Hmmm, reserve.......
yambabe
PostPosted: 21:00 - 10 Mar 2007    Post subject: Hmmm, reserve....... Reply with quote
Confused Can you "adjust" the point at which a bike goes on reserve?
The Zeph spluttered to a halt on me twice today, both times in fairly inconvenient places. The tank holds about 12 litres I think, yet it ran out at 96km and 102km on the tripmeter! Shocked Both times the fuel guage on the dash showed about half-full and I could see petrol when I opened the cap to refill.
I'm going to have to go out with a can of juice strapped on the back soon I think and see how far it will actually go on reserve, but does (my guess) 2/3rd to 1/3rd on to reserve sound a bit excessive? None of my other bikes had that much left on reserve, and they all went loads further from reserve to reserve!
cestrian
PostPosted: 21:50 - 10 Mar 2007    Post subject: Reply with quote
You cant adjust it, sorry. What bike is it?
NickD
PostPosted: 21:53 - 10 Mar 2007    Post subject: Reply with quote
IIRC the Zephs got a proper old style petrol tap. If so it should be possible to trim the tube for the main feed so it sits lower in the tank.
I was only doing what it said on my licence officer....
Tear along the dotted line!
steveh
PostPosted: 21:59 - 10 Mar 2007    Post subject: Reply with quote
with the older style, reserve is the point that the longer tube can no longer suck fuel through, so youd have to lower the point of exit, but being a mesh be carefull not to get loads of bits in there.
Just drain your tank, and remove the tap from the bottom.
with the new ones, its a solid tube (on mine it is anyway) wich in theory, you could trim down.
cestrian
PostPosted: 22:56 - 10 Mar 2007    Post subject: Reply with quote
If you don't mind me saying......
Problem is tho, by trimming the main tube, you'll gain an extra few miles on the 'main' supply, but the reserve supply will be reduced drastically. There's no point in doing the job, in my opinion. You'll still get the same mileage on a tank full of fuel.
ncrn
PostPosted: 22:59 - 10 Mar 2007    Post subject: Reply with quote
The best thing to do really is learn when roughly your bike is going to run onto reserve, for example my bike does at about 120 miles normally, if I'm not really thrashing the bike everywhere. So as I'm approaching 120 miles on my trip counter I begin to think about how the bikes responding and look out for any signs of running out of fuel.
I don't get caught out as often now I've started doing this Smile
steveh
PostPosted: 23:16 - 10 Mar 2007    Post subject: Reply with quote
Ah, yes i stand corrected, as the reserve sits on the base of the tank, not so far up.
Just fill up your tank ! Razz
djfr1
PostPosted: 23:20 - 10 Mar 2007    Post subject: Reply with quote
Erm, surely if you could still see petrol, your bike should still have been running?
TS50ER + big bore kit n pipe, TZR125 with pv kit, TSX125, KR1S, ZX7R, R1...
steveh
PostPosted: 00:19 - 11 Mar 2007    Post subject: Reply with quote
are you sure your not running it on RES then turning it too OFF?
The markings (if any, could be wrong)
Steve.
cestrian
PostPosted: 00:30 - 11 Mar 2007    Post subject: Reply with quote
Or.... perhaps the tubes are connected 'back to front', ie the RES tube is on the FUEL ON part of the tap, and vice versa.
I had that problem on my GS500, right PITA
Sharpy
PostPosted: 00:35 - 11 Mar 2007    Post subject: Reply with quote
Not always my old kwaki had an old school reserve and it would have 2 tubes into the tank, this meant that you could still have fuel in the tank but not be going anywhere!!! happened to me a couple of times!!! Shocked Laughing Laughing
Crazy, not Stupid.......
https://www.staffordshireriders.co.uk/forum/index.php
https://www.myspace.com/the_sharp
NickD
PostPosted: 00:50 - 11 Mar 2007    Post subject: Reply with quote
I don't think She's saying she was out of gas, just that she had to switch to reserve really early.
Nath
PostPosted: 04:40 - 11 Mar 2007    Post subject: Reply with quote
Yup, and that does seem a fair complaint, 1/5 of the tank capacity is the reserve on my two Hondas.
Drain off all the petrol, see how much you have, then see how much more you need to brim the tank and find out its full capacity. Then note how much fuel you have to stick in to brim it when filling up after hitting reserve. If the reserve really is 1/3rd of the total capacity then I would definitely be looking to do something about it.
Neither of my two running bikes have working odometers/trip-counters. When they hit reserve I start paying attention to how many miles I'm travelling so I don't run out of juice.
Hard livin', hard luck.
Dazbo666
PostPosted: 08:17 - 11 Mar 2007    Post subject: Reply with quote
If it's correct, 1/3rd reserve does sound to be excessive.
In my (admittedly limited) experience approx 1/4 or 1/5 seems to be about the norm...
EDIT : Just for the record, (with conservative riding) my 1991 GPZ will do 163 miles until it splutters to a halt and needs the reserve Embarassed
Word of the day : DILLIGAF
yambabe
PostPosted: 12:03 - 11 Mar 2007    Post subject: Reply with quote
Thumbs Up Spot on.
According to all the specs I can find online the tank capacity should be around 15 litres on this bike, although I've never drained it and refilled it to check. On both stops (first petrol station after I had to put it on reserve) yesterday it took just under £7 to brim it again so about 8 litres to reserve! Shocked
According to my calculations that means I should in theory be able to go almost as far again before it actually runs out of juice, in which case it seems totally ridiculous to me to have reserve kicking in at that point.
On both my eliminators reserve to reserve was about 100 miles and I then had about 20 miles (250) or 15 miles (400) to find more juice. I usually rode by filling up every 100 miles or when it hit reserve, depending which came sooner.
60 miles to reserve just seems stupid to me, really bad design. Either that or the tank may be full of filler........ Confused
krebsy
PostPosted: 12:46 - 12 Mar 2007    Post subject: Reply with quote
My ZZR will do 135+ (13Ltrs+) with two-up and not hit the reserve whereas Phil_C's Hornet hits reserve at 88 miles. all down to the Bike make, model and tank size. A CBRF600S will do 190 miles to the tank easily without a worry.
Dashboard fuel guages are notoriously pish on bikes. Mine does 70+ miles before coming off full and once it hits 110 (at about "2/3rds full") the needle drops like a stone. Don't trust them, just measure the distance from full to reserve and use the odometer/trip meter to know when to fill up.
K.
1280 x 1024.
veeeffarr
PostPosted: 13:20 - 12 Mar 2007    Post subject: Reply with quote
My GS500E does 90ish miles until Reserve, then I think it does another 30 Thumbs Up
SoulRider
PostPosted: 14:07 - 12 Mar 2007    Post subject: Reply with quote
i will get around 120 miles on mine before hitting reserve and then im guessing around 20ish on reserve.
Whereas coronaboner on his RSV mile will only get 80-90 miles before hitting reserve. Different bikes different milage but to be honest half a tank of reserve sounds like way to much.
My Bike Pics
The last post was made 19 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 102.79 Kb
