Odd indicator problem
Itchy
PostPosted: 14:13 - 09 Feb 2007    Post subject: Odd indicator problem Reply with quote
My indies work , problem is the idiot light doesn't work consistantly , I signal
right and the idiot lamp flashes in sync with the right signal, ie works normally
I signal left and it sometimes doens't come on at all , it sometimes comes on (the
idiot light) after about 10-15 seconds,
or if I signal right then left the idiot lamp flashes as normal.
Any thoughts as to the problem?
Honda NTV650, again.
Ta
Nath
PostPosted: 14:25 - 09 Feb 2007    Post subject: Reply with quote
Probably just a dirty/poor contact.
Think the wiring on the NTV is very similar to the Bros. Your indicator wires are orange and blue, I forget which is for which side, and you should have both of these wires going into your idiot-lamp cluster. Look which wire goes to which indicator, then clean the connection for that side going to the idiot lamp. This will all be inside your headlamp shell.
Hard livin', hard luck.
Itchy
PostPosted: 14:37 - 09 Feb 2007    Post subject: Reply with quote
yeah same bike different drive system tis all ,
damn those dirty contacts I only cleaned them up about 2 months ago due to another dodgy light issue!
The last post was made 19 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 37.28 Kb
