Help, Broken Bolt
davidimurray
PostPosted: 13:51 - 11 Mar 2007    Post subject: Help, Broken Bolt Reply with quote
Hello
Bugeer, damn and blast. Just whipped the front wheel off the er5 to have a look at straightening the front mudguard - bent since I had it. Anyhow, no sucess there so just tried to put the bike back together.
Anyhow got the front axle back in. Started tightening the fork clamp and ping, with 2 or 3 mm left before tigtening up it snapped. My question is, is it safe to ride without it until I get it fixed. The axle bolt is fine and done up tight, just no clamp bolt.
Dave
Gazdaman
I did a trackday!!!
PostPosted: 14:03 - 11 Mar 2007    Post subject: Reply with quote
So it's just the pinch bolt?
When I was changing G's front wheel on the daytona last weekend, I noted his pinch bolts were less than finger tight.
And I suspect he's riding that slightly harder than you.
As long as the axle's done up ok, it'll be fine. But do get it fixed sooner rather than later.
Gaz
davidimurray
PostPosted: 14:34 - 11 Mar 2007    Post subject: Reply with quote
Yup just the pinch bolt.
Maybe Very Happy , but I have just been dropping the forks to push it that bit harder!
About to get the screw extractors out and start war with it!
Piccies attached
iooi
PostPosted: 15:43 - 11 Mar 2007    Post subject: Reply with quote
Try a jubilee clip round it in the short term... If you can't get it out.
crazymotorbik...
PostPosted: 16:08 - 11 Mar 2007    Post subject: Reply with quote
Hey,
I had the same problem on one of my bikes. The bolt was seized in and snapped.
I drilled it through then simply nut and bolted it. Worked a treat for me.
Cheers,
Shaun.
ratboy
PostPosted: 17:36 - 11 Mar 2007    Post subject: Reply with quote
depending on how daring you are you can try drill it to the closest size to it. i did it and gently wriggled it and it brought the thread out of my scooter, could tap it slightly bigger if it all goes wrong.
hope its rmotely helpful!
rat
davidimurray
PostPosted: 20:59 - 11 Mar 2007    Post subject: Reply with quote
Hi Guys
Got it sorted in the end. Tried a screw extractor but it was so tight that it destroyed a Moore & Wright tap wrench and then broke the square off the extractor. Ground a couple of flats on the extractor body and got the mole grips on it. Then drilled through the bolt and put a nut and bolt in instead.
Took the bike out for a test ride and all is well. Since i've dropped the clamps on the forks 5mm there is a massive difference to the handling. Had a race with an RX8 and a 5 series BMW on the twisties and completly smoked them Smile Done a great job on reducing the chicken strips and I think it is now time to get some knee sliders - got a bit close a couple of times Razz
Gazdaman
I did a trackday!!!
PostPosted: 23:17 - 11 Mar 2007    Post subject: Reply with quote
Knee down on an ER-5 is definitely possible, been there, done that.
That's the problem with stud extractors though, they tend to snap, and the annoying thing is they're made out of the hardest stuff known to man, so they're a complete twat to drill through.
Well done though.
Gaz
The last post was made 19 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 55.79 Kb
