Clean and respray help?
Dalemac
PostPosted: 13:12 - 17 Feb 2007    Post subject: Clean and respray help? Reply with quote
Hey everyone,
Im planning on taking off my pillion footrest and exhaust mounts on my ybr due to a huge build up of rust, which i hate.
To remove the rust, i will probably use the electrolysis method as described here. https://www3.telus.net/public/aschoepp/electrolyticrust.html
unless anyone elts can think of a better process to do this.
After will bake in a 200 degree oven for a few hours, after removing all the rust.
will then find a colour match to the rest of the bike (black) and spray the whole thing.
I have a few questions:
1.) is this the right technique and what elts do i need to do?
2.) how many coats of primer and paint should i do?
3.) is it even a good idea?
Here are some pic's so you can see what i have to deal with.
any help would be greatly appreciated.
Dale
YBR125 -> GPZ500S -> SL1000
Ciarans-special
PostPosted: 19:02 - 17 Feb 2007    Post subject: Reply with quote
Not sure how well that method of rust removal works, if it was me I would just use wire wool on it and alot of elbow grease, then when you have all the rust gone id sand down the paint wit sand paper.. As for painting it really depends on the paint you use but generally I apply about 2 or 3 tin coats of primer at about 15 minute intervals of each other then a two coats of paint and then two coats of laquer.
Good luck,
Ciaran.
Jamie S
PostPosted: 19:29 - 17 Feb 2007    Post subject: Reply with quote
3 coats of primer with a rub down of dry wet and dry between each coat, and 2 coats of your top colour.
hope this helps you.
jamie stokes
Dalemac
PostPosted: 23:45 - 17 Feb 2007    Post subject: Reply with quote
and what will the finish be like?
Also, run out of fs 365, so used some wd40 ot protect my exhaust, forks, wheels, engine etc.
Is WD40 a good temorary replacement?
Jamie S
PostPosted: 00:10 - 18 Feb 2007    Post subject: Reply with quote
the finish will be like paint.
Dalemac
PostPosted: 00:19 - 18 Feb 2007    Post subject: Reply with quote
really? i never knew that Laughing
i mean, would it be up to standard with the rest of the bike Razz
Jamie S
PostPosted: 00:27 - 18 Feb 2007    Post subject: Reply with quote
depends are you going to spray it or brush paint it ?
Dalemac
PostPosted: 00:30 - 18 Feb 2007    Post subject: Reply with quote
depends on how the paint comes. probably spray it.
Jamie S
PostPosted: 00:37 - 18 Feb 2007    Post subject: Reply with quote
if you are going to spray it it will be the same finish as the rest of the bike mate
Dalemac
PostPosted: 01:27 - 18 Feb 2007    Post subject: Reply with quote
kool, thats exactly what im lookin for Thumbs Up
Anyone elts got any suggestions?
Whosthedaddy
PostPosted: 05:49 - 18 Feb 2007    Post subject: Reply with quote
Powder coating will be much more hard wearing than paint.
I painted the FZR frame with Hammerite, used for the intended purpose, prepped and ready to go. However, the slightest fart near it caused the paint to peal and got damaged easily when bolts and bits were refitted.
Dalemac
PostPosted: 12:48 - 18 Feb 2007    Post subject: Reply with quote
ok there is a few powder coaters in my area, what sort of cost would i be looking at to get that done?
Dalemac
PostPosted: 12:50 - 18 Feb 2007    Post subject: Reply with quote
and daddy, see the last pic i posted, it shows the original paint flaking off.
Ciarans-special
PostPosted: 13:19 - 18 Feb 2007    Post subject: Reply with quote
If you spray it right an use at least two coats of laquer u will have a lovely hard finish.. how ever if your not very confident in your spraying skills, id go with powdercoating, its very easy to mess up spraying and get a nasty finish. If you can afford it id get it powdercoated it really is the beez neez!!
Dalemac
PostPosted: 13:33 - 18 Feb 2007    Post subject: Reply with quote
any ideas on a price?
loply
PostPosted: 16:24 - 18 Feb 2007    Post subject: Reply with quote
From my fairly limited experience I wouldn't bother painting it unless you can sandblast it first, and be sure to lacquer it.
When I've sprayed things that haven't been sandblasted, the slightest dink takes both the primer and the paint straight off - Which defeats the whole object.
I think the extra keying and adhesion of a sandblasted surface helps to prevent this.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Dalemac
PostPosted: 17:23 - 18 Feb 2007    Post subject: Reply with quote
ok loply thanks.
It looks as if i may as well just give someone the part and tell them i want it a perfect black when i get it back.
Still love to know what sort of price im lookin at tho.
Whosthedaddy
PostPosted: 17:26 - 18 Feb 2007    Post subject: Reply with quote
There have been a number of powder coating threads on here, I believe that wheels are around £30 and frames around the £100-£150 mark. These prices occasionally include the powder coaters collecting the parts too.
Jamie S
PostPosted: 17:42 - 18 Feb 2007    Post subject: Reply with quote
i have had a Quote to do my ariel (motorbike) frame of £35 this incs pick up, zink primer the lot
hope this helps
jamie stokes
Dalemac
PostPosted: 18:58 - 18 Feb 2007    Post subject: Reply with quote
hmm. there is 3 companies who do powder coating on the industrial estate down near me, i will call them and get a price.
Thanks for all the help people.
Jamie S
PostPosted: 20:10 - 18 Feb 2007    Post subject: Reply with quote
3 separate companys in the same area ?
Dalemac
PostPosted: 22:04 - 18 Feb 2007    Post subject: Reply with quote
yeah, according to yell.co.uk, there is 3 seperate powder coaters on the bayton rd industrial estate, coventry.....
The last post was made 19 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 107.79 Kb
