how to remove battery without setting off alarm constantly??
mike_neon
PostPosted: 16:44 - 08 Feb 2007    Post subject: how to remove battery without setting off alarm constantly?? Reply with quote
i need to desperatly charge my battery. when i remove the screws and connections the alarm goes off. what do i need to put the connections on to earth it or what ever.
i have been biking for 4 years now, and i have never had a mechanical let down on a bike, every single trouble i have had with a bike is the alarm on the past two bikes i have had Embarassed are they worth the hassle, bloody things Laughing
some help quick plz
Simple
PostPosted: 17:18 - 08 Feb 2007    Post subject: Reply with quote
I've never owned a bike with an alarm, however I believe you need to put it into service mode if it has one, do you have the paper work for the alarm? If not ring a dealership up I'm sure they'll help you over the phone.
Other wise, long extension cord and charge the battery while it's on the bike?
Insta - FemFeral
Finglonga
PostPosted: 22:49 - 08 Feb 2007    Post subject: Reply with quote
Just charge the battery on the bike, I always have if I needed to with no problems. Wink
...Or as said above put the alarm into service mode and remove the battery.
Andy Sez....
F.Y.Y.F.F.
Rookie
PostPosted: 08:06 - 09 Feb 2007    Post subject: Reply with quote
Laughing We had some great fun with this when we were pulling apart the Cat. While it was all coming out I put duct tape over the speaker which dulled it well, and when I just had the frame left I just pulled out every fuse I could see. Laughing
stu_m
PostPosted: 23:49 - 10 Feb 2007    Post subject: Reply with quote
why not just put the alarm in sevice mode
get a manual for the alarm it will tell you how in there
usually you turn the ignition on then press the button as if to arm the alarm then turn ignition off
Stu
PostPosted: 00:47 - 11 Feb 2007    Post subject: Reply with quote
To put mine in service mode you turn the ignition on then hold down the button, and turn it off again.
edit:- or do what I do, Go for a long ride to charge it up.
The last post was made 19 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 47.69 Kb
