YAMAHA XJ DIVERSION
iooi
PostPosted: 10:59 - 10 Mar 2007    Post subject: YAMAHA XJ DIVERSION Reply with quote
Looking at one of the above.
Anything worth while that i should make a extra carefull check of ?
20,000 mile on the clock. R reg.
Was quite surprised at how easy they are to handle when not running.
bish777
PostPosted: 11:37 - 10 Mar 2007    Post subject: Reply with quote
No particular vices.
Dont be put off by a noisey engine, theymake a fair amount of ticking at idle when in good condition! Its an oldskool aircooled motor and they do make afair bit of noise.
Just check it over for corrosion, particularly of the rear shock and the exhaust. Otherwise theres not much to worry about.
GSXR1100J
krebsy
PostPosted: 12:50 - 10 Mar 2007    Post subject: Reply with quote
Check the exhaust collectors for corrosion. Replacing the exhaust ranges from 350 quid for a 4-1 Nexxus to 750 for a Yamaha direct replacement. Check under the rear right panel for starter loom corrosion (unclip the connector blocks to the relay, any "green" is a dodgy sign).
Check the top and bottom engine gaskets for signs of oil seepage and the right breather tube under the bike for signs of sludge. Too much and it could be piston rings or just too much oil in the engine overflowing into the air filter.
Umm... That's about it really. I did 8k on mine in a year with just a set of tires and a caliper cleanup after winter. They are pretty bulletproof and a decent hack bike.. Smile
I might pick one up to reminisce.. Smile
K.
1280 x 1024.
iooi
PostPosted: 15:06 - 10 Mar 2007    Post subject: Reply with quote
Well its done and bought now. Laughing
Ran pretty sweet, despite being stood for a while.
No signs of oil leaks and exhaust looks ok for its age.
Much better riding position to the ZZR 250 i have.
AN GOF.
PostPosted: 15:35 - 10 Mar 2007    Post subject: Reply with quote
Good choice, Love mine and cheap to insure and a good 180 mile tank range Thumbs Up
kawashima
PostPosted: 16:19 - 10 Mar 2007    Post subject: Reply with quote
400? 600? 900?
iooi
PostPosted: 16:47 - 10 Mar 2007    Post subject: Reply with quote
600 green with the fairing Very Happy
Felt comfortable from the moment i sat on it, even easy to get on the center stand which surprised me.
Just need to sort out ins.
krebsy
PostPosted: 21:09 - 10 Mar 2007    Post subject: Reply with quote
Post a pic or two. They are comfy for eating up the miles and will run merrily with two-up. Toured around the Cotswolds and over to hereford on ours last year and bar a quick clutch adjustment it was fine.
K.
1280 x 1024.
iooi
PostPosted: 21:26 - 10 Mar 2007    Post subject: Reply with quote
Pick it up later this wekk so it will be in me avatar soon Laughing
The last post was made 18 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 59.69 Kb
