What section do I ask a car question on if its technical ?
theshmoo
Bottomless Pit
PostPosted: 23:09 - 10 Feb 2007    Post subject: What section do I ask a car question on if its technical ? Reply with quote
You see I have a saxo that has a fault with is rear wheel hub.
heres the question just incase.
Rear wheel hub Nut and shaft threaded.
What I would like to know is does the rear hub shaft come off the back axel or is it all one peace ?
I was ask to fix the hand brake for someone and on removing the drums I found the rear nut loose and the shaft threaded, Not only that but someone before me had stuck a sticker in side the cap that fits over the nut and it Says "hub needs replaced HAHA".
I know there is 2 ways to fix this.
1. Cut new thread on shaft and get a new replacement nut. Shaft and nut are 22mm 1.75 pitch, so I will need to get a 20mm dye and a new smaller nut to do this, Getting a 20mm dye might be hard to come by.
2. Replace hole backed for car parts bought from scrappy. Don't want to do this due to time and money factor.
3. This is why I'm here can the rear hub shaft be replaced on this car with out having to replace the back end ???????????????
CBR 1100 blackbird.
sagiliam
PostPosted: 23:18 - 10 Feb 2007    Post subject: Reply with quote
Cant help you with your problem about your car Laughing
But "Car Problems"; probably best here. It will be moved by a Mod if its in the wrong section Thumbs Up
alexhornet
PostPosted: 13:50 - 11 Feb 2007    Post subject: Reply with quote
how did the car prob go?
if its a rear beam axle and not IRS you will be able to get a stub axle ( bolts onto the axle and you attach the brakes, bearings etc )
cost me £20 for a stub from scrappys.
theshmoo
Bottomless Pit
PostPosted: 13:54 - 11 Feb 2007    Post subject: Reply with quote
Its a rear beam so the stud should just push out I think.
CBR 1100 blackbird.
alexhornet
PostPosted: 16:17 - 11 Feb 2007    Post subject: Reply with quote
the stub axle is normally held on with 3 or 4 bolts. take off the drum, shoes, bearings etc ( or discs and caliper etc ) then as the haynes book of bollocks normally says " simply refit "
theshmoo
Bottomless Pit
PostPosted: 18:16 - 11 Feb 2007    Post subject: Reply with quote
job done, stub just hamerd out, I was told it did not split from beam.
CBR 1100 blackbird.
The last post was made 19 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 49.15 Kb
