| satelliteone |
 satelliteone Nitrous Nuisance
 Posted: 01:19 - 10 Feb 2007 Post subject: my CB125S Project |
| McGee |
 McGee O RLY?
| Dalemac |
 Dalemac World Chat Champion
| Merv |
 Merv Two Stroke Sniffer
 Posted: 15:45 - 10 Feb 2007 Post subject: |
wow mate that looks sweet!looks like uv put in alot of hard work,bet you cant wait to ride the thing!
cheers
martin ____________________ 1988 CBR400 NC23 |
| ncrn |
 ncrn World Chat Champion
| WavyGravy |
 WavyGravy Scooby Slapper
| shonajoy |
 shonajoy Nitrous Nuisance
 Posted: 22:09 - 10 Feb 2007 Post subject: |
That's amazing, what a job  ____________________ Shona |
| satelliteone |
 Posted: 22:26 - 10 Feb 2007 Post subject: |
thanks for the post chaps, the spokes where taken out and cleaned, Lots of manual sanding. was going to get them zinc coated, but a decent alloy paint done them justice. Maybe in the future the zinc-ing will be done.
Every part was stripped, cleaned, rust treated and then repainted, i must of went through 7 wire brushes that fit on my drill. Lots of hours taken all the paint/rust off back to bare metal. Lucky for me, only the mudguards where rotten out. The frame was brill.
The engine took ages. The clutch was replaced with EBC parts. The gears, crank case was stripped cleaned. There was more water than oil when i first drained it out..lol The bore was fine but the piston rings where stuck. A good soaking in liquid spanner and a very small dremmel wire brush free`ed them up nice. Got a Gasket kit with seals and rebuilt the engine. Lapped the valves in and now have awsome compression. Points advance retard mech rebuilt also.
I did buy a few newer parts. But spent around 100 quid. Cheap bike me thinks. and have lots of fun with it.
And i did all this without a hyanes manual. The bike is that simple.
Sure i will ride the Jaffa project, it deserves a new life. For a 31 year bike, hopefully live on for a while yet.
Would love to do somthin a little bigger, but i can only drive 125cc so i might just go and take that dreaded test. probally on the honda too. Thanks for the input guys. |
| gavin |
 gavin World Chat Champion
| Gazdaman |
 Gazdaman I did a trackday!!!
| Welshd1k |
 Welshd1k World Chat Champion
| Dalemac |
| kawashima |
 kawashima World Chat Champion
 Posted: 14:15 - 12 Feb 2007 Post subject: |
You are professional rebuilder  |
| TOM M |
 TOM M World Chat Champion
 Posted: 16:29 - 12 Feb 2007 Post subject: |
That looks awesome, such a difference.
I admire your hard work, you should be proud  ____________________ Now owner of a 1200 Bandit |
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 17:23 - 12 Feb 2007 Post subject: |
If my current heap ends up looking half as good as that, i'll be a happy man. Nice job.
Zen Dog ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| satelliteone |
| Jamie S |
 Jamie S World Chat Champion
| WavyGravy |
 Posted: 12:10 - 14 Feb 2007 Post subject: |
Hi again
Davidsilver has the main stand return spring for £1.35, chances are they could help you with the exhaust clamp. I cant recommend them highly enough, cheaper than a main honda dealer though you do need to add VAT and postage to their prices, dont be afraid to pick their brains. They also do a genuine indicator relay for £25 but personally I'd get one elsewhere,
www.davidsilver.co.uk
this place does 6v relays for between 3 and 7 pounds, havent used then though
https://motorcycleproducts.co.uk/
When it comes to starting there might be problems, the rubber disc in the petrol tap might be hardened which can make the tap leak out the side, there is only one good position for the connection to the points, between the insulating washers, anywhere else = no spark and a very hot coil.
To set up the valve timing you line up the T mark on the flywheel with the mark, then with the points plate/auto advance/ and mounting plate removed line up the 'o' stamped on the cam gear with the notch/triangle on the cylinder head (its about 11 or 12 o'clock)
Points gap is 0.3mm
Tappets 0.05mm
Plug gap 0.7mm
You've probably already done all that but as you said you had no manual theres no harm in having a reference.
Have fun ____________________ 1975 CB125s, 1991 GN250, 1990 Ducati Paso 906
"Don't wake him up - He's got insomnia - He's trying to sleep it off" |
| WelshWizard |
 WelshWizard Derestricted Danger
| WelshWizard |
| Bru |
 Bru Trackday Trickster
 Posted: 09:51 - 15 Feb 2007 Post subject: |
| element |
 element World Chat Champion
 Posted: 15:52 - 21 Feb 2007 Post subject: |
no way. I had one of those in my garden for over a year. Was all complete but needed alot of work and I couldnt be bothered so I scrapped it..
anyways thats a damn good job there. Mine was in similar condition if not a little tidier  ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| Jack_Cheese |
 Jack_Cheese World Chat Champion
 Posted: 19:12 - 24 Feb 2007 Post subject: |
I've used them, decent service, and very competitive prices. I got a clutch cable for £11.95, an OE cable was closer to £60.
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
| satelliteone |
| satelliteone |
The last post was made 19 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
