washer jet problem **SOLVED**
befdelta7
PostPosted: 00:15 - 07 Feb 2007    Post subject: washer jet problem **SOLVED** Reply with quote
hi,
i know this isnt bike related.... sorry, i just need some info fast you see my dads driving to his brothers in dorset tomorrow and the washer jets dont work properly which is really not very good given the time of year and the crap on the motorways.
i have replaced one jet with a new one as my dad broke a needle in the jet hole trying to adjust it and the other isnt blocked and in very good condition....
the problem is the pump turns, you can hear it whining, but the pressure of the water coming out of the front two jets is very poor! the rear washer jet, jet's out like it should do.
does anyone have any ideas as to what the problem can be??
some forums iv searched on google just now say something about an airlock but didnt give any infomation on how to sort it.
has this happened to anyone else? also anyone got any ideas on how to sort it? as its impossible to clean the screen as the water doesnt reach the screen but dribbles out the jets.
if i block the drivers side jet the water from the passenger side jet improves in pressure but not nearly enough to clean the screen.
the car in question is a vauxhall vectra elegance 2002 (new shape)
thank you for your replys Thumbs Up Thumbs Up Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
PostPosted: 00:20 - 07 Feb 2007    Post subject: Reply with quote
I would suspect a split pipe somewhere in the system
Gradog
PostPosted: 00:26 - 07 Feb 2007    Post subject: Reply with quote
It could easily be a split pipe or loose pipe connection, but the deciding point would be whether the car has two pumps for the washer, ie front or back, or a switching relay. In which case the short term answer is to switch them to get your old man out of trouble and then chase the problem through at the weekend. If you switch and they are still shit then you definately have a pipe fault.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
befdelta7
PostPosted: 00:44 - 07 Feb 2007    Post subject: Reply with quote
cheers for that info lads Thumbs Up
there is not water marks on the drive so i dont think it could be a split pipe.
iv been reading a bit more on the net and a lot of people seem to have this problem(not this perticular car) and mention an airlock thus causing a lack of pressure and making the water dripple out insted of jetting out. how would i go about getting out an airlock?? i might aswell try this as it strikes out one possibility LOL.
come to think of it my mum did run the screen wash bottle dry before this problem arised-- could it be an airlock??
she uses the car more than my dad, but typical of my mum she doesnt have a clue about it and "just drives it" Rolling Eyes
cheers for your replys
PostPosted: 00:52 - 07 Feb 2007    Post subject: Reply with quote
Would think the pressure from the pump should push the air out pretty quickly.
jimbothe
PostPosted: 01:25 - 07 Feb 2007    Post subject: Reply with quote
If mine runs really low i sometimes get bits of shite in the pipe.Just take it off from the jet and pump it through as you would if the jet was connected.If there is an air leak or a blockage it is sure to clear Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
GSXFire
PostPosted: 01:30 - 07 Feb 2007    Post subject: Reply with quote
I would put my money on the pipe being trapped or nipped just where it goes from the bonnet to the engine compartment, try the washers with the bonnet open and move the hoses about, make sure the hose isn't nipped. Thumbs Up
Fire by name Firefighter by nature.
My old bikes. https://www.bikepics.com/members/firefighter1/
Regan28
PostPosted: 01:45 - 07 Feb 2007    Post subject: Reply with quote
I had the same sort of thing in my car, problem on mine was that it had a non return valve to stop water running back into the bottle when it wasn't pumping water (so that there was always fluid as soon as you pressed the button). I think this either got blocked up or just broke, I removed this and its fine now. Just need to wait a second or two while it pumps it from the bottle now Thumbs Up
finpos
PostPosted: 10:40 - 07 Feb 2007    Post subject: Reply with quote
Remarkably effective fix/diagnosis method - pull the tube off somehere and blow through it Smile
finpos.
Finglonga
PostPosted: 12:41 - 07 Feb 2007    Post subject: Reply with quote
Are you sure the water is not simply frozen? The pump will still work but nothing will get through.
Andy Sez....
F.Y.Y.F.F.
extreme3d
PostPosted: 18:01 - 07 Feb 2007    Post subject: Reply with quote
I agree. Been blue skys and sun all day today, yet our outside tap was still frozen solid.
Finglonga
PostPosted: 18:07 - 07 Feb 2007    Post subject: Reply with quote
I remember a few years ago there was a spate of numpties that burnt out the washer bottle motor because they would presss and press it untill either water came out or it stopped making a noise. Shocked
Andy Sez....
F.Y.Y.F.F.
befdelta7
PostPosted: 19:47 - 07 Feb 2007    Post subject: Reply with quote
the water isnt frozen as this was happening before it was cold enough to turn water to ice.
my best guess is its a blockage or an airlock.
thanx for all your replys people Thumbs Up Thumbs Up Thumbs Up
befdelta7
PostPosted: 19:53 - 07 Feb 2007    Post subject: Reply with quote
Nb
PostPosted: 19:56 - 07 Feb 2007    Post subject: Reply with quote
I get cars at work that have the same trouble, 8 times out of ten its because the owner has put too much screen wash in. Which then conjeals (sp)? and clogs up the filter underneath the pump. If you pull out the pump you will probably see a black rubber seal thats like a gauze? Poke a bigger hole in the middle with a knife or a phillips screwdriver. Thumbs Up
garyd
PostPosted: 20:31 - 07 Feb 2007    Post subject: Reply with quote
Best bet,phone local taxi for a price and flog the car................. ever wondered what the little locked flap is on the side of car?!!could always stick yer head out an spit on the windscreen.
garyd
befdelta7
PostPosted: 20:36 - 07 Feb 2007    Post subject: Reply with quote
what the hell are you talking about?
garyd
PostPosted: 20:55 - 07 Feb 2007    Post subject: Reply with quote
im talkin about how ignorant some are of the workings of a car,christ sake man ,its schoolboy stuff,what yer gonna do when you hear a noise /or need to replace the air filter?get a manual and get to grips with it ............just like you would before the "tinter net"came about Middle Finger
befdelta7
PostPosted: 21:19 - 07 Feb 2007    Post subject: Reply with quote
seeing as my mum uses the car everday for work and the car gets used most evenings,
is pointless unless the problem is narrowed down as who knows how long it could take to find... it being as the car is used frequently!
how longs the internet be running, back then car workings were a hell of a lot simpler than todays cars.... shows how ignorant you are to the workings of a car Middle Finger Middle Finger
Finglonga
PostPosted: 21:40 - 07 Feb 2007    Post subject: Reply with quote
Talking about schoolboy stuff.....English is a subject at schools still, as far as I know? Basic mistakes CAPITAL letters at the beginning of sentences and for names.
https://www.loc.gov/exhibits/oliphant/oa048.jpg
Andy Sez....
F.Y.Y.F.F.
timjim
PostPosted: 23:06 - 07 Feb 2007    Post subject: websites Reply with quote
I for one,joined the site so as i could learn about things i dont know and teach about things i do know.If someone has the honesty to put there hand up and say "ive got a problem and dont know how to fix it",i would like to offer my advise,maybe good,maybe bad.....isnt that what a manual also does????
Going back to the original question though,try and remove the pipe from the washer pump and see what pressure, if any,comes out.If none then the gauze strainer may have become blocked with sludge,so just clean it out.If the pressure is good, then refit the pipe and trace it along checking for kinks in the pipework.Good luck and THANKS for asking..............................................................................................................If in doubt...ask Thumbs Up Tim
befdelta7
PostPosted: 17:06 - 10 Feb 2007    Post subject: Reply with quote
**SOLVED**
it was an airlock!
what i did was use the battery booster packs pump (the yellow pack with an electric pump for inflating tyres) connected it to the hose from the washer bottle and turned it on, the pressure gauge went to 120ish psi then a loud pop was herd and the water in the washer bottle shot out the cap and went about 3ft high like a fountian but a lot more violently. and all was solved the pressure in the washer hose was back to normal and the washer jets, jetted out the water like they should!
so anyone else experiencing this same problem try the above method worked a treat for me!
cheers for all your advice lads Thumbs Up Thumbs Up Thumbs Up Thumbs Up
The last post was made 19 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 124.11 Kb
