. The original is a touch too big and not too pretty.
We really want one like the one on this XS650 https://www.650motorcycles.com/ScottPickett.html
I have got in contact with the man but the only thing is he uses a fiber glass tank. I'm pretty sure that’s not legal over here for starters and it seems a touch unsafe too. So here is the big question, can anyone think of a similar tank that is not fiber glass? I was thinking along the lines of classic 60's trials bikes? It's got to be small and keep that nice shape.
I'll follow up this project with a full write up when it is complete but that will not be for some time yet.
I will be grateful of any information that is received
Joe
[/img]
Bezzer
PostPosted: 23:19 - 04 Feb 2007    Post subject: Reply with quote
If you're spending that much effort on engine mods you may as well spend a bit of money on the cosmetics as well so everything is spot on.
Check these out and drool Shocked
https://www.thetankshop.com/
BTW fibreglass isn't illegal aftermarket wise and for some old bikes that used to have them. They wouldn't pass type approval for a new bike, think they were banned in the middle to late 60s from being approved after some poor buggers were burnt to death when they split in accidents. Not even worth considering if you did find one.
400bandit
PostPosted: 23:29 - 04 Feb 2007    Post subject: Reply with quote
Thanks for the link, have just sent them an e-mail Thumbs Up
PostPosted: 23:36 - 04 Feb 2007    Post subject: Reply with quote
It's like a small, flattish teardrop one you're after then. The one in that picture is like a tank off a custom-type bike but mounted flat instead of at an angle.
Off the top of my head, the XV125 Virago.
a CA125 Rebel
or the good old SR125
400bandit
PostPosted: 11:05 - 05 Feb 2007    Post subject: Reply with quote
Thanks for the ideas guys, keep em' coming. I had thought about the yamaha 125 before but it's not quite right, I like the little bit of curve in the tank on the flat tracker.
Many thanks again, Joe
sickpup
Old Timer
PostPosted: 11:09 - 05 Feb 2007    Post subject: Reply with quote
That looks like a Steve Stortz tank.
Fibre glass and plastic tanks are legal these days. Triumph and Ducati both use them.
400bandit
PostPosted: 13:09 - 05 Feb 2007    Post subject: Reply with quote
Are they safe though? The thought of one cracking open is too pleasant but if they were safe then that would make things a whole lot easier.
Joe
yambabe
PostPosted: 13:37 - 05 Feb 2007    Post subject: Reply with quote
Which XS650 do you have, is it a standard or a US Custom "Special?"
Cos I reckon the tank off a custom special is what you're looking for, the standard XS tank is bigger and squarer.
https://www.650motorcycles.com/NeilPetrie1.jpg
400bandit
PostPosted: 13:41 - 05 Feb 2007    Post subject: Reply with quote
Yeah it's a special, if it comes to it we'll probably stick with it, it's just I love that tank on the other XS...
Joe
PostPosted: 13:46 - 05 Feb 2007    Post subject: Reply with quote
Joe
The Triumph Daytona 955i has a plastic tank iirc, and it was perfectly safe. Aprilia Falco's have plastic tanks too iirc.
Loads of bikes which ride around safely all the time happen to have plastic tanks.
yambabe
PostPosted: 13:51 - 05 Feb 2007    Post subject: Reply with quote
Have a look at Virago tanks definitely, especially the early XV750/700 ones. They are similar to the XS but a bit smaller and more "pointy". IIRC the fittings aren't too difficult to bodge either.
sickpup
Old Timer
PostPosted: 14:41 - 05 Feb 2007    Post subject: Reply with quote
Joe
I could beat you to death with one and it wouldn't crack. That strong enough?
yambabe
PostPosted: 20:29 - 05 Feb 2007    Post subject: Reply with quote
Another tank that might do the job and should fit on fairly easily is one off a DT175, an early one with a screw-on cap. It has the same mountings as the XS650 and you might well be able to pick one up in a breakers.
https://members.sparedollar.com/fastpart/tankdt175al.jpg
That one is a bit beaten-up but you get the general idea?
Also a 70s TS250 (Suzuki) might be about the right shape and size but not sure how easy it would be to adapt it to fit on.
https://photos.motorcycle-usa.com/Web/suzukits250port.jpg
yambabe
PostPosted: 20:33 - 05 Feb 2007    Post subject: Reply with quote
Back again! Have you got a kit for the 840 bore-out or are you going to do it yourselves?
Mate of Himself did one a few years ago using Ducati/Corillo con rods and CX650 turbo pistons. They bored the liner to fit and ended up with around 900cc in the end. Apparently they could rev it to about 9k without any damage cos the pistons had no weight to them at all!
ZRX61
Victor Meldrew
PostPosted: 21:21 - 05 Feb 2007    Post subject: Reply with quote
Do a web search for Shell Thuett...
https://www.ahrma.org/machines/scott_yam.htm
400bandit
PostPosted: 18:07 - 08 Feb 2007    Post subject: Reply with quote
Once again thanks for all the help guys. As for the bore kit, we have one sourced but it's coming from Australia! Sounds like a lot of effort but the reason for this is he has designed the pistons for the XS650 head and have a compression ratio of 12:1! It's not going to be a cheap project, not by a long way but it is something that my dad has wanted to do for a long time. Will keep everyone posted with progress.
Joe
The last post was made 19 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 91.74 Kb
