NSR goes bang
bonceunounce This post is not being displayed because the poster is banned. Unhide this post / all posts.
kev
I Hump Things
PostPosted: 01:48 - 27 Aug 2003    Post subject: Reply with quote
If your lucky its just a piston gone which isn't a real problem but if it turns out that it is a blown engine talk to zim or G as I think they both have engines for sale.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
James
PostPosted: 02:10 - 27 Aug 2003    Post subject: Reply with quote
If i could hear the bike myself id be able to tell you straight off but ill just have a go from your description of events.
If your bike has got a kick start, then turn over the engine and feel what the compression is like. If no kick start, try pushing the bike along in secong gear or something and again see how compression feels.
Another good way is taking the spark plug out, holding your thumb over hole and turning engine over.
If its your rings that have welded themselves to the piston or something along those lines then there will be very little if at all any compression. In that case you'll be looking at best, at new rings and possibly piston.
Even though your bike is old it will still have a Nikasil plated bore which is very material, and can survive piston ring failure. If this is scored or damaged though, you will have to replace the whole lot.
If the bike has got loads of compression though, i would first check to see the plug has a spark. If the plug has a spark, and you have compression but the bike still wont start, then it looks like a carb problem. These are usually straight forward to sort out.
Another problem with old bikes is the crankcase gaskets lose the ability to seal. This is unlikely from what you've described though.
If you do need to replace the top end, send me an e mail and ill reply with the names of a few importers of very cheap genuine Honda parts.
In the meantime, keep your chin up! When you've had as many strokers break down as i have, you learn to expect it Wink
James
PostPosted: 02:16 - 27 Aug 2003    Post subject: Reply with quote
Sorry bud, i didnt read your last post before i posted my reply.
It sounds very much like piston and rings.
You can get a whole top end brand new for not much more than hundred quid if you know where to look.
I spent a fortune on bits till i found this site, but i always like to help so here:
https://www.davidsilverspares.co.uk/
Its alright for some Laughing
James
PostPosted: 02:44 - 27 Aug 2003    Post subject: Reply with quote
No they dont always seize up. Sometimes the rings become kind of welded into the piston so they dont spring out and therefore dont make contact with the barrel.
It does sound very much like the rings. Especially if the bike seems easier to push when in gear then it used to.
Its hard to say without meeting the bike in person Laughing
PostPosted: 20:03 - 27 Aug 2003    Post subject: Reply with quote
That is very cheap for the top end of the engine. Suspect you don't need to order the rings seperatly (suspect they come with the piston), but you might consider a new little end bearing while you have it apart. The head can probably be cleaned up.
James
PostPosted: 20:40 - 27 Aug 2003    Post subject: Reply with quote
I bought one of those top ends and you do have to buy rings seperate.
Like i said though, you wont find cheaper
Like shit off a stick
Laura
Playboy Bunny
PostPosted: 23:28 - 27 Aug 2003    Post subject: Reply with quote
It's a shame that tom also known as 125 has blown up his nsr and now trying to get his mate on here to help get it fixed isn't it!
If tom had been nicer to everyone he would of been able to ask himself instead of being banned!
Good girls ride motorcycles bad girls thrash them.
PostPosted: 00:33 - 28 Aug 2003    Post subject: Reply with quote
It isn't too hard to get the top end off the engine. From memory 6 bolts hold the head on and 4 bolts hold the barrel on (once you have disconnected the exhaust and power valve). Took us about 1.5 hours I think on Cols bike when he blew it up.
The biggest problem is that the 2 studs holding the barrel on the alternator side have locating dowels around them which seem to stick in place. I would try squirting a fair amount of WD40 around the studs after you have got the nuts off and leaving it to stand for a while. The use a soft piece of material to try and knock the barrel upwards. Do not hit it directly with a hammer. Use a fairly solid piece of wood between the barrel and the hammer. You don't need to hit it really hard, just alot, and once you have a bit of play try and rock the barrel from side to side a touch. Do not put a screw driver between the barrel and the crankcases to try and lever them apart.
The last post was made 22 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 3 - MySQL Queries: 13 - Page Size: 100.18 Kb
