How old is your lid (quite important actually)?
dabigginger
PostPosted: 00:16 - 09 Mar 2007    Post subject: How old is your lid (quite important actually)? Reply with quote
Something I learnt quite recently is that helmets are only effective from around 3-5 years from the date of manufacture. Now, apparently the manufacture date should be in it somewhere, but I have yet to find mine. The reason being is that the polystyrene slowly absorbs moisture over time and becomes brittle. So, if you have a crash, rather than cushioning the blow, it just crumbles.
Before anyone thinks I'm sounding patronising, I did ask a mate who's been riding for the best part of 10 years if he knew this, which he didn't. I'm sure some people on here probably know, but I'm sure there are some who probably don't. So, even if it could potentially save someone, I thought it might be worth mentioning!
california_rookie
PostPosted: 00:18 - 09 Mar 2007    Post subject: Reply with quote
I'd heard that had a finite life span but never why. Thumbs Up
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
The Tot
PostPosted: 00:25 - 09 Mar 2007    Post subject: Reply with quote
Well some polymers suffer degradation from ultraviolet and the polymer bonds tend to break down over time. If it's something safety critical like that, it's worth not to take the chance as a lid in shop window must have had many months of UV exposure enough to degrade the chains in the polymer. I need to look into it though. Polycarbonates are meant to be UV resistant though.
Never argue with autism
Dan 4RR
PostPosted: 00:27 - 09 Mar 2007    Post subject: Reply with quote
Well if this info is correct my helmet "expires" between 2009-2011. Smile
Humans....the largest form of cancer the world has ever seen!
Speed Cameras - Putting goverment revenue before public safety!
Kaben
If the helmet is stored out of sunlight (i.e shop stock room) then a helmet will not be affected by age.
However Once it has been worn, UV exposure and sweat moisture will slowly cause the polystyrene innards to harden and the outer shell components to become slightly brittle.
My helmet is 7 years old, but as it had only been worn once or twice by my dad then stored for 4 years before I started using it, it was fine.
It is only a worry if you store it in a damp location or in direct sunlight basically.
For a helmet that is in regular use it is recommended to change it every 3-4 years.
Arai however state that their helmets are good for 7 years of regular use if stored correctly between usages (i.e not in direct sunlight and in dry conditions as stated above).
Obviously if you drop it you should think about replacing it.
Its Not a Melon, Its Clearly a Lime!!
Yamaha Fazer 600Now dead, MZ 125 SM
My Deviant Art homepage https://robabloke.deviantart.com/
PostPosted: 03:26 - 09 Mar 2007    Post subject: Reply with quote
My helmet is 8 years old and my bike fell over on top of it the first time out taking several big gouges out of the paint on top.
I'm about due a new one because it's starting to get a bit loose and presses against my nose at high speeds which is annoying.
Not wanting to get into another debate about it but I personally think that the safety benefits of helmets are vastly overrated. I also object to being made to wear one by law.
They do however keep my head warm and dry and the visor keeps the wind and rain out of my face. As long as it still achieves this task in comfort, I'll keep wearing it. It's starting to become less comfortable now so maybe time for a change.
Rookie
PostPosted: 04:30 - 09 Mar 2007    Post subject: Reply with quote
Mine's going on 3 years old, I was shopping for new helmets today. Looking at an Arai and an AJC. Fed up with how noisy the cheap one I've got is.
CoronaBoner
PostPosted: 07:16 - 09 Mar 2007    Post subject: Reply with quote
Mines 3 odd years old and has taken more hits than Baghdad, way overdue a change, would have got one from the Excel show if I hadn't of lost my wallet the day before Brick Wall
2004 RSV Factory
Cluck cluck chicken
Pte1643
PostPosted: 11:44 - 09 Mar 2007    Post subject: Reply with quote
They certainly do. Thumbs Up
And if anyone wants to know (that didn't already) the Date of Manufacture is on the chin strap on an Arai. Thumbs Up
If your after a quiet helmet then Arai shouldn't be your first choice. They're not exactly the most quiet. Better than some admittedly, but not as good as they could be for the money. They're one of the few manufacturers that still use side pods to hold the visor on, these add to the noise levels, when directly comparing them to the flush fitting one's (Shoei, for one example).
McGee
O RLY?
PostPosted: 11:51 - 09 Mar 2007    Post subject: Reply with quote
I like to get a new one every year Embarassed
But now I have to pay for it I'm not sure Laughing Crying or Very sad
Its pronounced Jixxer!
Simple
PostPosted: 12:33 - 09 Mar 2007    Post subject: Reply with quote
I'm planning on changing my AGV soon, it's 2.5 years old, getting loose and has been to cyprus twice, once as hand luggage and once in the hold Shocked...
I'll replace it when one of the current visors break.. I can see one is starting to fracture at the little tab.... so wont be long.
mine has had plenty of knocks and I've fallen over wearing it twice, once on the bike once the pup took my legs from under me...
the next lid I get I'll want to be lighter as at 100mph pluf it presses on the top of my head and gives me a head ache Thumbs Down Sick makes me feel quite sick.
Insta - FemFeral
PostPosted: 12:35 - 09 Mar 2007    Post subject: Reply with quote
I get a new one every year too.
The thing is, helmet technology is always improving so a new lid is going to be more protective than one that was manufactured eight years ago whether ot not you take age into account.
I'd rather not take the chance with my head.
Kaben
PostPosted: 12:51 - 09 Mar 2007    Post subject: Reply with quote
You also have to take into account that with a Shoei style lid there is less material between your ears and the air turbulence. The difference between the two styles is negligble.
The fit and materials around the neck of the helmet have a much grater impact on noise.
The Number and shape of vents will also have a great impact. For Example an RX7-Corsair is an amazing lid but those vents will not keep it quiet.
mark83
PostPosted: 16:15 - 09 Mar 2007    Post subject: Reply with quote
Oh memories.....
Now you've got me thinking about the show!
BTW, do you fancy going to Ace Cafe this weekend, given that it's 'Superbike Sunday' this sunday?
I'll post it as a general topic as well......
Kawasaki ER6n -> Honda CBR600RR -> Honda VTR 1000 -> Moto Guzzi Norge 1200
Buy my Mercedes 350 Sport AMG Evo
t121anf
PostPosted: 16:26 - 09 Mar 2007    Post subject: Reply with quote
about 6 months Sad as i had to replace it after dropping it
PostPosted: 17:33 - 09 Mar 2007    Post subject: Reply with quote
5 months. I think it'll be ok.
Kal
PostPosted: 17:50 - 09 Mar 2007    Post subject: Reply with quote
I thought everyone knew about this, it was mentioned on my CBT and my DAS by the instructors of two different schools in Leicester and Nottingham.
My current lid and my previous one has the date alongside the sizing information inside.
Kal...
PostPosted: 17:51 - 09 Mar 2007    Post subject: Reply with quote
Same, although they told us that fibre glass/ composite lids are good for 5 years and polycarbonate/plastics ones for 2 years.
gypsyjackson
PostPosted: 17:58 - 09 Mar 2007    Post subject: Reply with quote
My CBT instructor also told me that.
My helmet is only 9 months old, but it's a pretty rubbish looking one, by a no name. Gold stickered, but I'm not sure. Also, I fell in love with the Rossi Manara helmet in the HG ad in MCN on Wednesday. Going to try it on tomorrow morning. God bless 0% finance...
Pte1643
PostPosted: 23:15 - 09 Mar 2007    Post subject: Reply with quote
Absolutely.
The Shoei comparison, regarding the visors, wasn't meant to be a direct Arai Vs Shoei debate, I just used it to try (badly it seems) and highlight, and compare, the different visor fitments rather than the helmets themselves. I could have just as easily said AGV, or any other.
Sorry for the confusion. Thumbs Up
But it's interesting you say there is less material between your ears and the outside (if you like) of the Shoei, because there's virtually none on any of the four Arai's I own (or have owned in the past). If you stick your finger in the "hole" that your ear goes in it's virtually as if there's only a single layer of material in there.
Liquorice
PostPosted: 23:26 - 09 Mar 2007    Post subject: Reply with quote
I think i win, on the newness here Very Happy think i registered it on shark warranty about 2 weeks ago Razz
(admittedly only cos i dropped the old one)
2003 Honda CBR 600 F Sport
www.lsumcc.co.uk
sandino
PostPosted: 23:36 - 09 Mar 2007    Post subject: Reply with quote
I got told that on CBT, also not to put stickers on there as the glue can dissolve the polystyrene. I have dropped my helmet once or twice now, and had a small crash in it, but there is no way i can afford a new one yet. It probably is dangerous but we all do dangerous things.
YBR125 - My bike's current land speed record - 74MPH (indicated)
PostPosted: 23:48 - 09 Mar 2007    Post subject: Reply with quote
That is mainly for the polycarbonate helmets (pretty rare these days). The glue could damage the helmet shell (but petrol would as well, amoung other things).
Resurrection
Ballast Boy
PostPosted: 02:14 - 10 Mar 2007    Post subject: Reply with quote
My helmet is about 2 months old.
Was marked down from £200 to £109 so i bought it.
now at £179
Its a Nolan f102 if im correct
At anything over about 30 MPH its well noisy
Res
ZX9r
sandino
PostPosted: 11:53 - 10 Mar 2007    Post subject: Reply with quote
Thanks, that is interesting. I have one sticker on there already but i would actually want to put more on.
The last post was made 19 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 133.89 Kb
