removing mould from bathroom tiles
lee8040
PostPosted: 09:09 - 27 Feb 2007    Post subject: removing mould from bathroom tiles Reply with quote
anyone no how to remove mould from bathroom tiles ? we have a tiny bit in a corner and we've scrubbed and scrubbed but it dont budge, weve used bathroom cleners but nothing moves it, any suggestions ?
techierob
PostPosted: 09:18 - 27 Feb 2007    Post subject: Reply with quote
last time I had that I used a hard surface cleaner with fungicide. I forget what brand it was, but I remember that I picked it up from b&q for a couple of quid and that it's clear and tastes almost exactly like bombay sapphire
Mr.Everready
PostPosted: 09:44 - 27 Feb 2007    Post subject: Reply with quote
If it's in the corner is it actually on the tiles or is it in the sealant ?
If it's on the sealant I think the only way is to remove it and replace it with new stuff.
Trixie
PostPosted: 09:53 - 27 Feb 2007    Post subject: Reply with quote
You can buy mould remover - try that. If it is indeed on the grouting as opposed to the tiles you will need to scrape the grouting out a little and regrout.
Dead nobodies in company cars...
map
Mr Calendar
PostPosted: 11:19 - 27 Feb 2007    Post subject: Reply with quote
As said try mould remover. Leave to soak in for a minute or so. Then use a small scrubbing brush (nail brush) and a cloth. As alternative a dilute solution of bleach and water and scrub.
FWIW best get a grout removal tool and then just regrout. Yes it is a faff but worth it in the long term.
HTH Thumbs Up
colin1
Captain Safety
PostPosted: 19:10 - 28 Feb 2007    Post subject: Reply with quote
i had this
i just covered the old silcone sealant stuff with new mould resistant stuff, and smoothed it into place with a coin
you need a gun plunger thingy, and the tube and nozzle that contains the stuff
you put it along the join between wall and bath, and then to get a nice finish, use a 2p piece and smooth it out evenly, so the wall curves into bath top following the shape of the edge of the 2p
easy job, very satisfying, also a bit messy
pd666
Crash Test Dummy
PostPosted: 19:16 - 28 Feb 2007    Post subject: Reply with quote
erm im a tiler Wink
there are various things to do
1 strip grout out and use bal microflex, its a anti bacterial grout (more work but better in the long run )
2 buy fila grout cleaner italian product ph balanced (scrub well)
3 buy bal microshield and maintain cleaning with this
do not use household cleaners ie bleach, this messes with compounds in the grout, and will make it prone to staining
over the years ive always found removing the grout and replacing with antibacterial grout works best Wink
or an epoxy grout, which would be the most exspensive option, this is for food hygene areas like butchers its impervious to any bacterial penetration around £65 quid for 2.5 kilios which depending on tile size wont cover much
microflex is £12.99 for 3.5 kilos and a much cheaper and viable option
hope this helps
edit if its silicone then use bal microflex silocone sealant Wink £9.99 per tube and wont stain (all the properties of bal microflex)
FZR 1000 RU, FZR 750, Honda VTR Firestorm 1000, Kawasaki Ninja zxr6
Jamie S
PostPosted: 19:19 - 28 Feb 2007    Post subject: Reply with quote
use this https://www.tooled-up.com/Artwork/ProdZoom/TB30132.jpg
it works a treat
pd666
Crash Test Dummy
PostPosted: 19:20 - 28 Feb 2007    Post subject: Reply with quote
no offence, but micky mouse products like that are for your avg joe bloggs i havent got a clue about tiling Wink
stick to bal, its a pros choice for a reason Wink
Mrs_Hippy
The Pink Lady
PostPosted: 20:11 - 28 Feb 2007    Post subject: Re: removing mould from bathroom tiles Reply with quote
Is the grout white or light? If so mix up a strong bleach solution and spray it on. It kills the mold dead and bleaches the area clean. Afterwards regular cleaning with a cleaner designed for a bathroom should keep it at bay.
Caution, of course - you know what bleach can do to shower curtains / clothes / rugs, etc and its not that kind to the environment so use wisely!
Karma - Karma
Walloper
PostPosted: 20:54 - 28 Feb 2007    Post subject: Reply with quote
You need these and some elbow grease.
The last post was made 19 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 69.05 Kb
