why do my newish brakes squeel
nrg
PostPosted: 00:04 - 20 Feb 2007    Post subject: why do my newish brakes squeel Reply with quote
Why is it every time i get new pads they squeal for around 3 months, what am i doing wrong?
JonT
PostPosted: 00:34 - 20 Feb 2007    Post subject: Reply with quote
You forget to put some copper grease on the back of them?
Also another thing is if you replace the pads without replacing the disk the contact area to start with is less.
This is because a pad in its use cuts tiny grooves into the disk, this is fine because the pad matches the disk. When you replace the pad they no longer match and will make noise when the brakes are gently pressed. This noise goes away after a little while as the pad grinds away at the rough pattern made by the old pad.
shaun_04
PostPosted: 11:15 - 20 Feb 2007    Post subject: Reply with quote
Put copper slip around the back of the pads/around the pistons, be sure not to get any on the pads themselves though.
The last post was made 19 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 35.13 Kb
