Driving Lessons - Reversing around corner - Tips required
king kong
PostPosted: 08:38 - 28 Feb 2007    Post subject: Driving Lessons - Reversing around corner - Tips required Reply with quote
I've been giving my sister-in-law a few driving lessons. But I cannot explain properly the means of reversing around a corner. I can demonstrate no problem, but when it comes explaining at which point one starts turning and straightening up - it goes tits up.
I've driving so long now that it is second nature. Can anyone offer any tips so that I can explain easily?
McGee
O RLY?
PostPosted: 08:40 - 28 Feb 2007    Post subject: Reply with quote
Use the rear pillar of the car to decide when to start turning.
Line up the curb with the middle of the rear window then its time to start to straighten it up.
Actually its hard as hell to explain that Laughing
Its pronounced Jixxer!
PostPosted: 08:42 - 28 Feb 2007    Post subject: Re: Driving Lessons - Reversing around corner - Tips require Reply with quote
A blind spot mirror can help see exactly where the car is - but you shouldn't be using this in the actual test.
techierob
PostPosted: 09:52 - 28 Feb 2007    Post subject: Reply with quote
mostly what mcgee already said. The best thing to do is break it down into two stages. Assuming the corner's on the driver's side:
1. reverse parallel to the kerb until the driver can see the corner through the driver's side rear-door window (assuming it's a small hatchback) or just before it lands in the blind spot of the driver's wing mirror if it's a saloon. This part of the manoeuvre should be done slowly, and they should stop the car when they're lined up with the corner. My instructor would occasionally tell me to shift to neutral and put the hand-brake on just to punctuate the procedure.
2. turn in slowly and slightly wide and use the wing mirror (with backward glances more for appearance's sake and to keep from backing over a toddler than anything else) and start straightening the wheels up when there's still a respectable distance (about 2-3 feet) from the kerb and hold the wheel straight when they're parallel. If I remember right, they're allowed an 18-inch gap between the wheels and the kerb, so it's best to start off using all of that allowance and then lopping off a few inches as they improve
slightly off-topic, but I found that finding an empty car park and reversing in figure eights for a couple of hours was a good way to build up confidence for manoeuvres.
JonB
Afraid of Mileage
PostPosted: 10:18 - 28 Feb 2007    Post subject: Reply with quote
Remember you are allowed to use the side mirrors on reversing round a corner, apparently you weren't able to a few years ago.
Just use the left mirror to keep tabs on the rear of the car. A common problem is that the learner straightens up too quickly leaving the car far from the kerb.
Adam_P
PostPosted: 11:42 - 28 Feb 2007    Post subject: Reply with quote
Rubbish, they're attached to the car, you can use them whenever you like, always have been able to. They're there for a purpose.
But I agree with using them for the reversing around a corner. Just get them to keep glancing at the one that's nearest the kerb (depending on which direction you're reversing, obviously) it's all a case of keeping the car parallel to the kerb. It will become easier for them (it's backwards, and you're going backwards too) the more they practice.
You used to be able to take your seat belt off to be able to turn around to get a better view at this point in your test, not sure if that is still a option too?
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
PostPosted: 11:45 - 28 Feb 2007    Post subject: Reply with quote
I was told not to do that in my test three years ago, because you were supposed to be looking out of the back window and would get marked down for not doing so.
I still managed a few quick glances though Smile.
pa_broon74
PostPosted: 11:47 - 28 Feb 2007    Post subject: Reply with quote
My first driving instructor had a 7 point plan for reversing round the corner. He had wee dots on the rear windscreen & quarter windows, it was way too complicated... (The reverse parallel park was even worse, it involved a powerpoint presentation...)
Just keep it simple, use markers in the car to line up with static points (like the kerb) outside the car. Try not to have more than three steps, it just gets confusing. (Well it did for me, thats why I failed so often... Ummm.... Honest... Embarassed )
Anton
PostPosted: 12:00 - 28 Feb 2007    Post subject: Reply with quote
A Drive forward and stop parallel to, and not more than one metre away from the blue car. Select reverse gear. Look to check it's O.K. to move off. Drive back very slowly and watch for the corner of the blue car appearing in the side window.
BWhen you can see the corner of the blue car, turn the wheel to the left one full turn. Check the road ahead and the road behind over your right shoulder. If it's safe, continue reversing until the front of the car alines with the back of the blue car. Turn the wheel fully to the right, watching you clear the blue car. The car will begin to swing in towards the kerb.
C Here you will be close to the kerb and the blue car. Still move the car very slowly and take off some of the right lock so that the front of your car does not swing in too far. Check your distance from the kerb and from the blue car. Keep your car within two car lengths from the blue car.
D Here you should be close to the kerb. If you need to correct your position you are allowed to move forward and backwards to get it right. But too much will be frowned upon by the Examiner. If you are not in the middle of the road and not on the kerb you should be O.K.
TOP TEN REASONS WHY PEOPLE FAIL THE PRACTICAL DRIVING TEST
OBSERVATION AT JUNCTIONS : Ineffective observation and judgement
REVERSE PARALLEL PARKING : Ineffective observation or lack of accuracy
USE OF MIRRORS : Not checking or not acting on what is seen
REVERSING AROUND A CORNER : Ineffective observation or lack of accuracy
INCORRECT USE OF SIGNALS : Not cancelling or giving misleading signals
MOVING AWAY SAFELY : Ineffective observation
INCORRECT POSITIONING : At roundabouts or bends
LACK OF STEERING CONTROL : Steering too early or too late
INCORRECT POSITIONING : to turn right at junctions and in one way streets
INAPPROPIATE SPEED : Going too slow or being hesitant.
Or better still, go here https://www.2pass.co.uk/parallel.htm
Tarmacsurfer
PostPosted: 16:17 - 28 Feb 2007    Post subject: Reply with quote
I've been riding for many years, recently bought a Reliant Rialto and have effectively been teaching myself the mechanics of driving something that is wider than my elbows.
Reversing is easy, it's sort of like climbing. Don't look behind you Wink
I'm immortal. Well, so far.
Pte1643
PostPosted: 18:06 - 28 Feb 2007    Post subject: Reply with quote
IMO this is a bullshit exercise.
I mean, who ever uses this manoeuvre in real life anyway?
What if your driving a van, or similar (Ambulance), with NO back window, although presumably not on your test? Confused
You use your mirrors, that's what.
I can remember though, that one of the biggest points my instructor used to highlight was to make sure you glance over your RIGHT shoulder as the car turns the corner and the nose "Swings" round.
Problem is while taking driving lessons you are taught how to "Pass a Test" rather than how to drive "Practically".
king kong
PostPosted: 18:18 - 28 Feb 2007    Post subject: Reply with quote
What is this 'blue car' you speak of?
Pte1643
PostPosted: 18:21 - 28 Feb 2007    Post subject: Reply with quote
Jeez... Didn't you know your 'spossed to have a Blue car convienently parked when your teaching someone to drive. Laughing Laughing Laughing
colin1
Captain Safety
PostPosted: 19:02 - 28 Feb 2007    Post subject: Reply with quote
dont close your eyes, but use the force, get a feel for the manouver
Teaman
PostPosted: 20:04 - 28 Feb 2007    Post subject: Reply with quote
how do you reverse round the corner in your car?
the key to passing your test is OBSERVATIONS,
Ive just passed my test a week ago and one of the manuvers was this
Get her to pull up just past the junction, but make sure she is about a grates width away from the kurb and she has a clear view of the edge of the corner in the near side mirror.
(some peole like to dip the side mirror now to get a slightly better view of the kurb, this is fine just remember to put it back to the same possition it was after doing the corner)
before setting off do all the life safer things and select reverse.
use the clutch more than brake and go slowly. as mcgee said as you look through the passenger side mirror you will line up with the corner and you will have lost a view of it in the side mirror. do a complete turn of the steering wheel and gradually go around the corner makeing more or less turns as needed but avoid weeving.
if she sees anyone else coming on the road they have right of way and she needs to stop.
when she has got round the corner she will need to straighten up and finnish about a grates gap between the car and the curb.
depending on the car she might need 2 turns depending also on the corner,
pick a more rounded corner at first to build confidence, then go for more square corners
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
Teaman
PostPosted: 20:06 - 28 Feb 2007    Post subject: Reply with quote
https://www.2pass.co.uk/video.htm
way hay, video lessons by 2pass.co.uk
just did a google, its well cool
The last post was made 19 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 96.73 Kb
