| MarJay |
 MarJay But it's British!
 Posted: 17:09 - 23 Feb 2007 Post subject: Slowing down indicators |
Hi There,
My KE100 failed its MOT last week. It failed on nine items in total, most of which were fixable. Some of which required a replacement front wheel, and two of which were the indicators flashing too quickly.
Previously I had replaced the indicator relay from a 21w x2 unit to a unit which can handle 8-21w x2. I replaced all of the bulbs with 10w bulbs and they started working.
However they didn't work that well at idle, so I rewired them directly to the battery. They work well, but speed up a LOT when you rev the engine, as the bike has no voltage regulator, just a diode as a rectifier. I bought what I thought was a 6v reg/rec on ebay, but it turns out it contains instructions for how to convert your old british Lucas 6v electrics to 12v. I've sent the ebay person a snotty email as it was quite clearly described as suitable for 6 or 12 volts.
I digress. My issue is still that the indicators flash too quickly. I've tried changing the bulbs back to the 21w items which were originally there, but this just makes the indicators dimmer.
I'm guessing that putting some sort of resistor in between the rectifier and the battery which will hopefully calm the voltage jump when you rev the engine. Obviously the ideal answer would be to replace the rectifier with a Reg/rec.
Any thoughts on this? ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| hmmmnz |
 hmmmnz Super Spammer
| finpos |
 finpos World Chat Champion
 Posted: 17:48 - 23 Feb 2007 Post subject: |
To get it through it's MOT, diconnect the wire that is charging the battery from the altenator. You'll then have a constant voltage, but you'll be running a total loss system, so don't hang around the testers too long
You near a maplins? you could try buying a 6V Zener Diode for pennies and "upgrading" your rectifier to a rectifier/regulator. Don't know how long it would last...
finpos. |
| cagiva gezzer |
| finpos |
| MarJay |
| MarJay |
 Posted: 22:51 - 23 Feb 2007 Post subject: |
Old PC's are a good source for small heat-sinks. ____________________ a.k.a 'Geri'
The last post was made 19 years, 93 days ago. Instead of replying here, would creating a new thread be more useful? |
