| Bru |
 Bru Trackday Trickster
 Posted: 12:16 - 16 Feb 2007 Post subject: NTV650 rear brake pad marks |
OK, so the title is not great. I have just fitted new pads to my rear caliper, replaced the piston and seals, and replaced the rear disc (could have bought a new bike with that.. ). Similarly the front. Anyway, took it for a test ride, and noticed that while the front pads are marking the disc uniformly, on either side, the case is different with the rear.
The pads are marking the nearside of the new disc fully, but only the outer edge of the offside. I also noticed radial lines on the disc, almost as if the assembly is skipping/vibrating.
OK, so I could strip the entire thing and begin again. But, as the rear is slightly different to the front in design (separates and rotates upwards for pad replacement), does anyone here know for sure if there are specific rules for lubrication of these calipers? I covered the rubber-shrouded shafts with copperslip, and bolted (and thread-locked) the caliper to the Haynes torque settings.
I am guessing that something is either loose or stuck part-open. What do you think? For a rear disc brake, it sure is poor right now. |
| finpos |
 finpos World Chat Champion
 Posted: 12:35 - 16 Feb 2007 Post subject: |
For a rear brake, I'm guessing it only has a piston on one side of the caliper, if that's the case: it's usually a sign that the pins that the two halves of the caliper slide on (rubber shrouded shafts?) are either worn, or corroded, or both . You might have to remove and split the caliper to get a good look at them. Should just be a case of pulling the caliper apart.
If it's got pistons on both sides, then I guess one of the pistons is sticking.
finpos. |
| Bru |
| finpos |
| Bru |
| Bru |
| Itchy |
 Itchy Super Spammer
 Posted: 14:19 - 16 Feb 2007 Post subject: |
crap mine does this too , , now its gone all sticky, getting replacements done soonish ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| finpos |
| Bru |
| Itchy |
 Itchy Super Spammer
 Posted: 16:23 - 17 Feb 2007 Post subject: |
I stripped the rear caliper cleaned 'er up then the front caliper seized up so I did that one too, maybe they were right about dominators and their enclosed disc brakes surely less crud 'll get into them. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Bru |
 Posted: 23:21 - 22 Feb 2007 Post subject: |
As an update to the rear caliper business, I have (kind of) sorted it. First came the eBay calipers, which were rusted and useless (surprise). Then the lightbulb went on, and I phoned my local Honda dealers. Yes, caliper slider pins exist, and could be had for £7 and change. Spent half an hour using heat, WD40 and a plumbers wrench before resorting to a file and adjustable spanner (file your own nut - marvelous). Pin screwed out. Inspected new one, to realise that 'hollow' end was formed to take a hexagonal drive (Allen key). Hit head against spanner as punishment.
Lesson to be learned: phone the professionals first, as they know the score (after you guys, of course). Clean item prior to dismantling - it's amazing what you might find.
Outcome: still some wobble, because the cast alloy hole in the piston block is softer than the worn forged steel pin. Nnn..
Guess that's it, tied up. No excuses now, but to ride the damn thing. |
The last post was made 19 years, 97 days ago. Instead of replying here, would creating a new thread be more useful? |
