CODE RED!!!!!!
freestyler_onli
PostPosted: 19:27 - 03 Mar 2007    Post subject: CODE RED!!!!!! Reply with quote
I put this sealant in my tyres, but knob-head here let the battery run down and now it wont start.
I tried bump starting it in 1st and 2nd but to no avail.......... Sad
Any other tips....... Shocked
Quote Me Happy
PostPosted: 19:28 - 03 Mar 2007    Post subject: Reply with quote
Charge the battery.
freestyler_onli
LOL.
I gathered that - i just couldnt be bothered.
I forgot to mention the needle on the speedo is stuck at 16 so i hope it wont start that high! Confused
Quote Me Happy
PostPosted: 19:29 - 03 Mar 2007    Post subject: Reply with quote
freestyler_onli wrote:
LOL.
That sounds like a fault error code then. You might have to try and find on the net what pointing to 16 means.
freestyler_onli
PostPosted: 19:31 - 03 Mar 2007    Post subject: Reply with quote
More like i fucked it on the second day! Laughing
keyser soze
LOL.
it means flat batt..
sorry the voices told me....
freestyler_onli
PostPosted: 19:35 - 03 Mar 2007    Post subject: Reply with quote
Well lets hope the voices are right
Shocked
cokker
PostPosted: 20:05 - 03 Mar 2007    Post subject: Reply with quote
I doubt that would bump start, half the engine is run by electrics (carbs etc) and if the battery's dead those parts are not going to do their job.
It's not like bump starting an old CB750 Razz
No longer have a bike due to a DVLA/Court royal f**k up.
freestyler_onli
PostPosted: 20:24 - 03 Mar 2007    Post subject: Reply with quote
Meh.
Hopefully ill be able to sort it out tomorrow night. Cool
Bendy
Mrs Sensible
PostPosted: 21:56 - 03 Mar 2007    Post subject: Reply with quote
Jump start it.
Or just charge the battery you lazy twat.
Sparks!
Sir Tart-a-lot
PostPosted: 22:01 - 03 Mar 2007    Post subject: Reply with quote
What's putting sealant in your tyres got to do with the battery running flat?
Finglonga
PostPosted: 23:09 - 03 Mar 2007    Post subject: Reply with quote
Yep? Should have put the sealant in the battery it would never be flat again. Mr. Green
Andy Sez....
F.Y.Y.F.F.
PostPosted: 23:32 - 03 Mar 2007    Post subject: Reply with quote
And why does your speedo have a '16' for the needle to point to Razz.
Rookie
PostPosted: 23:52 - 03 Mar 2007    Post subject: Reply with quote
I imagine a 14k redline and a 16k tacho maximum?
Ichy
PostPosted: 01:05 - 04 Mar 2007    Post subject: Reply with quote
Rolling Eyes
Ariel Badger
PostPosted: 01:11 - 04 Mar 2007    Post subject: Reply with quote
Tyre sealant will to be the cause of the problem, I have done it myself. You need to make sure that you have the right sort, 6volt or 12 volt, + or - earth. Get it wrong and you are bolloxed, flat battery and your clocks fucked at least, worst case your power band will stretch and fall off.
brooky
PostPosted: 02:17 - 04 Mar 2007    Post subject: Reply with quote
LMAO Laughing
Suzuki GSX-R 750 K6.
cestrian
PostPosted: 02:50 - 04 Mar 2007    Post subject: Reply with quote
Ya cunny funt.
PostPosted: 14:19 - 04 Mar 2007    Post subject: Re: CODE RED!!!!!! Reply with quote
If you haven't taken it for a run after putting sealant in your tyres you could be in for a nasty shock when you do ride off.
they say take it out for a run so the sealant spreads over the whole of the tyre and not sit in one place causing the wheels to be out of balance. Take it easy when you ride off!
I hope everything is OK otherwise you are facing a rather nasty bill to get this sorted.
Triumph Trophy Launch Edition
freestyler_onli
PostPosted: 17:38 - 04 Mar 2007    Post subject: Reply with quote
Yeah thats what i planned to do.
For all the cockfags out there - i put the ignition on to turn the movement sensor off the alarm - but i didnt turn the ignition off again.
My own fault i know.......... Cool
Keir
PostPosted: 17:50 - 04 Mar 2007    Post subject: Reply with quote
just jump it off a car or another bike.
Current : '08 Yamaha FZ1s
iooi
PostPosted: 18:24 - 04 Mar 2007    Post subject: Reply with quote
Well a couple of warning lights should take a long time to run a battery down, unless you had the lights on as well.
As a aside what sealent have you used ?
freestyler_onli
PostPosted: 21:09 - 04 Mar 2007    Post subject: Reply with quote
You're right- the headlights were on (automatically).
I plan to chrage it tomorrow when the weathers a bit better.
FYI i used 'Ultraseal' - i first saw it as a 'hands on Demo' at the BMF show. I stuck a screw driver as hard as i could into a fully inflated tyre and within a nanosecond of me pulling it out- the tyre had sealed.
As i did it myself - i can verify that it works.
https://www.ultraseal.biz/home1.htm
***And when i said SPEEDO i meant TACHO
Finglonga
PostPosted: 22:25 - 04 Mar 2007    Post subject: Reply with quote
Hmmmmmm Taco.....
https://www.paleocurrents.com/img/homer_drool.JPG
https://www.wpclipart.com/food/meats_and_eggs/taco.png
Andy Sez....
F.Y.Y.F.F.
freestyler_onli
PostPosted: 19:19 - 05 Mar 2007    Post subject: Reply with quote
Ha!
I never had a Taco. Confused
Oh well, i'm charging it now - lets pray it works. Shocked
The last post was made 19 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 125.39 Kb
