| short1uk |
 short1uk World Chat Champion
 Posted: 08:55 - 15 Feb 2007 Post subject: Found this under bike what is it? |
| veeeffarr |
 veeeffarr Super Spammer
| finpos |
 finpos World Chat Champion
| Louise |
 Louise World Chat Champion
 Posted: 09:13 - 15 Feb 2007 Post subject: |
Who ya gonna call ? |
| short1uk |
| finpos |
| short1uk |
| Marci |
 Marci Brolly Dolly
 Posted: 10:20 - 15 Feb 2007 Post subject: |
Mop up spilt coolant - it's high ethyleneglycol content makes it VERY slippy, and also toxic - you really don't want any getting on tyres, and if you have cats etc you don't want `em licking it up - it WILL make them ill... ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| short1uk |
| freestyler_onli |
 freestyler_onli World Chat Champion
| finpos |
 Posted: 10:39 - 15 Feb 2007 Post subject: |
You know that it'll take about an hour of idling engine to put back into the battery the amount of charge you took out starting it in the first place
I think "buy a trickle charger" may be appropriate advice.
finpos. |
| yambabe |
 yambabe World Chat Champion
Is that the right colour to be coolant though?
It seems awful bright and green to me, the coolant we use is kind of blueish. Also, the green bit looks kind of thick and gloopy, wrong consistency?
At first glance to me it looked like that stuff you put in the tyres to seal them if you get a puncture. ____________________ Sod falling in love, I wanna fall in chocolate.  |
| short1uk |
| Marci |
 Marci Brolly Dolly
 Posted: 10:47 - 15 Feb 2007 Post subject: |
There is no "it might be..." - it is DEFINITELY coolant. I will state that with 100% certainty.
Coolant comes in many forms... reddish color generally indicates presence of polypropylene glycol (non-toxic). Greenish color indicates ethyleneglycol (toxic). Blueish color generally is based on Pentosin.
Green coolants (ethylene glycol based) tend to be a bit thicker than the others, and offer the best antifreeze properties.
It'll also look thicker if it's been leaked out whilst hot - water content will evaporate leaving behind the concentrated additive itself (coolant is is distilled water mixed with an anticorrosion-antifreeze-additive).
See https://www.mnpoison.org/index.asp?pageID=155, but ignore all statements of EthyleneGlycol being "more efficient" than water as a coolant. It has a higher boiling temp and lower freezing temp is all, meaning your coolant can get hotter than 100 deg C without boiling, and (depending on concentration) as cold as -40 deg C without freezing. It still doesn't hold a patch to plain water for thermal capacity and specific heat.
Part of the reason Ethylene Glycol and other additives are banned on racetracks is due to their surface-tension-reducing properties which result in a slippery surface, and the other part is due to it's toxicity.
Personally, I only use polypropylene additives - nowhere near as slippery, and non-toxic, and thus in an accident pose no further risk of the accident worsening. Generally I fill up with distilled water then dump a single 4oz bottle of Zerex in... ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| short1uk |
| finpos |
| short1uk |
| Ichy |
 Ichy World Chat Champion
| Marci |
 Marci Brolly Dolly
 Posted: 11:02 - 15 Feb 2007 Post subject: |
Shouldn't cost anything to sort - more than likely you simply boiled over... If it's recently serviced and is running fine otherwise, then worst case it'll be a jubilee clamp on the end of a hose that's worked loose or rusted... if loose just tighten it up again. If rusted, replace - they're about 75p.
Most thermostats are set to kick the fan in when coolant reaches 100 deg C, which is generally the start of the red section on your temp guage - can take a while (30mins or so) for it to get there from cold if just idling it outside. Once fan fires up, temp should drop by 20 degrees within a minute... ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| finpos |
 Posted: 11:03 - 15 Feb 2007 Post subject: |
Don't run the bike just to charge the battery .
I've noticed you can't see hee-haw through the sides of expansion bottles of newer bikes., so take the top off the bottle, look inside and guess.
finpos. |
| Marci |
 Marci Brolly Dolly
 Posted: 11:07 - 15 Feb 2007 Post subject: |
If can't get head at right angle to look in, grab a l'il ruler. Measure from neck of expansion tank down to midway between min and max. Dunk ruler in tank the same distance and pull out... look for the "water" line (ie: use a ruler as a dipstick). If can't get a clear enough line, fold a piece of paper around the ruler. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| short1uk |
| Itchy |
 Itchy Super Spammer
 Posted: 13:24 - 15 Feb 2007 Post subject: |
| finpos wrote: | Don't run the bike just to charge the battery  .
finpos. |
just don't do it when hot , as its nasty ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| finpos |
| curryfishball |
 curryfishball Nova Slayer
The last post was made 19 years, 275 days ago. Instead of replying here, would creating a new thread be more useful? |
