 slj23 Nitrous Nuisance
 sickpup Old Timer
 GSXFire Trackday Trickster
 Posted: 11:26 - 23 Feb 2007 Post subject: |
I had a similar problem with my 2000 600s bandit, turned out to be the chain and sprockets, put it on the centre stand and slowly turn the rear wheel while moving the chain up and down, i guess you will find the chain tension changes a lot, a small difference is ok but to much and the chain is stretched or the sprockets are worn.
Another thing they are bad for is the carb balance making the engine run slightly rough, you don't always notice it till they are re-balanced and then you find out how bad it was. ____________________ Fire by name Firefighter by nature.
My old bikes. https://www.bikepics.com/members/firefighter1/ |
