hot grips
lee8040
PostPosted: 09:19 - 05 Feb 2007    Post subject: hot grips Reply with quote
does anyone use these to keep there hands warm?
do they get very warm, enough not to get frost bite ?
thanks
Mooncatt
PostPosted: 10:51 - 05 Feb 2007    Post subject: Reply with quote
i have them on my 400 (already on when i bought the bike) i have tried them but they get bloody hot so i end up just not using them
current bike...CBR400RR
"you always need more chicken"
extreme3d
PostPosted: 11:12 - 05 Feb 2007    Post subject: Reply with quote
Sure you had the oxford ones then Question. They come with a dial so it's possible to adjust the temperature. Sounds like you had some cheap heated grips fitted which only had on or off.
The latest Hot Grips comes with a new style button control panel and is what I have fitted to my bike. Summer gloves don't provide enough insulation and you will find them a tad hot to hold when set to level 4 . I find setting 2 or 3 works just right. Personally I prefer to wear winter gloves and set it to max. It soon warms up the padding inside the gloves and your hands are warm as anything, including the thumbs which are usually sticking down in the breeze.
https://i10.photobucket.com/albums/a129/extreme3d51/grips002.jpg
Mooncatt
PostPosted: 11:16 - 05 Feb 2007    Post subject: Reply with quote
lmao no mine aint like that its just like you say "on/off" and they do get too bloody hot. the ones you have a pic of look to be much more sensible for those cold winters
m0l0t0v
PostPosted: 13:04 - 05 Feb 2007    Post subject: Reply with quote
Mine are Oxford hot grips, the ones you can take on and off easily but don't have a dial. They only have on/off and don't get very warm sometimes... Confused
M1ke
Ped Boi
PostPosted: 13:20 - 05 Feb 2007    Post subject: Reply with quote
I have exactly those and mine gave me burn blisters on a 200 mile trip! i swear they get hotter the faster you go as well, its as if the extra charge that the battery is getting is going straight to the grips.
m0l0t0v
PostPosted: 13:24 - 05 Feb 2007    Post subject: Reply with quote
Wanna swap? Mine seem to be terrible. Sometimes they'll get really warm and keep my hands warm but like today, they don't do much. Had to stay on the bike after I parked up for 3 minutes to warm my hands after tkaing my gloves off Confused
Ichy
PostPosted: 14:30 - 05 Feb 2007    Post subject: Reply with quote
I've got the new hotgrips and they work really well. Think the other ones might be called hot hands?
Stu_666
PostPosted: 21:37 - 05 Feb 2007    Post subject: Reply with quote
Yeah I've got the same ones as extreme3d (above). Apart from the 60% light not working (which I will take back in a few days time to get the switch box changed), they're not bad. Normally the first or third heating setting is good.
Due tend to find though that they warm more the palm of the hand than the fingers. Having said that they're not bad for the price I suppose (paid about £30 for mine) compared with a few factory fitted optional extra ones which can cost £140.
CR
PostPosted: 17:51 - 06 Feb 2007    Post subject: Reply with quote
What are they like with draining the battery? Do they drain it at all? or that just a myth.
_______________
Freedom of Information Act
https://www.myspace.com/darkeneddream
mark83
PostPosted: 18:32 - 06 Feb 2007    Post subject: Reply with quote
Good point....
I would also like to know!
Kawasaki ER6n -> Honda CBR600RR -> Honda VTR 1000 -> Moto Guzzi Norge 1200
Buy my Mercedes 350 Sport AMG Evo
DynaMight
PostPosted: 18:37 - 06 Feb 2007    Post subject: Reply with quote
As long as you don't leave them on while the bike isn't started you'll be fine, soon as the engine is running it should be fine.
As standard they will connect right upto the battery so it is possible to switch them on without the ignition on thus draining the battery, you can connect it to a relay or somewhere that has a live feed after the ignition and it wont turn on unless the ignition is on.
Ichy
PostPosted: 19:21 - 06 Feb 2007    Post subject: Reply with quote
The new oxford grips are supposed to have a sensor in the switch box and will automatically switch off if the battery level gets low. Its says that there should be enough power to start the bike but I haven't tried it.
Simple
PostPosted: 13:09 - 07 Feb 2007    Post subject: Reply with quote
I have oxford wrap arounds, okay on their own, dont keep hands warm in these temperatures,
I added a pair of bar muffs,
rarely have the grip son now, the protection from the wind blast helps alot, not to mention keeps the road crap and moisture off my summer gloves.
Monday at 6am for the 80mile trip to uni I had both grips and muffs and my hands were cold...
get some and find out, good grips are £15-20 from a bike show
or tech 7 (via mps) were doing a buy hot grips and muffs for £30
MY R&G heated grips were better imo than oxford, better priced too, daytona seem to be the best with a dial.
Insta - FemFeral
Simple
PostPosted: 13:11 - 07 Feb 2007    Post subject: Reply with quote
mark83 wrote:
Good point....
I don't turn mine on until I'm rolling, GPZ battery fails to start the bike if it's been sat in the cold for a day or so, the hot grips dont seem to make a difference, though obviously if you leave them on without the engine running they will drain the battery.
I think the battery in the GPZ is origional... certainly looks like it's from '98 Confused
Insta - FemFeral
Simple
PostPosted: 13:13 - 07 Feb 2007    Post subject: Reply with quote
mine get uber painful hot after I've gone up the revs and the needle is slowly coming down.
Happens every time, so If I get colder I know what to do.
Insta - FemFeral
lee8040
PostPosted: 08:30 - 04 Apr 2007    Post subject: Reply with quote
how long do the new 2007 oxford hot hands take to warm up ?
djneu-trix
PostPosted: 09:28 - 04 Apr 2007    Post subject: Reply with quote
i got a set of wraparound (take um off easy) oxford hotgrips! no setting just ON!
they get frigging hot VERY quickly!!!!! and that saying something comming from me, as i got asbestos hand from being a chef!
i expect the 2006 versions against the 2007 versions are really NOT any different! it all depends on how well charged your battery is at the end of the day!!! well it does on my bike!!!!
pg
lee8040
PostPosted: 09:52 - 04 Apr 2007    Post subject: Reply with quote
the 2007 ones have different temp settings 4 in total
lee8040
PostPosted: 09:29 - 18 Sep 2007    Post subject: Reply with quote
i find that when i have mine on and am sitting in traffic or braking it turns off. i have to be riding with the revs up to get it to stay on then when i approach traffic and hit the brakes they switch off.
anyone notice this?
Finglonga
PostPosted: 13:28 - 18 Sep 2007    Post subject: Reply with quote
Got them fitted as standard to my BMW and they have 3 heat settings, Off, Nice and warm and Core of the Sun! I wear summer gloves all year round as they are so good. Wouldn't be without them now. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
veeeffarr
PostPosted: 17:29 - 18 Sep 2007    Post subject: Reply with quote
I plan to get some soon
I remember on the deauville I had they used to burn the fuck out of your hands when you throttled off... haha.
T
Chriss
PostPosted: 18:33 - 18 Sep 2007    Post subject: Reply with quote
Hi, can vouch for this working, did it on the SV though took over an hour before they switched off, though this would probably vary a bit bike to bike, so I'd say the power consumption is low.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Swipe
PostPosted: 19:54 - 18 Sep 2007    Post subject: Reply with quote
My heated grips = hot palms but cold fingers
FS1E (73) -> RD125LC (86) -> Honda Bros 650 (88)
Honda Hawk GT Forum - A forum dedicated to the Hawk GT/Bros/RC31
www.staffordshireriders.co.uk
lee8040
PostPosted: 14:16 - 27 Sep 2007    Post subject: Reply with quote
Do they work when you have your lights and indicators on?
mine just turn off
The last post was made 19 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 129.74 Kb
