| Louise |
 Louise World Chat Champion
 Posted: 00:22 - 15 Feb 2007 Post subject: Bandit |
Ok, Sorry I cant find you 'Gaz' on the members search
But following the chat ive got some pics.
To everyone else, I had a new chain fitted a week ago.
It seemed to be ok, but was rubbing - could feel it on the footpegs spesh when breaking.
Anyhoo - I was attempting to Wheelie, first time - few inchs and left it at that.
Today, attempted again - 1st gear, rolling at 20mph, throttle off - throttle on - I must admit I pushed the bike to the limit im guessing.
Heard a really loud cranking/clatter noise from the back - Im guessing its the chaing.
People on other side of the car park even heard it.
Bike was judgering so pulled clutch in to smooth out and come to a stop.
Frightened me to some extent
Check chain, all ok - right tension - Guard isnt loose, all teeth in the front and back sprockets are all there. Hugger isnt touching.
Im miffed and so were a couple of others.
On the way home tonight I stoped, checked for the noise (other post of mine)
Well the noise seems to be comming from the front sproket.
Here are a few pics. Any avice again before I take it to 'another' garage.
Its starting to piss me off now - Im not trusting the bike at all ATM |
| Bezzer |
 Bezzer World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 01:24 - 15 Feb 2007 Post subject: |
id say by looking at the photo (not that i can tell much from them)
that your chain is far too tight,
when you sit on your bike you should have 1/2 inch slack, (up and down)
that looks like its got no slack and no one is even sitting on the bike,
when you sit on it you are tightening it even more and the chain is probably catching on the edge of the sprocket as it moves past it,
 ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| goatrider |
 goatrider Renault 5 Driver
 Posted: 02:03 - 15 Feb 2007 Post subject: |
Yep - I would agree with the above comment about chain tension. Chain looks like it has no slack in it at all. Might be a bit out of alignment too - check the adjuster marks on the swingarm where the rear wheel spindle goes through it - they should be on exactly the same mark on both sides of the swingarm - if they are not then the back wheel is not in proper alignment and the chain will be catching on the sprockets a little.
Put the bike on its center stand (assuming you have one - or a paddock stand - rear wheel needs to be off the floor) and give the back wheel a spin by hand. You will probably find that the chain makes a "clonking" noise everytime a link is taken onto the sprocket if it is too tight or mis-aligned.
It also looks like the chain could use a good bit of decent lube too - it appears very dry to me.
Hope that all helps
Let us know how you get on with the problem.
(apologies if you know this stuff already and have checked it all - i am new to this and just trying to help out )
Goat. ____________________ Honda NS125R 1987, Suzuki GS500EW 1998, Honda CB750F2N RC42 1992
"I dont give a shit who your dad is......quit walking on the water while I'm fishing......." |
| goatrider |
| Pete. |
 Pete. Super Spammer
 Posted: 09:28 - 15 Feb 2007 Post subject: |
Nothing wrong with putting a new chain on used sprockets, so long as the sprockets are good.
Your front sprocket is shagged Louise, you need to fit a new one. You also need to lube the chain more what you have there is far from adequate. The rear looks to be not bad. ____________________ a.k.a 'Geri'
| Kris |
 Kris World Chat Champion
 Posted: 10:04 - 15 Feb 2007 Post subject: |
I'd also check that the chain link that was clamped closed when the chain was fitted is not too tight, causing a tight spot.
Find the point at which the chain was closed and see if that particular link moves freely. It wouldn't hurt to check the whole length (I know my chain 'graunches' when the chain has tight spots).  ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| Ichy |
 Ichy World Chat Champion
| Paddy Blake |
 Paddy Blake World Chat Champion
| JonB |
 JonB Afraid of Mileage
 Posted: 15:01 - 15 Feb 2007 Post subject: |
Completely un-related from mechanics, but you've only had the Bandit a month tops after having a 125, sure it's sensible to try and wheelie so early?  ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| Vincent |
 Vincent Banned
 Posted: 15:13 - 15 Feb 2007 Post subject: |
Yep, as above. My bet's on a blown gearbox bearing or rear sprocket carrier bearing. If the garage adjusted your chain too tight I'd take it back to them, but don't tell them about the wheelies  |
| Louise |
 Posted: 17:18 - 15 Feb 2007 Post subject: |
I know, I know but I wanted to try
Anyway took it to a recomended garage, He said the bike sounds absolutly fine
Chain is the right tention, Back sproket looks fine - unsure of the front - didnt have time to check. He rode it, but only up the drive and said it was all good.
The vibrations can be caused by the chain working its way into the sprocket ect ect
He also said as its my first big bike im sitting on top of the engine so I would here lots of different noiseys.
MOT booked for next week, which he will check the sprocket again. |
| Pete. |
 Pete. Super Spammer
 Posted: 18:42 - 15 Feb 2007 Post subject: |
This sprocket is knackered, it's about to start seriously hooking the teeth. The cutouts between the teeth have gone from having a circular base that fits the rollers of the chain to a flat-bottomed U-shape, with sloping sides, this will cause the side-plates of the chain to stretch and the rollers of the chain to roll-up the sides of the tooth cutout and jump over the tooth, putting enormous stretching-force on the chain and destroying it in short order. You need to change this sprocket very soon or you'll be needing another new chain too. The reason the rear sprocket isn't showing so much wear is because it's about 2.5 times the size of the front so each tooth of the front sprocket gets used 2.5x more often than the rear, plus the load is distributed over more teeth. ____________________ a.k.a 'Geri'
| Finglonga |
 Finglonga World Chat Champion
| Paddy Blake |
| goatrider |
 Posted: 05:36 - 16 Feb 2007 Post subject: |
Fair comment, fing - they are only a "guide" and its always worth double checking with a metal ruler from center of spindle to end of swingarm to get it mm perfect....but if one side was on say mark 4 and the other side was on mark 5 then its a good indication of misalignment.
Hope it gets sorted soon Louise.
All the best,
Goat  ____________________ Honda NS125R 1987, Suzuki GS500EW 1998, Honda CB750F2N RC42 1992
| JGY6000 |
 JGY6000 Trackday Trickster
| JGY6000 |
 Posted: 11:29 - 16 Feb 2007 Post subject: |
| Louise |
| Pete. |
 Pete. Super Spammer
 Posted: 18:01 - 16 Feb 2007 Post subject: |
Louise the rear sprocket looks good enough to last at least the life of your crrent chain, and the front should only cost about a tenner plus fitting. It's no bad thing changing both but it's not necessary. ____________________ a.k.a 'Geri'
| Fallen Angel |
 Fallen Angel Franny the Nanny
 Posted: 22:18 - 16 Feb 2007 Post subject: |
Geri is spot with his diagnosis of the front sprocket ... the clatter you heard was probably the chain jumping teeth on the front sprocket ... change it soon as it could knacker your chain quite quick. ____________________ I have an asshole tolerance level of -10
www.cliqueyclanmcc.co.uk
www.bebo.com/fallenangelfran |
| timjim |
 timjim Trackday Trickster
 Posted: 22:46 - 16 Feb 2007 Post subject: Bandit |
Louise..in the first pic you posted of the back wheel-is that swarf on the back wheel?if so ,try and get the back wheel off the deck and spin the wheel by hand..check and listen for noise,in particular from the back wheel,also check for ant tension or roughness in the drive.The reason i ask,is that i had similar characteristics form my Bandit after a tyre chain and found out that the f###wit let the spacer out between the sprocket carrier and the wheel bearing .Also agreeing with what other people are saying..yes youve got a spring missing(from your bikle).Dont trust the adjuster measurements on the swingarm and dont try and wheelie...its not clever and its more control with 2 wheels on the deck!!!!!Tim |
| Louise |
| Louise |
 Posted: 11:14 - 17 Feb 2007 Post subject: |
I need to get to London today - Last min thing. WIll be ok to ride? Just not ragg it? Only about 60 miles, maybe more - I tend to get lost Then come back tonight. Dont fancy taking the train! |
| Dalemac |
 Dalemac World Chat Champion
The last post was made 19 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
