| Arfdog |
 Arfdog Crazy Courier
 Posted: 12:06 - 13 Feb 2007 Post subject: Anti-dive mechanism |
I am going to try remove the rusty nipple on top of the anti-dive mechanism this evening. If I bugger it, I might remove the anti-dive completely.
Three questions:
Is this an anti-dive, considering that there is only one mechanism on one fork, nothing on the other?
What is the easiest way to disable/remove anti-dive?
If I remove it, will my bike start diving much more?
Thanks
https://i112.photobucket.com/albums/n190/arfdog/SIDE.jpg
https://i112.photobucket.com/albums/n190/arfdog/FRONT.jpg ____________________ I'm a lover, not a fighter. |
| Paddy Blake |
 Paddy Blake World Chat Champion
| Arfdog |
| finpos |
 finpos World Chat Champion
| Arfdog |
| finpos |
 Posted: 14:05 - 13 Feb 2007 Post subject: |
Inside there there's a piston - on one side of it is brake fluid, so when you press the brake lever the piston moves exactly like your caliper piston. Other side, there's a big spring to return it.
On the suspension side, there's basically two different routes for the damping oil to go when the fork is compressed - one that allows normal damping, one that is stiff damping (i.e. antidive mode).
When you press the brake, the piston moves and blocks off the normal route, leaving only the anti-dive route.
So, if you leave the brake fluid in the anti-dive unit and screw a bolt in t' hole, you run the risk of compressing the fluid, shifting the piston and putting it permanently into anti-dive mode.
i.e. it doesn't work by fork oil pushing back against brake fluid pressure.
And if you rip off the unit, you'll possibly expose some oilways, or at least a delicate diaphragm or something. You'd need to make up a metal plate to replace the unit with.
finpos. |
| Arfdog |
| finpos |
| Tarmacsurfer |
 Tarmacsurfer World Chat Champion
 Posted: 15:40 - 13 Feb 2007 Post subject: |
Anti dive (on the GPz series at least) was pretty good, when it worked. The problem being that it rarely worked for more than a few thousand miles between rebuilds
Looks to me like one fork has been replaced at some point, and so they are mismatched. If that's the case I'd hope that the system is already disabled otherwise it's going to lead to some interesting handling... What's the bike? The RXS100 doesn't have an anti dive system as far as I'm aware
Most important thing to remember if removing the system though, is fit progressive springs and sort the oil weight out, or the front endwill be utterly fubar. ____________________ I'm immortal. Well, so far. |
| crazymotorbik... |
 crazymotorbik... Nearly there...
| Arfdog |
 Posted: 18:53 - 17 Feb 2007 Post subject: |
Ok I removed the bleed nipple finally and got a stainless replacement, but it turned out the anti-dive nipple is about 2mm longer than ther brake bleed nipple, so I can't plug the hole!
So, I disconnected antidive hose, drained fluid, and sealed it back up again, so antidive is disabled and brakes are now hard as rock. I also opened the mechanism to see inside, and the piston was stuck in permanent anti-lock. I loosened it so it moves again, but there is no spring (on the top side anyway), so I hope it stays up.
Next problem, before removing the correct bit, I removed the incorrect bit of the antidive, the bast part. I lost about 3 teaspoons of fork oil which was behind it, before sealing it up.
So now I'm thinking I should replace fork oil in both forks so I know they're sound. Question is: the manual I have does not cover models with anti-dive forks.. so how much fork oil should I put in each, especially considering that one fork has a newly disabled anti-dive? I'm guessing unequal amounts in each fork, but equal level from the top in each, since one fork will probably have a bit more space atthe bottom due to anti-dive.
Thanks.
* Oh, if anyone has a haynes manual for the 1986 gs450, could they please have a butchers and tell me if it says anything about fork oil levels specifically on anti-dive forks? thanks ** ____________________ I'm a lover, not a fighter. |
The last post was made 19 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
