For the love of God...
Kris
PostPosted: 12:43 - 19 Aug 2003    Post subject: For the love of God... Reply with quote
Got a few problems with the bike, thought I'd share them (just incase you can help)
Recently, the bike has been behaving itself and has been a real joy to ride. I'd changed the front calipers/pads/fluid and the brakes have improved considerably. Mucho happiness Very Happy
I'd even stopped worrying about the bike drinking clutch fluid (will find the leak asap) the swingarm bearings, and the carb/valves running problem. Generally I was in a very good mood with the bike...
....so I washed it.......
Now, last time I washed the bike I made the mistake of pouring a bucket of water over it. Not something I will do again as it obviously put water everywhere and the bike misbehaved. The bike would backfire over 4K revs and "BLAM-BLAM-BLAM-BLAM-BLAM" down the motorway was not fun.
This time I was careful to use a wet cloth to rinse around the tank and upper fairing, and only used a bucket of water for the lower parts.
Now the bike started with one backfire...but seemed to be otherwise okay. Went for a ride around the block and the bike just died on me. Tried to start it for over ten minutes with no joy. Tried one last time and it fired as normal. This happened four times over the weekend and the last time it happened the bike would not restart. But - the bike was fine for ages inbetween dying. I could be on a long ride to the coast - get there okay and then the bike would not restart. Surely the water has disappeared by now Confused
Now the bike is parked outside my g/f's and awaiting a bit of detective work.
Bikes - more trouble than they're worth!
/rant
[edit] thought I'd better add that the bike is trying to turn over (its a new starter motor btw) and the problem appears to be a weak spark.
www.prisonplanet.com
Scooby
Scrappy Doo
PostPosted: 12:46 - 19 Aug 2003    Post subject: Reply with quote
My NSR did this once, and I think it was because some water got into the carb somehow (in the float or something), but not sure if this could be the case with your bike cos surely it would still fire on 3 cylinders?
I ain't got a scooby-doo mate, sorry Sad
Kris
PostPosted: 12:49 - 19 Aug 2003    Post subject: Reply with quote
yea thats what I was thinking - water either in the carbs or near the spark plugs somehow Confused
But if you only knew how hot these bikes run then you'd be wondering how water can still be anywhere on the bike Very Happy
Demonic69
The Pink Rhino
PostPosted: 12:50 - 19 Aug 2003    Post subject: Reply with quote
Try draining the carbs, turn the little screw underneath. Bikes tend not to suffer from water too much. If they did all the bikes at RnB woulda been fooked. if yours is having trouble with water then there's something not right, maybe a leak somewhere letting water in?
Back on a Blade. Just feels so right.
Kris
PostPosted: 12:52 - 19 Aug 2003    Post subject: Reply with quote
Yea I'll try draining the carbs. I'll be checking the plugs/HT leads too.
Whats the betting the bike starts first time with no probs Evil or Very Mad
Robby
Dirty Old Man
PostPosted: 12:57 - 19 Aug 2003    Post subject: Reply with quote
Some water might have got into your fuel tank - if the seal on the filler cap isn't any good water gets in. Being heavier than petrol it sinks to the bottom and sits there, also sits in the bottom of your carbs until you drain them.
TiN
Pocket Tin
PostPosted: 13:00 - 19 Aug 2003    Post subject: Reply with quote
Moral of the story - Don't wash your bike. Mr. Green
TiN
dotgems.net
Phoenix
Twisted Firestarter
PostPosted: 13:33 - 19 Aug 2003    Post subject: Reply with quote
It doesn't on the 400 but on the 750s do the air hoses actually go into the airbox? If so I gues water could be pouring into your airbox when you wash the tank/nose fairing.
Scotty
Scooter Boi
Already knows this, and has been doing for the past year.
Regards
Scott
Kris
PostPosted: 13:45 - 19 Aug 2003    Post subject: Reply with quote
nah they're fake 'ram-air'
but....they do direct air down under the airbox...
hmmm /me ponders
cheers phoe
PostPosted: 14:43 - 19 Aug 2003    Post subject: Reply with quote
Suspect it is either water in the petrol as Robby suggested ( and Charlottes GPZ500 is a pain for this as it seems to get past the petrol cap quite easily, then causes a problem when you switch to reserve) or water near the plug caps, in which case use loads of WD40.
By the way methanol absorbs water so that it mixes with the fuel and is burnt OK. basically get a bottle of methylated spirits and put a cup full in the tank. Probably best not to thrash the bike too much on that tank of fuel though.
Kris
PostPosted: 15:12 - 19 Aug 2003    Post subject: Reply with quote
Nice one Keith Very Happy
The bike is actually on reserve.....so your theory could indeed be correct.
TBH I won't mess around with meths - I'll just drain the tank/carbs and put fresh jungle juice in Very Happy I'll check the plugs as well....
Kris
PostPosted: 17:27 - 25 Aug 2003    Post subject: Reply with quote
*update*
okay, so yesterday with a few hours to kill before a barbeque and with a willing helper in the name of 'Neil' (and his toolkit Very Happy ) I decided to have a go at draining the carbs (see attached pics).
Put fresh petrol in the tank, drained off the carbs and cleaned them through as well as we could with carb cleaner. Also charged the battery for good measure, oh and checked the plugs.
Carbs were a bit dirty, but not really *that* bad. Plugs were fine - battery charged. We did find that the electrical connection for the fuel pump ( a home made connector/elec tape affair from previous numptie owner) was shit and was very loose - so that got sorted. Oh and the fuel filter was checked...no probs.
Put her back together and this morning tried to start her.
The bike seems to want to start. If I put my hand over the exhaust and thumb the starter (long arms y'see Very Happy )- I can feel the exhaust gas waves "Whum whum whuming" as it tries to turn over.
Any ideas? I've been trying for hours, so the fuel must be getting through by now Confused
Any help/ideas much appreciated
Kristof
bonceunounce This post is not being displayed because the poster is banned. Unhide this post / all posts.
McJamweasel
BCF Junkie
PostPosted: 19:07 - 25 Aug 2003    Post subject: Reply with quote
bonceunounce wrote:
have you tried using the choke?
He's got to the point where he;s stripped the bike down and cleaned out the carbs - I'm guessing that he did indeed think to use the choke...
Anyway kris, are you geting a spark? And is the fuel definately getting through?
TiN
Pocket Tin
PostPosted: 19:08 - 25 Aug 2003    Post subject: Reply with quote
First off, get that dodgy lanky geezer away from the bike. Razz
How did you "check" the fuel filter? Have you checked that the fuel tap works? Have you checked the fuel and vacuum hoses? Have you thought about getting a decent bike?
TiN
dotgems.net
Kris
PostPosted: 19:18 - 25 Aug 2003    Post subject: Reply with quote
McJam: Didn't have a spare plug laying around-so was unable to do a 'spark check' on the cylinder head Confused So no, not positive about spark.
Fuel is definately getting through though. Bike now stinks of petrol where I've flooded it Sad
Tin: Lanky geezer? That's Neil, and he's 5'8" on tip toes Very Happy Spose that would be lanky to you though wouldn't it Wink
Fuel filter is brand new and is not clogged. Fuel tap works. How do you check 'fuel and vaccum hoses'?
....and my bike is decent (doesn't look like a panda anyhow) Razz so ner
TiN
Pocket Tin
PostPosted: 19:23 - 25 Aug 2003    Post subject: Reply with quote
Damn, thought it was you. Razz Embarassed
As for the hoses - just make sure that they're all connected properly and not kinked, although you should know that anyway. Is the air filter/box blocked or anything?
TiN
dotgems.net
JayZ
PostPosted: 19:58 - 25 Aug 2003    Post subject: Reply with quote
Had a similar problem on my other ZXR a while back.
And it was all down to the battery.
Kept on turning over until i ran the battery flat.
Even though the battery seems good, ZXR's are a bit funny, if they don't get exactly 12v they just spin over like it all seems ok.
But it doesn't get enough power for that extra spark. Wink
Try another one and see how you get on.
In the meantime i will have a think just incase it's something else. Confused
JayZ
PostPosted: 20:02 - 25 Aug 2003    Post subject: Reply with quote
Also double check the spark plug caps for deterioration.
Buy or borrow a standard NGK plug cap and have a swap about.
Kris
PostPosted: 20:22 - 25 Aug 2003    Post subject: Reply with quote
I must admit that sounds like it could be it. The Haynes manual said that the H model ZXR's all have the weird battery that requires a lot of maintenance, plus the last owner wouldn't have had the foggiest how to look after a battery properly.
Cheers mate Very Happy Will get a new one just to make sure.
Kris
JayZ
PostPosted: 20:38 - 25 Aug 2003    Post subject: Reply with quote
Let us know how you get on. Smile
Kris
PostPosted: 11:02 - 31 Aug 2003    Post subject: Reply with quote
UPDATE:
well I finally got it started Very Happy Here's how..
Bought a new battery, charged and fitted it. Still not turning over Confused
Went through the Haynes manual step by step, trying to check each part of the ignition system as we go. Got to the igniter unit (CDI) and decided to have a swop around with a spare I had with the bike. Well instantly the bike was sounding healthier, and trying to turn over - so I took both ignitors to the local garage to get a continuity check. Turns out the spare I had is the only one working Very Happy Cleaned all the contacts up and fitted the spare ignitor ... and after a while she turned over. Very Happy Thank fook for that....a new ignitor is £400 new Shocked
After that we did a spark check on all the HT leads just to make sure it was all okay...and then we went for a test ride Smile needless to say, very happy. No sign of it dying as yet [touch huge lump of wood] but am erring on the cautious side.
Many thanks to [JZ] who suggested the new battery- the old one is past it's best, so no doubt it helped. Thanks also to everyone else who suggested something... Cheers peeps.
TiN
Pocket Tin
PostPosted: 11:23 - 31 Aug 2003    Post subject: Reply with quote
Glad to hear that it's sorted mate, and almost in time for the winter too. Wink
TiN
dotgems.net
Kris
PostPosted: 11:36 - 31 Aug 2003    Post subject: Reply with quote
Laughing shuddup bitch
(it's sunny today - so I'm happy) Razz
The last post was made 22 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 5.86 - MySQL Queries: 13 - Page Size: 134.99 Kb
