Engine Oil
mistergixer
PostPosted: 13:54 - 11 Feb 2007    Post subject: Engine Oil Reply with quote
I've been given a load of (unused) engine oil by a mate who's giving up bikes.
My bike never really uses any except at service time.
My car on the other hand has a Yamaha engine and drinks loads of oil.
What (if any) are the differences between bike engine oil and car engine oil of a similar rating i.e 5w40
I've often heard it said that you shouldn't put car oil in a bike engine - why is this? If the ratings are the same, surely the oil is the same?
If there is any reason for the above, does it work both ways round - i.e i shouldn't put bike engine oil into my car?
Space Monkey #7
Rookie
PostPosted: 14:04 - 11 Feb 2007    Post subject: Reply with quote
People say not to put car engine oil in a bike engine because there's some car oils which have additives which bike engines don't like. Like that Magnatech stuff, the stuff that clings to the engine and stops wear before the car heats up? Apparently that really doesn't agree with bike engines.
iooi
PostPosted: 14:16 - 11 Feb 2007    Post subject: Re: Engine Oil Reply with quote
I think the main reason is a lot of bikes have wet clutches and the additives in modern oils is not suitable for them.
Used to use car oil like 30 years ago and it made no difference, but things have moved on a lot since then.
As to the other way, can't see it making much difference, so long as its not synthetic oil to non or such.
I would just save it till its oil change time and use it up that way.
PostPosted: 14:17 - 11 Feb 2007    Post subject: Reply with quote
I have often used car oil in the bikes. Not had any problems. There do seem to be some oils that can sometimes cause problems. Magnatec for example. Ste had problems with Texaco oil (I think).
The spec for bikes oils is generally lower than for cars (look at the API rating on the side of the bottle).
While I would generally not worry about mixing oils (it can very occasionally cause problems), I think lobbing in half a dozen varieties of bike oil into a sump already containing half a dozen varieties of car oil might be asking for trouble.
The only thing that you must not do is mix mineral based oils with castor based oils (eg Castrol R). Mixing sythetic and non synthetic is unlikely to cause an issue.
Gazdaman
I did a trackday!!!
PostPosted: 15:55 - 11 Feb 2007    Post subject: Reply with quote
I always use Halfords cheap shit 10W40 in my bandit. Did in my XJ600 as well.
Granted not top of the line sports bikes but it sure did the job.
Gaz
The last post was made 19 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.2 - MySQL Queries: 13 - Page Size: 46.03 Kb
