nsr 125 chain adjust
mansong001
PostPosted: 11:08 - 17 Feb 2007    Post subject: nsr 125 chain adjust Reply with quote
ive never ajusted my chain.how do you do it.im worried if i do it i may feck it up
dave madden
alains
PostPosted: 11:59 - 17 Feb 2007    Post subject: Reply with quote
you need 2 flat spanners size 10 and your special spanner to untighten the back wheel bolt . at each end of the swing arm , you see a bit of threaded rod (dia 6) with 2 nuts blocked together . hold the one against the swing arm then untighten a bit the other one (we will call it counter-nut) & do it on each side . untighten the back wheel bolt (2 rounds is enough) and lift the back if you have a stand . now tighten 1/2 turn by 1/2 turn the nut at each end of swing arm and you must do the same numbers of turn on each side . after each 1/2 turn on both side , control the chain play (3-5 cms vertically) . when ok , tighten the back wheel bolt and control again the chain play (it may moves when tightenning the bolt) . when finish block the counter-nuts
nota : when it's too tight if you untighten the nuts , kick a bit your wheel to put it back (when it's stiff it comes back hardly)
iooi
PostPosted: 12:02 - 17 Feb 2007    Post subject: Reply with quote
To be honest, if i was you i would go and get a Haynes Manual or one of the other ones for your bike.
In your case it would be money well spent.
About the only thing you can really get wrong that will cause major issues is over tightning the chain, or not getting the rear wheel in alignment.
alains
PostPosted: 12:11 - 17 Feb 2007    Post subject: Reply with quote
you cannot mist if you turn the same on each side Very Happy
Finglonga
PostPosted: 17:25 - 18 Feb 2007    Post subject: Reply with quote
Don't forget it need lubing too if you have not ever done that also. Wink
Andy Sez....
F.Y.Y.F.F.
The last post was made 19 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.18 - MySQL Queries: 13 - Page Size: 43.81 Kb
