| carlmalibu |
 carlmalibu Spanner Monkey
 Posted: 20:12 - 22 Feb 2007 Post subject: "sloppy" back end? |
Hello all
I recently purchased a CB500, and moving onto it from the RS125 has been an experience to say the least.
Obviously the braking isn't as sharp (very obvious), and the acceleration is across the range, and the CB (inline 2) is considered a "boring" bike, but what I've found is it keeps feeling like the back end is slipping out. I can only describe it as sloppy.
I haven't ridden for a good 2 months before this bike (bar the scooter I drive on one of my jobs), but I feel like I have absolutely NO cornering confidence, for worry the back end is gonna drop out.
I can't explain it but whilst cornering the back end feels like its drifting ever so slightly if I lean, and I don't want to push it so I find myself cornering at real low speeds.
Is this purely a confidence thing or is it the type of bike? Is there anything I can do to help?
THANKYOU, Alasdair. ____________________ Shine on, you crazy diamond
CB500, woop. |
| craigs23 |
 craigs23 Mr Muscle
| MarJay |
 MarJay But it's British!
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 20:31 - 22 Feb 2007 Post subject: |
alot of the commuter twins out there are known for having sloppy arse ends and ride like hovercrafts, which probably isnt helped by the twin shocks on the rear,
if one has blown or is leaking then that will defently not help at all,
but first off check wheel bearings, linkage barings, tyre pressure ect.
it may be worth trying to find replacement shocks from another model bike, remember it was a bike made on a budget,
but you should with a bit of practise manage to almost get your knee down with it  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| cestrian |
 cestrian World Chat Champion
| chalky143 |
 chalky143 Traffic Copper
 Posted: 20:47 - 22 Feb 2007 Post subject: |
the handling would be shit compared 2 ur rs! and it will feel sloppy. I had tht going from my rs 2 a bandit 6! very shit handling but u get used to it. I bought i hornet 6 now and its alot better  ____________________ Current bike :: sv650 minitwin race bike
Previous bikes::cbr600 steelie race bike, 1989 Honda vfr750f, 2013 Honda fireblade, 2013 Ducati multistrata 1200s, 2012 Triumph street triple R, 1999 yamaha r6, vfr 800, ducati 600ss, vfr 400x2, ntv 650, bandit 600, cagiva mito 125, aprilia rs 50, honda c90x2, honda hornet 600x2, cbr 600, aprilia rx50, suzuki katana
My bike pics: https://www.bikepics.com/members/chalky143/ |
| carlmalibu |
| MarJay |
| davidimurray |
 davidimurray Nitrous Nuisance
| lllN30lll |
 lllN30lll World Chat Champion
 Posted: 21:59 - 22 Feb 2007 Post subject: |
I had the same problem.
checked my tires for depth and pressure, fine
checked the bearings, FOOKED!
once replaced back end was perfect  ____________________ Turbo R1
CRF450R |
| dainesefreak |
 dainesefreak World Chat Champion
 Posted: 22:00 - 22 Feb 2007 Post subject: |
Tyre pressures again from me, especially at this time of year.  |
| carlmalibu |
| lllN30lll |
| MarJay |
| Trixie |
 Trixie World Chat Champion
| shaba2000 |
 shaba2000 Nitrous Nuisance
| Marci |
 Marci Brolly Dolly
 Posted: 11:59 - 23 Feb 2007 Post subject: |
They handle fine! Throw em around like anything else... seriously, I can lob the CB500 round a roundabout with me knee on the deck faster than I could ever get the Mito round... if you're having problems with handling it's definitely in the setup of the bike as the bike can take whatever you throw at it. Sooo many folks slate the CB500 and consider it boring, but in all honesty it's a superb bike... outhandles and outpaces it's newer incarnations...
The problem is the feedback you get from the bike is different. You're position on the bike is different. If you were sat on the RS the same way (ie: take the pegs off the RS, move em forward and down a bit, then whack on a set of renthal bars) you'd probably find the backend feels very similar on both bikes... majority of it will be a confidence thing... it feels different and you need to get used to it... but as recommended, check tyre pressures, ensure rearshocks are set up correctly and in good condition, check alignment, chain tension, and all the other usual suspects (preferably in that order)
Personally I'd say you likely need new rear shocks - common on the CB500... mine still has it's originals badly in need of replacing, and to keep the rearend steady have them set on the 4th notch up (1 down from the "stiffest" setting) and it corners like it's on rails.
Braking - change the lines for braided, check the pads. You'll never out-break the RS - the CB weighs at least 50kgs more - but when setup correctly it can still spit you over the bars if you grab too much front...
Then go out and spend some time getting to know it's little foibles etc... once you get used to it you'll find you can toss it around all over the place at speed without issues. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
| Finglonga |
 Finglonga World Chat Champion
The last post was made 19 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
