winter and my 600 bandit
fingers
PostPosted: 15:34 - 09 Feb 2007    Post subject: winter and my 600 bandit Reply with quote
hi everyone. got a question that needs answered by someone in the know. i ride a 600 bandit 95 model. it runs sweet as a nut with no problems, until winter comes and then it runs like a dog!. the problem is when i start the bike in the garage i get no problems until i start to hit the road in the cold and then the bike feels like its running on 3 cylinders!.if i stop revving it cuts out . if im riding above 5000 revs it picks up again and shoots off. any Mr. Green help would be great, someone has said it could be carb icing. if it is , how do i combat this , as when i work nightshift, the bike is left outside witha cover on but runs like shit. cheers and thanks.
veeeffarr
PostPosted: 15:35 - 09 Feb 2007    Post subject: Reply with quote
Do you have Carb Heaters?
fingers
PostPosted: 15:40 - 09 Feb 2007    Post subject: Reply with quote
how do i know? ive heard this before but not sure what to look for
finpos
PostPosted: 16:03 - 09 Feb 2007    Post subject: Reply with quote
Carb icing tends to work (not work?) the other way around - the bike will run fine until you cane it at high revs for a long time. Are you saying that when you come out of work it does not run well? If so I'd be more inclined to think that the damp gets to it and you have an electrical misfire.
finpos.
fingers
PostPosted: 16:10 - 09 Feb 2007    Post subject: Reply with quote
the bike only runs poorly when its freezing outside. get no trouble in wet. i ride bike in all weather and even torrential rain, and get no trouble until its about minus degrees, which is often in newcastle Laughing and when the weathers ok the bike rides like new.
finpos
PostPosted: 16:31 - 09 Feb 2007    Post subject: Reply with quote
Just not convinced about the icing - it's possible, but it's rare.
Another alternative is that the bike runs a little bit lean which will be compounded by cold air (I hope I've got that the right way round Smile ). You could try running it with the choke on exactly one smigin, see if that helps it.
If you are desperate to look for carb heaters, then they will work either off the cooling system or electrically, so look for small tubes or wires going to the carbs. A lot of bikes simply don't have them, don't know for sure about the Bandit.
finpos.
veeeffarr
PostPosted: 16:46 - 09 Feb 2007    Post subject: Reply with quote
WTF... This avatar is misleading.
Bezzer
PostPosted: 21:19 - 09 Feb 2007    Post subject: Reply with quote
You ARE joking I presume Rolling Eyes . Carb icing affects the idle circuit mainly, so you come off the main from higher revs to a blocked idle from ice formed from inlet air moisture and get rough running or cutting out, exactly the symptoms described, very common on a 600 Bandit with knackered or missing carb heaters, can even affect those with working heaters.
All Gen2 UK Bandits have heaters,some Gen1s don't though, if it has heaters fitted they are the small brass plugs under each carb with a cable joining them all together, there's also a thermo switch under the tank to control them.
If the electrical connections to each one is OK then you're looking at the switch being faulty as the heaters themselves are just a heated spring in a brass collar that don't "wear out".
It's easier just to use Silkolene Pro FST, it works and saves any hassle.
finpos
PostPosted: 02:39 - 10 Feb 2007    Post subject: Reply with quote
Bezzer wrote:
You ARE joking I presume Rolling Eyes.
No, I wasn't. If you're having to use fuel additives in this country, either Bandits in general or your bike in particular are seriously messed up. Not sure which, so I can't comment any further.
finpos.
instigator
PostPosted: 02:47 - 10 Feb 2007    Post subject: Reply with quote
Carb Icing is Sickpups speciality. Mr. Green
Bezzer
PostPosted: 22:06 - 10 Feb 2007    Post subject: Reply with quote
finpos.
All I can say is you can't really comment as you don't know what you're talking about
It's quite obvious that you haven't got a clue about the cause and effect of carb icing. If you had you would know that this country in particular gives you the right conditions for it. You seem to be of the mistaken opinion that you get it in Artic type climates when in fact you don't get carb icing in below freezing conditions as the moisture you need to get the icing has already dropped out of the air.
Some bikes are more subsceptible to it than others either by bad design, being an import from a country that hasn't got the necessary heaters as standard or failure/bad maintenance. Speak to any ram air Kawasaki owner that has forgotten to clean the carb coolant filter or any 600 Bandit owner without the carb heaters or and they'll tell you all about it. My own personal favourite was an import GS650, the cure if there are no heaters is an additive.
fingers
PostPosted: 23:26 - 11 Feb 2007    Post subject: Reply with quote
right, so from all this knowledge, i presume an additive in me tank of petrol should cure the problem. if so how much do i add per tank of petrol? thanks for all your suggestions. Laughing
JonB
Afraid of Mileage
PostPosted: 11:27 - 12 Feb 2007    Post subject: Reply with quote
I'm seriously assuming it is Carb Icing as well, especially seeing as your Bandit is a very early 95 model, this model did not have the carb heaters that later Bandits had. Use this additive as a temporary fix and if I was you, I'd go to a Suzuki dealer and ask how much it would cost to buy and install carb heaters for your Bandit. Smile
Kris
PostPosted: 14:45 - 12 Feb 2007    Post subject: Reply with quote
Well I can definately sympathise with the original poster on this topic.
I've got a '99 Bandit 600 S and recently the bike has been running absolutely terribly. It happened last year as well so before this winter I replaced the carb heater loom and two of the actual brass collars/ connections as they had fallen off. Unfortunately this still hasn't cured the problem, quite often the bike will die if I slow for a junction/ roundabout etc with exactly the same symptoms as previously mentioned up ^^. It's a shame really as the bike is otherwise ideal as a daily commuter.
I also have a sneaky suspicion that the carb rubbers are leaking ever so slightly, but the bike still ran in summer and on warmer days like today.
I'm going to give the additives a try next time the temperature drops - maybe it's worth adding the results to this post afterwards?
www.prisonplanet.com
bigwill
PostPosted: 21:10 - 12 Feb 2007    Post subject: Reply with quote
mine does the exact same thing!! i thought it may have something to do with mine being restricted or something!!
also mine has recently started to sound a bit different, sounds like the tappits. I think it just needs a service after the shit weather has ended.
2006 Yamaha FZ1 - the comfy R1
bonehead
PostPosted: 01:11 - 15 Feb 2007    Post subject: Reply with quote
Im having the same probs and have been since before xmas ( cutting out at low revs, not reving past 9k fow a second or two, sounds really loud as if running out of fuel, alittle choke on for a whole 1 hour commute is normal) and its been driving me mental. Im on a 95 600n with no carb heaters
Frank Dunstall in beckenham whacked half a bottle of the silkolene stuff in my tank for free and bikes been amazing for the last two days. Feels like summmer again (touch wood).
goatrider
PostPosted: 02:49 - 15 Feb 2007    Post subject: Reply with quote
Bezzer is spot on again Wink.....
Sounds like a definate case of carb icing.
As you say the bike runs fine in the garage (warmish and dry) and then it all goes tits up outside (cold with just a touch of moisture in the air) so its definately an atmospheric effect and that means carb icing.
Moisture in the air gets into your carbs and then the cold air being forced in while riding freezes the moisture causing the idle jets to block up a bit (thus the feeling of the bike being fuel starved).
Not sure how much the carb heaters cost but from what I have read and heard they aren't much cop anyway.
Pro FST is definately the best way to go at the moment - not sure on how much you are meant to use in each tank full of fuel but there must be a guidelines on the FST bottle so best plan is to follow them. It should solve your problem.
All the best.
Goat Wink
Honda NS125R 1987, Suzuki GS500EW 1998, Honda CB750F2N RC42 1992
"I dont give a shit who your dad is......quit walking on the water while I'm fishing......."
fingers
PostPosted: 20:35 - 16 Feb 2007    Post subject: Reply with quote
cheers goat.im off to bike shop tomorrow for the pro fst. funnily en thanks a lot mate.ough, the bikes running sweet as a nut now the cold snaps gone. still going to try it though.
Kaben
PostPosted: 21:06 - 16 Feb 2007    Post subject: Reply with quote
out of interest, why do you have Flips avatar?
Its Not a Melon, Its Clearly a Lime!!
Yamaha Fazer 600Now dead, MZ 125 SM
My Deviant Art homepage https://robabloke.deviantart.com/
The last post was made 19 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.78 - MySQL Queries: 15 - Page Size: 105.22 Kb
