Cruise Control
Edicap
PostPosted: 17:38 - 13 Feb 2007    Post subject: Cruise Control Reply with quote
One for the budding car mechanics out there! Can I fit cruise control to a car that doesn't have it as standard?
I'm thinking about a VW Golf, around a 1999 model.
Life is not a journey to the grave with the intention of arriving safely in one pretty and preserved piece, but to slide across the line broadside, thoroughly used up, worn out, leaking oil, shouting GERONIMO!!!
Honda CBR600F
phantomtek
Lil Joe Tek
PostPosted: 17:40 - 13 Feb 2007    Post subject: Reply with quote
You will need a brick and a bungee cord and I think it can be done.
techierob
PostPosted: 17:45 - 13 Feb 2007    Post subject: Re: Cruise Control Reply with quote
hmm.. possibly Thinking
A brick and some gaffa tape should do the trick - it worked for father ted anyway Thumbs Up
If there's no facility for it in the engine management system, then I can't see it being a simple job. If there is a redundant cruise-control system already there, then it might just be a case of cannibalising the parts off a similar model car that's found its way to the breakers and plumb them in as required.
ken
PostPosted: 17:52 - 13 Feb 2007    Post subject: Reply with quote
No you can’t as vehicles fitted with cruise have a different wiring loom, and also the ECU would not be programmed correctly,
So you chose the golf then?
latest bike 03 R1 in zee red and black
Edicap
PostPosted: 17:55 - 13 Feb 2007    Post subject: Reply with quote
Think so, looking at a 1999 GT TDi model with 100,000 miles on the clock. Was a bit worried about the miles at first but it has a FSH and apparently thats bugger all for a VW diesel engine.
Honda CBR600F
ken
PostPosted: 18:02 - 13 Feb 2007    Post subject: Reply with quote
Maybe not, but you are going to put star ship miles on it if my memory serves me correct?
but its not just about how long the engine will last (they are strong motors) but its other things like wheel bearings various motors, so your running cost will go up just make sure you buy it cheap enough
If you pm me reg No I will do a hpi check and a value on it
Off home now and will be online later
kc
Edicap
PostPosted: 18:06 - 13 Feb 2007    Post subject: Reply with quote
Wilco mate, cheers for that! Thumbs Up
Honda CBR600F
The last post was made 19 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 52.51 Kb
