NC30 Cutouts (with video)
Letum
PostPosted: 12:22 - 07 Feb 2007    Post subject: NC30 Cutouts (with video) Reply with quote
Hello!
My NC30 cuts out, usually after any acceleration, revving or engine breaking, although it ticks over fine.
Here's a YouTube video to illustrate part of the problem.
The first time I rev the bike in the video I do so slowly and it revs all the way.
At 10 seconds into the video I snap the throttle open and keep it fully open until the cut-out at the end.
https://www.youtube.com/watch?v=8jj8AIFZ7S0
Any help or speculation would be appreciated!
Thanks! Very Happy
h00dwink
PostPosted: 12:38 - 07 Feb 2007    Post subject: Reply with quote
are you turning the bike off?
that doesn't make much sense otherwise
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
Letum
PostPosted: 14:24 - 07 Feb 2007    Post subject: Reply with quote
No, it just cuts out after I quickly open the throttle. If I slowly open the throttle it does not cut out.
finpos
PostPosted: 14:49 - 07 Feb 2007    Post subject: Reply with quote
How long between you snapping the throttle open and it cutting out?
Does it cut out dead or does it splutter out?
Do you know if your bike has a throttle position sensor (look at the wiring diagram)
finpos.
Mooncatt
PostPosted: 15:46 - 07 Feb 2007    Post subject: Reply with quote
my mate had a similar problem on his aprilia 125 extrema could be a carb problem maybe??? thats what his turned out to be anyway
current bike...CBR400RR
"you always need more chicken"
Letum
PostPosted: 16:50 - 07 Feb 2007    Post subject: Reply with quote
finpos.
See the video. I snap the throttle open and it revs to ~6 and then back down to idle. I continue to keep the throttle open and it revs back up to 6 again. It repeats this sevral times and then suddenly cuts out.
No, there is no throttle position sensor.
finpos
PostPosted: 17:09 - 07 Feb 2007    Post subject: Reply with quote
Maybe I can't see the video Wink
Best guess would be that it's running lean and/or it's got a restricted fuel supply to the carbs (the second could be causeing the first).
Try running the bike off an alternate fuel supply, aka a funnel full of petrol jammed in the fuel line. Make sure any vaccum tubes (e.g. the fuel tap vaccum tube) are blocked off.
Do you have a manual for the bike? Does it mention anything to do with accelerator pumps on the carbs?
finpos.
Finglonga
PostPosted: 17:59 - 07 Feb 2007    Post subject: Reply with quote
finpos.
If you can't see the video it is cutting out as if the pumps diaphram has split in the pump. Just as the carb should be giving it that bit of juice to keep it going the engine cuts out.
Andy Sez....
F.Y.Y.F.F.
nick606
PostPosted: 18:10 - 07 Feb 2007    Post subject: Reply with quote
could be water in the carb this happened with my bike..... or blocked air/fuel filters maybe ?
bike sounds beast though
Harley Godzisz
PostPosted: 19:57 - 07 Feb 2007    Post subject: Reply with quote
NC30's do not have a throttle position censor, nor do they have accelerator pumps on the carbs.
1st of all, do the fuel tap mod (take the fuel tap apart and move the spring to the opposite side of the diaphram.), this will eleiminate any fueling problems now and in the future.
secondly, While you've got the tank off, whip the air box off and look for any plates (carb restriction disk's) that are like a huge washer with a small hole about a quarter of the size of the disk. Remove them if any.
Thirdly, Clean the air filter.
If you still have problems, you have a jet's problem. Try 118 main jets in the front and 120 main jets in the back. That's what i use in my NC30.
Good luck m8 Thumbs Up
Should only take you an hour tops!!! takes me 15 minutes to change jets and get it back to gether.. but then again i did pull my bike apart every weekend!
Cillit-BANG
PostPosted: 20:38 - 07 Feb 2007    Post subject: Reply with quote
Unless you are racing then avoid the fuel tap mod.
Quite a few people have problems with fuel overflowing from the bowls and entering the oil supply which may result in seizure if left unnoticed. Its ok if you check your float height regularly or turn your tap off every time you stop, but for most it is just a pain in the arse.
I'd agree it is a fuel issue. Have you checked that the vacuum hose is in good condition with no cracks? All carbs are seated properly in their rubbers?
The last post was made 19 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 68.75 Kb
