| phill_sumner |
 phill_sumner Nova Slayer
| sagiliam |
 sagiliam Could Be A Chat Bot
 Posted: 14:31 - 18 Feb 2007 Post subject: |
Hi, firstly, just for future reference. Post problems in "the workshop" section. Dont worry about it now, a mod will move it for you
Have you tried changing your spark plugs yet to see if theres any difference?
LS |
| Matt06 |
 Matt06 World Chat Champion
 Posted: 14:38 - 18 Feb 2007 Post subject: |
Check you're spark plugs and see how clean they are. You might need to give them a clean. ____________________ Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09 |
| phill_sumner |
| Teaman |
 Teaman World Chat Champion
 Posted: 17:41 - 18 Feb 2007 Post subject: |
if you have a center stand use it then lift the front end off the ground, I pack bits of wood under mine and rest it on the engine. This way you can spin the front wheel. do so and listen carefully, it could be disks rubbing or you hear a grating noise if its bairings.
if its bearings theres bound to be a bit of play in them, by getting aomeone to hold the bike turn the wheel to the side and pull it then push it a few times to check for play, you might pick up some play from the forks here, if so check them, (its a recently bought bike remember, owt could be wrong)
as for the power loss, check your plugs, the fuel system, the carbs (not sure if its got carbs tbh, these are basic ish checks)
my gpz 900r did the bogging down when I was rev happy, turned out to be the carbs and also the fuel line, previous owner had fitter a fuel filter, handy but slowed the flow,
have fun,
Stu ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them. |
| Matt06 |
 Posted: 17:52 - 18 Feb 2007 Post subject: |
| phill_sumner wrote: | sorry mate i didnt know where to post it, its my first post. But thanks for the replies. Ive been told it could be running rich or lean but ill inspect the spark plugs when i can get hold of a plug socket, cheers |
Unfortunatly, the GSXR400's always have problems running too rich so this could be you're problem. It might be an incorrect setting on the mixture screws on the carbs but more likely if its running too rich it will be the O rings in the carbs. The stock Suzuki O Rings tend to die and start to leak fuel after a while or if the bike has been stood for some time.
Even if the O Rings arent the problem at the moment I recommend changing them if they havent been before because they are sure to cause problems later on.
Dont worry though. The O Rings are easy to change and cheap to buy. ____________________ Current: MT-10, Bandit, Grom, GPZ500
| NSR Mick |
 NSR Mick World Chat Champion
| NSR Mick |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 20:37 - 18 Feb 2007 Post subject: |
It could just need a carb balance if it's fluffy in some places. ____________________ My Flickr |
| phill_sumner |
| NSR Mick |
| Matt06 |
 Posted: 14:54 - 20 Feb 2007 Post subject: |
I am currently in the process of changing/replacing my O Rings on the same bike. Got 2 of the 4 O rings I need delivered today.
You might find this website useful - https://tonysleep.co.uk/gsxr400carbs
It tells you everything about fixing possilbe carb problems with the GK76a. Mainly being the O Rings . The pictures should help with finding them aswell, they are quite small. ____________________ Current: MT-10, Bandit, Grom, GPZ500
| phill_sumner |
 Posted: 16:53 - 20 Feb 2007 Post subject: |
cheers mate that really helps did you take your carbs off to do the o ring replacement or did u manage to do it with them on? i can get access to the screws with a stubby philips head but im worried incase i round the screw heads with the carbs still on, are they easy enough to remove? |
| Matt06 |
 Posted: 17:12 - 20 Feb 2007 Post subject: |
You have to take the carbs off to replace the O Rings. There isnt really any way to get at them otherwise. If you follow some of the stuff on that site for getting the carbs off they should be easy enough to get out. The main thing that helps is to remove the airfilter so you can get some extra space for the screws. Oh and yeah, the philips screws around the carbs are shit and shape like butter but its mainly due to the age of the bike. Should still be able to get them off though. Try some WD40 .
Hope this helps. ____________________ Current: MT-10, Bandit, Grom, GPZ500
| phill_sumner |
| Matt06 |
 Posted: 18:40 - 20 Feb 2007 Post subject: |
With all that stuff off you should be able to remove the carbs. You dont need room if they are out of the bike .
What are you trying to access? ____________________ Current: MT-10, Bandit, Grom, GPZ500
| phill_sumner |
| NSR Mick |
| phill_sumner |
The last post was made 19 years, 91 days ago. Instead of replying here, would creating a new thread be more useful? |
