slight engine power loss
befdelta7
PostPosted: 22:19 - 05 Feb 2007    Post subject: slight engine power loss Reply with quote
cagiva supercity 125cc 1992
hi,
when i was on my way home from boxhill yesterday, doing about 60mph in 4th/5th (cant remember)
accelerating through the rev range in what ever gear it was the bike felt sluggish was slow to get throught the rev range and didnt sound as deep(induction noise) as it usually does, it done this in every gear when accelerating for a few miles and then all of a sudden traveling through the rev rang and gears the induction noise got louder(as usual) like flicking a switch and the power was back too!
what i though it was, was the power valve suddenly opening but the valve was fully operational and still is.
anyone else have any ideas what caused this, clutch slip, dirty carb, engine too hot??
cheers for your advice Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
Resurrection
Ballast Boy
PostPosted: 23:30 - 05 Feb 2007    Post subject: Reply with quote
You checked your spark plug lately?
May be worth giving it a clean or investing in a new one!
Res
ZX9r
befdelta7
PostPosted: 09:08 - 06 Feb 2007    Post subject: Reply with quote
yer the spark plug is only 3 weeks old.
is it worth running my bike on BP ultimate 97 octane? would that help with smoother running and better throttle responce?
PostPosted: 10:19 - 06 Feb 2007    Post subject: Reply with quote
Not usually, no.
befdelta7
PostPosted: 11:50 - 06 Feb 2007    Post subject: Reply with quote
my mate has a highly tuned scooter and says it runs better on BP ulitmate than standard petrol Rolling Eyes
could that be because his compression is a lot higher than standard? i herd than when fitting a high compression head you need to run the engine on that stuff.
i was thinking on trying it in my bike but its a lot more expensive than normal petrol, and could possibly be a waste of money.
whats your input to trying it?? Thumbs Up
also whats the pros and cons??
cheers,
james Thumbs Up Thumbs Up
BigChris
PostPosted: 18:54 - 06 Feb 2007    Post subject: Reply with quote
the ron rating for petrol doesnt give you any more bang to your squirt of juice. It just stops detonation.
Therefore your friend is talking shite.
Before you go all mad, check air filters and oil levels.
That usually solves the trick.
Living with Schizophrenia is like being with your best friend 24 hours a day. Enjoy it while you can!
PostPosted: 19:26 - 06 Feb 2007    Post subject: Reply with quote
cheers,
As BigChris said the higher-octane fuel provides better resistance to detonation.
He might well have found his bike runs better on that fuel than the previous but he might have found equally good results switching to another premium-grade fuel. The octane-rating wouldn't affect the power delivery.
befdelta7
PostPosted: 20:23 - 06 Feb 2007    Post subject: Reply with quote
ok thanx for that info Thumbs Up !!
can anyone reccomend any adjustments to get smoother running and better throttle responses E.G anything that can be adjusted/set diffrently to standard that can be done at home and have a benefit.
** Embarassed sounds like a divy question, as i cant really explain what i mean Embarassed **
befdelta7
Resurrection
Ballast Boy
PostPosted: 21:59 - 06 Feb 2007    Post subject: Reply with quote
Im not quite sure what you mean but
Try not snapping it open!
At the end of the day its a 125 its not gonna blast like an R1 is it.
Is your cable ok? what i mean is, is it stretched or frayed?
Might have got the wrong end of the stick but may be worth a check!
Res
ZX9r
befdelta7
PostPosted: 23:19 - 06 Feb 2007    Post subject: Reply with quote
yer the cables fine, when i pull back the throttle and look up the carb mouth the slide opens fully, and the throttle itself is very free moving and snaps back to closed when released.
what i ment was how to get better, smoother engine running and a little bit more umph, a bit more get up and go kind of thing Wink
The last post was made 19 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 72.55 Kb
