I put swish new indicators on today....
PostPosted: 00:11 - 16 Feb 2007    Post subject: I put swish new indicators on today.... Reply with quote
Now all my warning lights are on and my heated grips do not work, what have I done!
yambabe
PostPosted: 01:03 - 16 Feb 2007    Post subject: Reply with quote
Not wired them up correctly?
PostPosted: 02:23 - 16 Feb 2007    Post subject: Reply with quote
The indicators work absolutly fine. so I don't think so
instigator
PostPosted: 02:25 - 16 Feb 2007    Post subject: Reply with quote
Laughing Thumbs Up
Are they LED jobbies? I know they require a certain amount of current but not sure whether they would mess about with electrics further down the line.
PostPosted: 03:10 - 16 Feb 2007    Post subject: Reply with quote
Nah just little ones. The indies work fine, it's everything else that is knackered.
iooi
PostPosted: 09:34 - 16 Feb 2007    Post subject: Reply with quote
Could be you have not replaced a earth lead somewhere.
I would have a good look at all the wiring around where you were working to see if you may have pulled a connection apart as well.
If you can't see anything odd then removing your new indicators from the power and see if everything else works OK again. Just because they work does not mean that they are not the problem.
yambabe
PostPosted: 09:45 - 16 Feb 2007    Post subject: Reply with quote
Yeah sorry that was a bit rude wasn't it. Embarassed
What I meant was more what iooi said, that when wiring in the indys you have knocked something else out of place.
Sounds to me like you may have accidentally bypassed a switch or something.
If you disconnect your indys is it still all wrong?
finpos
PostPosted: 11:11 - 16 Feb 2007    Post subject: Reply with quote
Normally I'd say that that is next to impossible, but if I remember correctly, triumph has odd wiring, i.e. just absolutely every circuit goes through a single humungous and mysterious ECU. If that's the case, first thing I'd do is to put the old ones back on and hope for the best.
It is worth while checking the bulb rating match, though.
finpos.
PostPosted: 03:23 - 17 Feb 2007    Post subject: Reply with quote
It has randomly fixed it's self Confused I think the bike has a mind of her own. Maybe that was her way of telling me she didn't like them.
Finglonga
PostPosted: 11:59 - 17 Feb 2007    Post subject: Reply with quote
As said above, you have knocked something. Re check all the wires especially the earth wires.
Andy Sez....
F.Y.Y.F.F.
The last post was made 19 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 64.6 Kb
