chinese 125 wont start ??? HELP
lilactime
PostPosted: 20:30 - 19 Feb 2007    Post subject: chinese 125 wont start ??? HELP Reply with quote
got shineray chinese 125 honda copy . had 3 months been ok , now wont start , even thou theres a spark and petrol is getting through ??? got me beat . any ideas ?
lilatime
Weedy
PostPosted: 20:31 - 19 Feb 2007    Post subject: Reply with quote
Dead battery?
<CBT passed 16th Sept 2007><Theory Test passed 11th Oct 2007><Practical Test passed 19th Apr 2008>
OWNED: 2008 Aprilia Pegaso Strada CURRENT: Bikeless :'(
Timmeh
PostPosted: 20:39 - 19 Feb 2007    Post subject: Reply with quote
I'm sure this topic'll be moved to the Workshop. Rolling Eyes
Anyway, chinese bikes all have one major weak point: The carb. The diagphram valve rubber splits wide open leaving you an engine that won't work or idles badly and doesn't generate any power.
I know a guy who owns a bike shop and they bought a load of Botian 125 scoots and they all died with the same problem.
Problem is virtually no-one stocks parts for the chinese copies so you'll be hard pressed to find a replacement. Even if you do, you'll be forced to buy a complete carb which will set you back around £100.
Whosthedaddy
PostPosted: 20:54 - 19 Feb 2007    Post subject: Reply with quote
My little monkey had a similar problem the other day.
Usually a good starter, even though needs choke virtually every time to start and fire.
However, for a good 5 mins I was trying various combos of choke / no choke, push start and kick start to get the thing to spark and fire. The engine would turn, anytime the engine fired it would cut out straight away.
I switched the bike to reserve and hey presto, the bike fired. There weas more than enough petrol in the tank so not sure, maybe an airlock?
I did however put it down to the way the bike got absolutely soaked a few days earlier when I forgot to put the cover on.
Pesky little thing Rolling Eyes
Giffer2
PostPosted: 21:12 - 19 Feb 2007    Post subject: Reply with quote
Have you tried starting with the kickstart and not having any throttle? The other weak point on these is the sidestand switch, which apparently doesn't like moisture, or water, or air or pretty much anything!
There is of course the chance that you've flooded the engine with petrol.
Whosthedaddy
PostPosted: 21:16 - 19 Feb 2007    Post subject: Reply with quote
When I picked the FZR from the garage after 2 weeks of nowt, the battery and everything was flat as you like, a quick hook up to a battery and the ting still would nt start.
The bloke then said:
Arrow Full choke
Arrow No throttle
Arrow Start button
Arrow Just keep the thumb on the button, in less than 10 secs the bike fired right up.
Used it a few times when the bikes been playing silly buggers and wouldnt start properly Thumbs Up
The last post was made 19 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 50 Kb
