What does the collector box do?
gimpy limp
PostPosted: 17:53 - 22 Feb 2007    Post subject: What does the collector box do? Reply with quote
I have an st1100 and the collector box and the section of pipe that comes from it has rusted and is going to need replacing. I can have someone make up two sections of pipe that would join the downpipes to the silencer on each side but would that cause problems (fuelling)?
This is an ST1100 without the fairings, the exhaust seems to run straight to the silencers, I can't see what the collector does:
https://img47.imageshack.us/img47/4141/1998st1100standardmodelec7.jpg
Couldn't we just fabricate 2 new pieces by here to joing onto the silencer:
https://img63.imageshack.us/img63/3889/de491copycq0.jpg
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - sam.barwick@ntlworld.com
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
veeeffarr
PostPosted: 18:21 - 22 Feb 2007    Post subject: Reply with quote
Collector box collects all the gases from the header pipes
Head pipes are designed to regulate back pressure, and are seperate so they can all be bent in the same shape to ensure they arrive in the collector at the same time.
(I think Wink )
T
baldy
PostPosted: 18:47 - 22 Feb 2007    Post subject: Reply with quote
make one up and change the fueling to suit. As long as they are the same length, there shouldnt be any problems.
One day i will rule the world, just not today.
hmmmnz
PostPosted: 18:49 - 22 Feb 2007    Post subject: Reply with quote
yeah you could do what your proposing,
the collector is just an easy way of getting all the pipes into 1 box,
normally there is just 1 can that comes off, but in your case there is 2,
at the moment you have a 4 to 2 to 1 to 2 Very Happy
but a 2to 1 as you decscribed would work perfectly fine and probly be a few kgs lighter as well Very Happy
as long as you have the first couple of bends from the head then there is enough back pressure for your bike to run sweet as Very Happy
that bike looks cool naked Very Happy Thumbs Up
the humans are dead
I kick arse for the lord
Odie
PostPosted: 18:58 - 22 Feb 2007    Post subject: Reply with quote
Toby R wrote:
Head pipes are designed to regulate back pressure.
I hate to tell you this but thats not exactly correct, they can have an effect but baffles are a better form of regulating back pressure as well as quieting the sound.
A collector box is a term used to describe where the down pipes of your exhaust meet up before they pass through to the silencers. Some times there are baffle plates inside the collector box.
A standard exhaust system normally has quite a large collector box to deaden the sound, where as an aftermarket exhaust might not even have one, might just be a 2 into 1 / 4 into 1 connector.
Collector boxs can also restrict the flow of the exhaust gas's which is why most aftermarket exhaust systems are of a "free flow" nature, they can get the exhaust gas's out faster and thus make the engine breath a little better combine this with adjustments in your carburation and you can release a few more BHP from your engine.
But remember that any work done to your exhaust effects the way you engine will perform and run and you must check your carburetor mixture to find out whether you are running lean (holed pistons, not good!)
The last post was made 19 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 46.69 Kb
