| Yarri |
 Yarri Crazy Courier
 Posted: 23:56 - 08 Mar 2007 Post subject: Why not to use front brakes on the corners? |
Yeah i know it's a noobish question but i just want to know exacly why and how dangerous it is
I am now quite used to use it all the times, my back brake is useless so i don't really have a choice |
| cagiva gezzer |
| Polarbear |
 Polarbear Super Spammer
| dabigginger |
 dabigginger Crazy Courier
| Louise |
 Louise World Chat Champion
 Posted: 01:25 - 09 Mar 2007 Post subject: |
Ive heard lots of stories to people - front break on a corner.
So ive tryed to stop myself from useing it.
Back break brings me back in if I go a bit wide, I have use the front a lil but that is just the tinyest ammount of pressure. Dont really fancy seeing the ground  |
| G |
 G The Voice of Reason
 Posted: 03:11 - 09 Mar 2007 Post subject: |
What you'll also find is if you apply the front brake while cornering, most bikes will sit themselves up and head for the verge on the outside of the corner.
Most of the times you would think about braking mid corner, it is because you went in too fast and are running wide. The bike sitting up and running even wider is not helpful.
What you'll find on bikes with a long suspension travel is the opposite. Pulling on the front brake a SMALL amount compresses the front suspension, shortens the effective wheelbase of the bike and tightens your line. Brake harder and it will sit-up like other bikes.
So, what do I do? In most cases, you are best to try to stay with it and make it round the corner by leaning further, the bike can lean over a lot further than you think if you keep it steady and smooth. You will get away with trailing the rear brake a bit. If you need to stop for some unforseen hazard, it may well be best to sit the bike up straight THEN brake as hard as you can for as long as you can before you have to come off them and lean it back over again.
If you are on a dirt bike/supermoto, you'll get away with a certain amount of dragging on the front to tighten your line.
That's the reality for me anyway.
Of course, the best and correct thing is to get all your braking done before you turn-in so you don't hit the corner too fast in the first place. In slow, out fast. |
| Speedy3 |
 Speedy3 Traffic Copper
| Jenks |
 Jenks World Chat Champion
| BanditBitch |
 BanditBitch World Chat Champion
| G |
 Posted: 13:02 - 09 Mar 2007 Post subject: |
A bit complicated the way I’ve displayed it, but I see it as something like this….
At any point, a vertical line will show how much grip you have on the graph.
Of course there are many factors that will change things, which I’ve rationalised down to good, average and poor conditions.
So, in good conditions, you may well find that you can still start to turn while braking at the maximum possible, while in poor conditions, not only is it not possible to use the same amount of braking, but if you try to turn when you’re using the maximum possible for the conditions available, you will go past the amount of grip you have.
Given ok conditions, it is possible to use a reasonable amount of braking while turning in.
Edit - oops, messed up, meant to be the upper section for braking.
On the comments about the bike sitting up, it is usually possible to ‘fight’ this with counter steering to keep your line, but you do have to make a conscious effort to do so.
The comments about using the brakes to narrow the steering geometry can be applied to road bikes as well, though less so as mentioned. This also initially ensures that you have good grip at the front – providing of course the conditions means you have a deficit of grip to use.
| trainerphil |
 trainerphil L Plate Warrior
| sandino |
 sandino Scooby Slapper
| Ariel Badger |
 Ariel Badger Super Spammer
| G |
| lumphammer |
 lumphammer Trackday Trickster
 Posted: 22:27 - 09 Mar 2007 Post subject: |
Perhaps this is not the best time to use the front brake too hard as well.  |
| Ariel Badger |
| G |
| Paivi |
 Paivi World Chat Champion
 Posted: 15:25 - 10 Mar 2007 Post subject: Re: Why not to use front brakes on the corners? |
The last post was made 19 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
