Tell me about torque?
yambabe
PostPosted: 23:17 - 12 Mar 2007    Post subject: Tell me about torque? Reply with quote
Can someone throw some numbers at me about torque and what it means?
Himself reckons there's no point in my having a bike with mega bhp cos I'd never use most of it, but he says a strong motor with lots of torque would be ideal. I kind of know that torque is related to acceleration and is a kind of thrusty effect but that's about it as far as my knowledge goes. Embarassed
So what is "good" or "high" torque in terms of numbers?
The bike I have my eye on for my next one has a mere 52 bhp according to the spec sheet, and it has 69 Nm of torque. Is that good?
Does that mean I'll have plenty of acceleration at fairly low revs to make stuff like overtaking easier? (Which is what I want.......)
veeeffarr
PostPosted: 23:25 - 12 Mar 2007    Post subject: Reply with quote
Torque = Acceleration
BHP = Speed (Torque with a factor of time applied)
Torque is basically a rotating force, like opening the lid of a jam jar. BHP is the rate at which work can be done...
Gah, stupid words... HTH
PostPosted: 23:30 - 12 Mar 2007    Post subject: Reply with quote
Trouble is that torque has 2 different meanings. The engineering meaning (turning effect of a force) and the more generally used (how flexable an engine is). They are not the same thing by a long way (a highly tuned 2 stroke will tend to have a very good max torque figure, but few people would claim the bike is flexable).
First one is the one that the numbers on a spec sheet refer to (in ft/lb). Second is not really mentioned, although possibly the best way to see it from a spec sheet is how far apart the rpm are for max power and max torque.
Power is just torque x rpm.
yambabe
PostPosted: 23:35 - 12 Mar 2007    Post subject: Reply with quote
Max power is at 6000 rpm, max torque is at 3500 rpm apparently.
PostPosted: 23:55 - 12 Mar 2007    Post subject: Re: Tell me about torque? Reply with quote
As Keith said - people usually say 'power' and talk about peak power but talk about the range of torque an engine has when they say 'torque'.
However, they could quite reasonably talk about a high peak torque and the range or power an engine has.
An engine with a good range of torque will generally have relatively (to it's peak power) a wide range of power through out the rev range.
I disagree with Toby. Torque does not mean acceleration.
High power gives you good acceleration and a high top speed.
High torque allows you to pull heavy things up hills.
A tractor will probably have very high torque, but won't accelerate very well. A cbr250 has a high power output for it's capacity, but would be useless at pulling a plough.
If you are not one to rev your engine to the red line every time, you may find that an engine with a wide range of torque to better suit your riding style. This doesn't have to mean a lack of power - for instance a GSXR1000 K1 had the highest peak power in it's class at the time, but also had the widest range of torque / power across it's rev range.
lilredmachine
PostPosted: 23:56 - 12 Mar 2007    Post subject: Reply with quote
I would say you are more concerned with power delivery than the amount of torque and power itself. As Blue said, having a lot of torque does not mean that a bike will be flexible or easy to use, it just means it has a lot of torque. Wink
What is far more important is how it is delivered and the area of the rev range it appears in.
yambabe
PostPosted: 00:07 - 13 Mar 2007    Post subject: Reply with quote
OK I'm kind of getting it I think, but I could still do with you giving me some numbers!
So as a comparison, the "max" figures are
"my" bike 52PS (bhp?) at 6000 revs, 69Nm at 3500 revs
GSF650S Bandit 77.5 PS (bhp?) at 10100 revs, 59.2Nm at 4000 revs.
So "my" bike has less overall power than a bandit, and less top speed, because it has a much lower rev range. However, it has the potential to pull a little harder in the low revs and may have better acceleration? But the bandit would be described as having better "torque" in everyday usage because it has a much broader range to spread it over and therefore more flexibility?
wristjob
PostPosted: 00:10 - 13 Mar 2007    Post subject: Reply with quote
for what engine?
the "best" engine will have its peak torque across the widest rev range.
however due to the unique way the bbc is funded same torque at more rpm =more bhp
its all made up numbers
people will tell you a vtwin has more torque than an inline 4
and at some rpm that might be true
so man invented gears.
but the truth is none of it matters on the road.
just ride the bike thats under you, if its a peaky 2stroke then rag it,if its a lazy twin then use the no revs,if its a modern litre 4 pot then just enjoy the fact its got way more power than you can use.
veeeffarr
PostPosted: 00:11 - 13 Mar 2007    Post subject: Reply with quote
Don't forget also that torque and bhp are the same at 5252rpm Wink
lilredmachine
PostPosted: 00:12 - 13 Mar 2007    Post subject: Re: Tell me about torque? Reply with quote
And I disagree with G. Torque is horsepower. Without torque you have no horsepower, so if horsepower is to do with acceleration and top end then so is torque. Don't forget that for an engine to keep producing power in the upper rev range (no matter how high that range is), it still has to be producing a gob of torque too.
lilredmachine
PostPosted: 00:21 - 13 Mar 2007    Post subject: Reply with quote
Another example of that is the little Skoda Fabia VRS.
It has 130hp as stock and about 220lb/ft torque, as you would expect for a low power high torque diesel the 0-60 is slow, 9.5 seconds, but the in gear acceleration times are (for a car) very quick.
Superchips will flash the ECU and dyno tune it for a fee, this on average gives about 165hp and 330lb/ft of torque. Despite only receiving a 35hp increase the 0-60 drops almost 2.5 seconds to 7 and the top speed increases to over 145mph from 125. This seems to suggest that torque may have a little more to do with acceleration than G is letting on...
The torque is produced later on into the rev range, so whilst hp is not dramatically increased in pure numbers, the torque providing it is there stronger and for a longer amount of time, hence the dramatic performance increase.
mr.z
PostPosted: 00:25 - 13 Mar 2007    Post subject: Reply with quote
This is how i like to think of it, how accurate it is I'm unsure but i don't worry about that sort of thing..
Say your hitting somebody with sticks..
Now say your using a big stick full of lead and hitting hard, this is torque
Now you hit with the sticks a little faster, this isbhp
RPM is how many sticks are employed at the time.
Both stick beatings produce the desired result, but in different ways..
PostPosted: 00:35 - 13 Mar 2007    Post subject: Re: Tell me about torque? Reply with quote
Something like the aforementioned CBR250 is an ideal example of a bike that makes reasonable power but very little torque.
It does this by revving very high.
I've ridden bikes that have a little more peak power, but something like 3X the torque. They were probably actually slower than the CBR, though that's more due to the weight, which isn't adequately compensated for by the extra torque.
lilred:
As I said, torque is useful for tractors Wink. I suspect that the aforementioned chip may well increase the range of torque power which is more needed in a car I believe.
Sharpy
PostPosted: 00:47 - 13 Mar 2007    Post subject: Reply with quote
That is a great way of putting it, Thumbs Up also got an hilarious image in my head!!!! Laughing Laughing
Crazy, not Stupid.......
https://www.staffordshireriders.co.uk/forum/index.php
https://www.myspace.com/the_sharp
bazza
PostPosted: 01:53 - 13 Mar 2007    Post subject: Reply with quote
"Torque vs bhp"? "V twins"?
You realise G will be stuck in this honeypot thread for days, don't you?
Nice. Thumbs Up
lozzypop1
Certified MILF!
PostPosted: 08:56 - 13 Mar 2007    Post subject: Reply with quote
That is the best way anyone has explained it (for me at least) Thanks Tobes! Thumbs Up
The last post was made 19 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 101.58 Kb
