Help with valve clearances NC23
clemsta
PostPosted: 23:21 - 07 Feb 2007    Post subject: Help with valve clearances NC23 Reply with quote
I've got the bike stripped down for a full service at the moment so i thought i'd do the valve clearances, theres 2 out of spec and a few which are on the limit, should i just chang the 2 in red or should i change more.
thanks
Adam
https://img68.imageshack.us/img68/9774/valveclearancesly5.png
SOMEONE CALL THE DOCTOR! I've got 2 stroke fever!!!
OGRI - Stuff everything, i've always got my bike!
DAS Passed - 7/6/06
SoND
PostPosted: 03:46 - 08 Feb 2007    Post subject: Reply with quote
I'd do them all while you're in there, might aswell.
instigator
PostPosted: 04:06 - 08 Feb 2007    Post subject: Reply with quote
Got to change the 0.12 ones as well...they will be out soon anyway. All the exhausts need done. Since you're in there as SOND says, do them all.
Wallet might take a fair whack if your dealer doesn't exchange shims...do check ebay before you buy anything, there was a seller doing them for £3 e.a whereas suzuki charged me somewhat more per shim if memory serves correct. Honda being honda would probably charge a hell of a lot more. Rolling Eyes
edd
PostPosted: 11:13 - 08 Feb 2007    Post subject: Reply with quote
Checking ebay is a good idea, in my experience bigger dealers tend to be less keen on swapping shims than smaller backstreet dealers so hunt out a backstreet garage if you cant get them swapped. You might well be able to re use a lot of the shims already in your head, just by swapping them around.
Bluespark Automotive - Diesel Tuning for Performance and Economy
clemsta
PostPosted: 19:15 - 08 Feb 2007    Post subject: Reply with quote
so should i change them so that the inlets all have a clearance of 0.15 and the exhaust 0.20?
Thanks
Adam
DAS Passed - 7/6/06
SoND
PostPosted: 02:29 - 09 Feb 2007    Post subject: Reply with quote
Yep.
clemsta
PostPosted: 15:04 - 10 Feb 2007    Post subject: Reply with quote
Thanks for your help guys, i'm gonna check the valve clearances one more time to make sure they were correct then i'll whip the cams out and get some new shims, i've got a vernier caliper to make sure the shims are correctly marked as well.
DAS Passed - 7/6/06
Cillit-BANG
PostPosted: 23:13 - 10 Feb 2007    Post subject: Reply with quote
You'll need a micrometer to check the shims, they need to be right to within 100th's of millimeters.
And be aware of course you can move shims around so you won't need to actually exchange all of them.
If they are the same shims as the VFR NC30 (which I doubt) then you can get them exchanged for £1 a pop. They are £5 each new.
The last post was made 19 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 56.56 Kb
